    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 09-02-2013, 10:07 AM   #8056
RShockley's Avatar
Originally Posted by kes7u View Post
Alright. I have a bit of a conundrum. I am building my rb6 kit, and haven't built a kit since my original Losi JRX2. I used a regular pair of coarse pliers when building the front turnbuckles, along with a turnbuckle wrench. All of the front plastic pieces are fairly well scuffed from the pliers. Certainly usable, but a little bit ugly. I subsequently build the rears using a wrench on the plastic parts. They turned out beautifully! Now. Do I give in to vanity and go back and rebuild the fronts with new plastic pieces? I can always use the current ones as back ups.
Kevin
I would but I go a bit overboard on making sure my cars look good.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 09-02-2013, 10:24 AM   #8057
Life_livin's Avatar
Trader Rating: 16 (100%+)
I would too just because I like my cars looking good and ballcups are such a crucial part of the car I don't take any chances where their strength could be compromised.
Life_livin is offline   Reply With Quote
Old 09-02-2013, 10:32 AM   #8058
Trader Rating: 82 (100%+)
Kevin
Use a dremmel sanding bit and work out some scruffs on the ball cups to save money, the ball cups aren't bad or weak, just scratched.
"Tinkering with Toy Cars that go around in circles"
OCRC | Club R/C | Mike's Gulf Coast | Kyosho RB6 ZX6 MP9E
Kuya_Kimo is offline   Reply With Quote
Old 09-02-2013, 04:02 PM   #8059
MikeXray's Avatar
Trader Rating: 73 (100%+)
Ran the car at a hard packed outdoor track, learned how important tires are! The car worked really well when I made the right tire choice, but for some reason in the main I had no rear bite. A few locals ran mid motor and did well.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-02-2013, 04:24 PM   #8060
I just ordered up a RB6......gonna try out mid motor..looking forward to it.....
I just got an Mp9e TKi and its pretty nice......
I've been die hard team associated for a long time......curious to see how the build goes!
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 09-02-2013, 04:32 PM   #8061
Trader Rating: 244 (99%+)
You prob ran the wrong tires for the main. Vineland gets slippery at night. You have to go back to where you started the day. I ran handlebars in round 3 and went back to impacts for the mains.
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 09-02-2013, 04:52 PM   #8062
Life_livin's Avatar
It is a little harder to build than a b4.2 but you will be able to tell right away how much higher quality it is. You will love it I know I did!
Old 09-02-2013, 05:03 PM   #8063
MikeXray's Avatar
Yup, that's what I was thinking, with the long break and cooler temps, even though it was blown off well, it seemed a bit more slick. If I had went back to holeshots I prob would have been fine.
Old 09-02-2013, 07:40 PM   #8064
Super Moderator
Trader Rating: 17 (100%+)
Fred's dead on. At this track you typically have 3-4 setups.
Practice
Rd 1&2
Rd 3
Mains
Setups can be just tires or totally different changes. To give you an example, I ran the following
practice - Green Flipouts w/ open cell foam & 8175 M3 fronts
Rd 1 - super soft impacts (1 run on them) w/open cell foam & 8175 M3 fronts
Rd 2 - super soft impacts (2 runs on them) w/open cell foam & 8175 M3 fronts
Rd 3 - super soft Handlebars (STD new) w/ closed cell foam & soft handlebars w/ 3/4 rear insert fronts
Mains super soft impacts (new) w/open cell foam & 8175 M3 fronts
I also made a few setup changes along the way to take traction away. I reversed them AFTER rd 3. If you ever are in doubt, always go with a M3/M4 Holeshot. The newer the better.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-02-2013, 08:16 PM   #8065
Enigma R/C's Avatar
The RB6 is just to amazing!
Looking to buy/sell USED rc gear? www.rcshed.com
Enigma R/C is offline   Reply With Quote
Old 09-02-2013, 11:13 PM   #8066
+1
Jason Snyder
Old 09-04-2013, 02:32 AM   #8067
+1
got it built? I thought mine was way better than the Losi SCT i built quality wise. The shocks are oh are so smooth as well
AlwaysLOSI is offline   Reply With Quote
Old 09-04-2013, 02:46 AM   #8068
steam's Avatar
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 09-04-2013, 08:41 AM   #8069
Frank L's Avatar
Trader Rating: 148 (100%+)
I just put a mid motor together and would like to see some pics of how you arranged it under the shell.
Thanks.
Old 09-04-2013, 09:00 AM   #8070
Johnn27's Avatar
Trader Rating: 71 (100%+)
Thanks.
Frank , check out pics of Hara's mid motor, sideway shorty battery reedy car!
http://2wdmod.com/2013/02/06/haras-r...edy-race-2013/
Johnn27 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
