    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-28-2013, 11:26 PM   #8011
Teambcw's Avatar
Trader Rating: 28 (100%+)
Originally Posted by NitroLuver View Post
buggy felt great tonight @ oc/rc second place in stock buggy in it's first race:
http://www.liverc.com/view_result_fi...y_(A_Main).xml
You were moving to hang right behind Jason and stay in front of Daniel. Great job!
Quick question, what's your buggy weigh?
OCRC / C$ race setups ...... And my Wife
Teambcw is offline   Reply With Quote
Old 08-29-2013, 12:00 AM   #8012
Trader Rating: 44 (100%+)
thanks and honestly I have no idea.. and it's a SP Reventon Pro...works great
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-29-2013, 04:07 AM   #8013
steam's Avatar
What set up are you running?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 08-29-2013, 06:21 AM   #8014
jk3
Default Buying RB6
Hey guys I'm buying an RB6 today and was wondering what else I should order with the kit springs etc.. I run on an indoor med grip ..Thanks any help would be appres..
jk3 is offline   Reply With Quote
Old 08-29-2013, 06:33 AM   #8015
wild gopher's Avatar
Trader Rating: 39 (100%+)
Maybe some gold rear springs, kit pinks are good for front. I would also suggest looking at Exotec upgrades although not mandatory
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 08-29-2013, 07:04 AM   #8016
my own currently and it isn't much haven't really started dialing the car in
I run long front camber links, med. length rear camber links, losi #54 pistons all the way around w/27.5 and 25 wt oils, wide hanger, middle hole on the tower in the front and third hole in on rear tower outside hole on both front and rear a-arms, 23/24mm ride height, -1.5 camber all the way around. The car is pretty twitchy with tons of steering. I am going to work on trying to lock the rear in a bit more though
T5M 7.5
22 3.0 7.5
Old 08-29-2013, 07:15 AM   #8017
jk3
Default New RB6
Does the narrow rear susp arm holders give rear end more grip
Old 08-29-2013, 07:25 AM   #8018
jkirkwood's Avatar
Here's what's on my car but you absolutely do not need all this stuff for the car to be good. I've changed stuff slowly, out of boredom. The first things I would buy would be Gold rear spring, Aluminum Steering Rack, and the new aluminum adjustable rear hangers.
  • Avid Shock & Turnbuckle Tool (AV1040)
  • Avid Slipper and Avid Top Shaft (AV1020-STK + AV1020-TOP-KYO), note: I run 76t in mod
  • Avid Kyosho HD Long Rear Axle (AV1041-AXLE)
  • Lunsford "Punisher" Kyosho Ultima RB6 Titanium Turnbuckle Kit (6) (LNS2687)
  • Avid Pistons (1.7x2 : AV1030-2x1.7-F, 1.6x2 : AV1030-2x1.6-F, 1.3x4 : AV1030-4x1.3-F, 1.5x2+1.1x2 : AV1031-1.5-1.1-F), note: if you run Avid pistons you will want some shims to shim out up and down play as a Kyosho piston is a little thicker. .1-.2mm. GHEA is direct fit but I typically don't like conical pistons so I have not tried them.
  • Exotek or Kyosho Alum Steering Rack (1258BLK, KYOUMW701)
  • Exotek Rear Camber Block (1279BLK)
  • Kyosho RB5 Front Hexes and Axle
  • Kyosho RB5 Rear Arms (KYOUM521-1), note: you need qty 2 to make a pair.
  • Kyosho V2 Aluminum Rear Hub Set (0) RB6/ZX/RT/SC (KYOUMW704-0)
  • Kyosho Big Bore Blank Shock Piston Set (2) (KYOW5303-08), note: you need qty of 2 to make a set of 4.
  • Kyosho Aluminum Adjustable Rear Hangers
    - UMW705+UMW706 for rear motor
    - UMW705+UMW707 for mid motor
  • Kyosho Derlin Suspension Bushings (KYOLAW32)
  • Rear Springs White KYOXGS012 Gold KYOXGS013
What's the name of your local indoor track?
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 08-29-2013, 09:23 AM   #8019
jk3
code3 rc Ive been running the losi 22 dont like it and dont really want to give the 2.0 a try I would rather just go with the RB6... I still have 2 orig ultimas that I got when they came out in late 80's... but anyway I was just wanting help with this car cause nobody at my local track has one I mainly just want to know what I need when I get this car to start out,just like I heard alot about the rear gold springs
Old 08-29-2013, 10:06 AM   #8020
I didin't upgrade because I couldn't afford to but the suspension hangers in aluminum and the steering rack as well for increased durability. My car is all stock for now but I will go to these parts in the future
T5M 7.5
22 3.0 7.5
Old 08-29-2013, 10:57 AM   #8021
carbons2k's Avatar
Trader Rating: 21 (92%+)
Honestly I think the only thing you need is the Kyosho steering rack and some .5* hubs. If you search you can find plastic hubs in .5*.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-29-2013, 12:09 PM   #8022
jk3
When you say kyosho steering rack is it an sliding rack sim. to losi...and it comes with a bell crank sys. correct me if Im wrong I just want to know what you mean when you say rack and do you mean .5 deg rear hubs
Old 08-29-2013, 12:33 PM   #8023
MikeXray's Avatar
Trader Rating: 73 (100%+)
Its stock rack, just in aluminum, not plastic, the stock one is a little fragile, not bad, but most replace it so they don't have to worry about it.
Yes .5dg rear hubs, I tend to run them everywhere, even on high grip.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-29-2013, 12:35 PM   #8024
jk3
Are those .5 toe
Old 08-29-2013, 03:56 PM   #8025
I have run the car since October last year in mod and yet to break anything including the plastic rack.
I run, gold rear spring, aluminum rear suspension holders, white bushing for said holders. For spares keep a $6 plastic steering rack and plastic rear hubs.
Enjoy your car.
Tom87 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Cmgreen
