    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 08-30-2013, 05:19 PM   #8041
steam's Avatar
Originally Posted by aloksatoor View Post
Big deal break out the sander and a drill and m3 tap and should be golden. Seems to have enough meat in there to hold a decent m3 screw.
right because I want to pay 30$ for a part and mod it. I'm not against that but at the same time
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 08-30-2013, 05:21 PM   #8042
steam's Avatar
would also be cool if the back side was threaded so you wouldn't need a nut to tighten to the gear box
Old 08-30-2013, 05:28 PM   #8043
aloksatoor's Avatar
Trader Rating: 42 (100%+)
hehe yeah Im happy with modding the aluminums because I tried that with the original plastics and ended up buying a new plastic tree, turned out pretty bad .
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-30-2013, 06:28 PM   #8044
Default Is the RB6 being updated?
I see that Stormer no longer carries it......
And AMain says there are limited quantities......
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 08-30-2013, 07:13 PM   #8045
Super Moderator
Trader Rating: 17 (100%+)
Yes. It's the RB6.2 Ryan Lutz edition
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-30-2013, 07:15 PM   #8046
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Lutz runs for durango. Really? A .2 already? I figured on a Worlds edition or something.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 08-30-2013, 07:54 PM   #8047
He's yanking your chain!
Seriously though...why doesn't stormer carry it?
Jason Snyder
Old 08-30-2013, 08:07 PM   #8048
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default gear diff
Thinking of giving the rear diff a try what weight diff fluid should I try?
Johnn27 is offline   Reply With Quote
Old 08-30-2013, 11:43 PM   #8049
steam's Avatar
SP coming out
Old 08-31-2013, 04:01 AM   #8050
Took my new RB6 out tonight for the first time. Here are my first impressions. Shocks wow these things are nice! It steers way better than the 22 I was borrowing from a friend. Easier to drive in almost all sections of the track. I was told by another racer at the track that he picked up a second on his lap times by switching from a AE4.2 to a RB6. While I thought that he was full of $h!t I went ahead and got my first Kyosho. Low and behold when the dust settled I was a second faster. I have owned Losi's for the past 20 years on and off so this is a new side of things for me. I was going to wait for the 22 2.0 but after talking to the team drivers I was less than impressed. They acted like I was interfering with what they had going on. (Even though they are more than helpful on this forum) But Cody Tuner went out of his way to find me and thank me after I turn marshaled for him. So Kyosho sold one kit to a happy customer via the personable driver that they sponsored. Thank you Cody for not being an ass. I wound have been building a 22 2.0 tomorrow had it went a little bit different.
Btw I used the shims from the scte diffs that they no long use to shim the losi 55 pistons during my build. If you guys have anyone at the track that is buying the new scte diff cases then they will no longer need the shims which fit the shocks perfectly.
AlwaysLOSI is offline   Reply With Quote
Old 08-31-2013, 04:06 AM   #8051
steam's Avatar
Btw I used the shims from the scte diffs that they no long use to shim the loss 55 pistons during my build. If you guys have anyone at the track that is buying the new scte diff cases then they will no longer need the shims which fit the shocks perfectly.
good to hear, you need to change your forum name
Cody has always been one of the most helpful guys I have ever raced with
Old 08-31-2013, 04:16 AM   #8052
yeah might need a new account now..........
Old 09-01-2013, 08:59 AM   #8053
Hey guys,
i have bought an Rb6 a few days ago and I got it a few minutes ago. I wanted to ask this question a few times in the last days but forgot it.
WHich gearing would you suggest? I am using an LRP 8,5t engine, track is not that highspeed, it should have a good topspeed but also a gut accel.
Ice22 is offline   Reply With Quote
Old 09-01-2013, 09:06 AM   #8054
Trader Rating: 91 (100%+)
You should be good with 23/76, unless your track is very short and twisty then 22/76.
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 09-02-2013, 09:18 AM   #8055
Alright. I have a bit of a conundrum. I am building my rb6 kit, and haven't built a kit since my original Losi JRX2. I used a regular pair of coarse pliers when building the front turnbuckles, along with a turnbuckle wrench. All of the front plastic pieces are fairly well scuffed from the pliers. Certainly usable, but a little bit ugly. I subsequently build the rears using a wrench on the plastic parts. They turned out beautifully! Now. Do I give in to vanity and go back and rebuild the fronts with new plastic pieces? I can always use the current ones as back ups.
Kevin
kes7u is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
