    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 08-28-2013, 11:58 AM   #7996
carbons2k's Avatar
Trader Rating: 21 (92%+)
Originally Posted by Cpt.America View Post
Really? It sure looks like you are using the kyosho slipper plates to me. You can tell because they are larger than the outer circumfrence of the pads. That means that the slipper plate will actually be sitting up against the plastic of the gear, instead of the slipper disk. It will work for a week or two, but as soon as slipper pad starts to thin out, you will run into trouble.
The slipper plate needs to sit on the slipper pad, 100%.
Theyre AE pads for sure. You can see them pads in the 1st pic. Im running 17.5 and AE is the only company (that ive seen) that has a 69t spur. I run my slipper locked anyway. Id like to use the kimbrough spur but not sure what id need to make it work in my Rb6
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-28-2013, 12:01 PM   #7997
Avid has a 69 if their slipper works on the RB6.
Barge is offline   Reply With Quote
Old 08-28-2013, 12:02 PM   #7998
Super Moderator
Trader Rating: 17 (100%+)
I have a shiny new Avid 69 tooth spur in my box. OH and a 66 just for good measure
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-28-2013, 12:05 PM   #7999
carbons2k's Avatar
Im not running the triad slipper tho. I still run the slipper locked down
Tom Licata
Old 08-28-2013, 12:08 PM   #8000
Well if you're looking for more spur gear choices it's a pretty affordable "upgrade"
Old 08-28-2013, 12:44 PM   #8001
My only real slipper issue occurred with a 13.5. I didn't want it completely locked down but wanted to use an AE or Kimbrough 72 and the slipper plates were riding on the plastic retaining ridge instead of the pad itself, as described above by Brandon. My solution to that was to glue two pads together on each side to get the mating surface beyond the plastic ridge. Apparently AE has some extra thick 4x4 pads that will work, too.
Still, if you're switching between mod/17.5/13.5 all the time and having to go to different spurs that Kyosho doesn't offer, it's worth it to get the Avid system IMO... I'll even use a 72 in mod now that I have the Triad when I want to move the motor farther back (mid).
BryanJ is offline   Reply With Quote
Old 08-28-2013, 12:51 PM   #8002
Hey guys...this is the V2 hubs manual I was telling you about:
and the table is on the right...what do you think? Does it refer to traction?
nitroargi is offline   Reply With Quote
Old 08-28-2013, 12:55 PM   #8003
Trader Rating: 16 (100%+)
Send a message via Yahoo to Zach Phillips
The chart on the right just represents how each bearing size differs in weight and durability.
KYOSHO | JCONCEPTS | ORION | SMACTRAC |
Zach Phillips is offline   Reply With Quote
Old 08-28-2013, 02:06 PM   #8004
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Not "pads", ... I said "plates"... the metal disks that squeeze the pads. I understand you are running the AE pads, but what we are telling you is that you can't run the AE pads, with the kyosho plates (or disks)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-28-2013, 02:56 PM   #8005
Super Moderator
I did the exact same thing.. I glued AE pads together. But ultimately, the AE pads are flat out junk compared to either the Kyosho slipper pads, or the avid slipper pads. Night-and-Day difference.
- RCSpecialties -
Old 08-28-2013, 03:07 PM   #8006
Life_livin's Avatar
If you aren't using your slipper why don't you just shed the rotating mass and go to a slipper eliminator and use kimbrough or Robinson spur gears?
Life_livin is offline   Reply With Quote
Old 08-28-2013, 07:54 PM   #8007
carbons2k's Avatar
That's what I'd like to do but not sure what parts I'd need.
Tom Licata
Old 08-28-2013, 08:01 PM   #8008
Life_livin's Avatar
Here is the eliminator, the one for the b4.1 works on the stock rb6 shaft.
http://www.speedysracingparts.com/As...eliminator.htm
Old 08-28-2013, 11:21 PM   #8009
Trader Rating: 44 (100%+)
buggy felt great tonight @ oc/rc second place in stock buggy in it's first race:
http://www.liverc.com/view_result_fi...y_(A_Main).xml
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-28-2013, 11:25 PM   #8010
wild gopher's Avatar
Trader Rating: 39 (100%+)
Great job! Which Speed Passion are you running?
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22955 Today 12:08 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
