    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-27-2013, 12:53 PM   #7981
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Cspurlock View Post
2 deg anti squat is kit standard. In my experience, it has the same effect as RM when you change it.
I have played with weight balance and was actually able to get 65% of cars total weight onto the rear wheels. Yes, I had traction, but the car didn't feel as good as mine does now. IMO after trying one of the team drivers setups where they used a saddle pack pushed all the way back, it was clear that their setup worked better than mine and that getting all that weight over the rear tires, wasn't the only way to yield traction.
2deg. Perfect. That's good to know. Kyosho doesn't make it easy to know. LOL.
Next question on changing anti squat with the mid setup. There's a couple of kit supplied shims that go between the rear arm mount and bulkhead. A .5 and 1mm shim if I remember right. Would you switch that out or, just change the shim on the front arm mount, or both to get the desired degree od anti squat? I'm thinking the easiest would be to just play with the front arm mount shim, but it may not be the correct or only way.
You can pm me that setup to look at if you don't mind. Never hurts to have options to explore.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-27-2013, 12:57 PM   #7982
Originally Posted by ryanpatrickgore View Post
2 biggest things that mady my midmotor setup actually work well...
1. 0.5* hubs installed
2. side pods dremmeled so the shorty could sit sideways all the way against the rear bracce in the back.
i tried different configurations and ended up where your electronics are now.
Might have to play with the .5 hubs. That could be helpful and an easy change to make. Thank you.
Thought about the side ways shorty setup. Wasn't ready to hack up the side pods at that time, but may have to consider doing just that. Did you leave the elec. placement all the way up front like that, or move them back some so there was a little less front weight bias?
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 08-27-2013, 01:01 PM   #7983
Another must have for mid (IMO) are the new adjustable hangers w/ inserts. The narrow settings will lock in the rear a little more.
BryanJ is offline   Reply With Quote
Old 08-27-2013, 01:38 PM   #7984
Saw those,
They're on the list of stuff I want/need. LOL. Be nice if they would just label the inserts as +1,2,3,4 for wide toe in and -1,2,3,4 for narrow of the same thing.
J.Mikoliczyk
ZX6 - RB6 - MP9e
Old 08-27-2013, 01:44 PM   #7985
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I did sideways shorty on my midmotor. My 17.5 rtr is 1524 grams! Way lighter than the RM setup I had on her same electronics thinner wire though (but thats maybe 5-10 grams). Will run it this weekend. The weight balance changes a lot compared to the inline mid motor. The CG went behind by a 3/4 inch rough estimate.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 08-28-2013, 06:18 AM   #7986
carbons2k's Avatar
Trader Rating: 21 (92%+)
at first I was like...
then I was like...
now Im like...
Rebuilt my RB6 from a new kit. Only think I reused from my old car were the shocks and the diff since I rebuilt them only 4 days ago.
All new upgrades added too.
Includes:
Kyosho steering rack
Kyosho V1 .5* hubs
Kyosho rear pivot blocks with inserts
Kyosho Titanium screw kit
Kyosho vented slipper discs
Kyosho vented motor plate
Kyosho RB5 front axles
KO Propo Rsx servo (the KO aluminum servo arm doesn't fit the RB6)
I cant wait to get my new motor and solder this up! Orion R10 paired up to a D3.5 17.5 Maxzilla. (may try the LRP Flow)
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-28-2013, 06:29 AM   #7987
MikeXray's Avatar
Trader Rating: 73 (100%+)
then I was like...
now Im like..Rebuilt my RB6 from a new kit. Only think I reused from my old car were the shocks and the diff since I rebuilt them only 4 days ago.
Includes:
Kyosho V1 .5* hubs
It looks like you are using a AE spur and pads with the stock Kyosho plates, this can cause issues since the plates are a bit too big and hit the plastic groove holding in the pad before hitting the actual pad. Grab a avid topshaft and B4 plates.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-28-2013, 06:39 AM   #7988
carbons2k's Avatar
I have the AE slipper and pads. Ive had them in the car before and never had an issue. If it starts to bother me Ill swap it out. Thanks for the heads up
Tom Licata
Old 08-28-2013, 07:14 AM   #7989
Super Moderator
Trader Rating: 17 (100%+)
boy you got a purty mou..... oh wait. Nice looking rebuild
I'm expecting a huge box o goodies today.....
#hugeakatireorderftw!
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-28-2013, 07:21 AM   #7990
carbons2k's Avatar
What.... no slicks?
Tom Licata
Old 08-28-2013, 07:42 AM   #7991
Super Moderator
What.... no slicks?
you can keep your slicks!
Old 08-28-2013, 07:50 AM   #7992
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Hack em up there only 10$ and it makes a huge difference.(all the way to the rear). Kept all te electronics up front but you can put them in a perfect line because now you have so much more room with the batter sideways. Looks super clean too. No need for the battery braces either just the posts. The side pods will now hold it in place from shifting around.
ryanpatrickgore is offline   Reply With Quote
Old 08-28-2013, 11:06 AM   #7993
carbons2k's Avatar
are there any benefits to running a gear diff over a ball diff?
Tom Licata
Old 08-28-2013, 11:22 AM   #7994
Super Moderator
durability and less maintenance once set.
Old 08-28-2013, 11:23 AM   #7995
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Really? It sure looks like you are using the kyosho slipper plates to me. You can tell because they are larger than the outer circumfrence of the pads. That means that the slipper plate will actually be sitting up against the plastic of the gear, instead of the slipper disk. It will work for a week or two, but as soon as slipper pad starts to thin out, you will run into trouble.
The slipper plate needs to sit on the slipper pad, 100%.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
