    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 08-23-2013, 07:57 AM   #7966
carbons2k's Avatar
Trader Rating: 21 (92%+)
Originally Posted by jkirkwood View Post
To make a gear diff for the RB5/RB6,you need the:
  • Kyosho UM605 Diff Gear Set
  • Kyosho UM610 Diff Bevel Gear Set
  • Kyosho UM611 Diff Case Packing
  • Kyosho UM612 Diff Shaft
  • Kyosho ORG045S Silicone O-Ring
If you want you can use steel bevel gear set:
  • Kyosho V-OneR4 Steel Diff Bevel Gear Set, VZW424
Source petitrc.com
looks like the pins to hold the gears are missing.....
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-23-2013, 09:04 AM   #7967
jkirkwood's Avatar
My apologies. Most the time [email protected] is very complete with his lists. I didn't double check it. Looks like others parts are missing as well according to this list:
http://www.tsrproducts.com/index.php...41-c-1446.html
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 08-23-2013, 03:04 PM   #7968
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
thank you
Kyosho SP Front Suspension Plate Type-B (UM721)
Type B is what you want if you want to keep it stock according to the exploded view. It's the only part I seem to have to maintain. I've never broke it, but overtime it seems to warp/bend, giving a bit of toe-out to the inner hinge pins.
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 08-23-2013, 03:13 PM   #7969
asc6000's Avatar
Trader Rating: 15 (100%+)
The front suspension mount block is a good place to use Aluminum.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 08-26-2013, 10:51 PM   #7970
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Got to get out for a little practice with the mid motor setup,
Overall, I'm pretty pleased. Car felt predictable even with the rear wanting to step out if traction wasn't up. It was a bit of a handful then, but carried a ton of corner speed.
Track is what I would call more along med. to maybe med-high traction for race days, and could be that or almost dry and loose feeling on a practice day (depending on how many are out for practice and/or how much it gets watered). Tire sauce is usually used for the best traction when the track is just wet to damp and the tires are broke in. When new or not running sauce, can add to the variables to account for when/if needing more or less traction.
Having never driven a mid motor setup and knowing that the local indoor track may not be the most ideal time to run a mid motor setup, I do think it could work pretty well and of course in the right hands, though many may prefer a more standard rear motor setup.
Now I have some questions that hopefully those that have played with a mid motor setup can help with;
Does any one know what amount of anti squat is built in to the mid rear end if built to the kit manual specs? Looking to know which way to go should I need to make a change for that.
Does a mid motor setup react the same as a rear motor setup would when making anti squat changes? For some reason I'm thinking that it may not.
My current mid motor setup has the rx and esc right behind the servo and then the shorty pack. I wanted to put the esc in the back like I had it on the rear motor setup, but couldn't make it work the way I wanted, so I'm pretty sure I have a little more front weight bias. Which isn't a total bad thing as the 2wd now feels a lot like my wheeler does when I have the most traction I can at the local track, but I'm thinking that I may need some weight added towards the rear when traction isn't as high.
Has or does anyone that run a similar elec. placement, use or add any weight rearward? I'm thinking about maybe adding a 1/2 oz. to help rebalance the car and give it just enough rear traction for when traction isn't as high.
I think that's about it for the mid questions. Sorry if they've been asked before, but didn't seen much mentioned that I felt would give me the answers I was looking for. Thanks for any help.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 08-27-2013, 06:59 AM   #7971
Hey guys....I was reading the instructions for the new V2 hubs, what's the story with the table on the right??
Are these bearings suggestions for low/high traction tracks??
nitroargi is offline   Reply With Quote
Old 08-27-2013, 08:44 AM   #7972
In that configuration, for medium to low traction, I've been running 14g on EACH side of the shorty pack, stuck to the side pods and moved back as far as possible. Then I play around with different amounts of weight on the rear bulkhead, up to 20g or so. So almost 50g added in the rear half of the chassis. You could also try saddles. My final weight usually varies between 1640-1680g. Also, the battery is only about 1/8" on front of the motor.
That's for mod buggy, FWIW. I probably wouldn't add any weight for 17.5.
BryanJ is offline   Reply With Quote
Old 08-27-2013, 08:47 AM   #7973
Trader Rating: 31 (100%+)
2 deg anti squat is kit standard. In my experience, it has the same effect as RM when you change it.
I have played with weight balance and was actually able to get 65% of cars total weight onto the rear wheels. Yes, I had traction, but the car didn't feel as good as mine does now. IMO after trying one of the team drivers setups where they used a saddle pack pushed all the way back, it was clear that their setup worked better than mine and that getting all that weight over the rear tires, wasn't the only way to yield traction.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 08-27-2013, 09:02 AM   #7974
The Fabulous One has got mid-motor figured out!
Old 08-27-2013, 09:03 AM   #7975
Frank L's Avatar
Trader Rating: 148 (100%+)
So what setup did you use?
???? What setup are you running???
Old 08-27-2013, 09:11 AM   #7976
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
2 biggest things that mady my midmotor setup actually work well...
1. 0.5* hubs installed
2. side pods dremmeled so the shorty could sit sideways all the way against the rear bracce in the back.
i tried different configurations and ended up where your electronics are now.
ryanpatrickgore is offline   Reply With Quote
Old 08-27-2013, 09:15 AM   #7977
I am not using a setup that is posted anywhere, if you want it PM me your email and I will send you a setup sheet.
MBX6-ECO, B5m
Old 08-27-2013, 09:16 AM   #7978
I was referring to Barry Baker. He's been ballistic with a mid RB6.
Old 08-27-2013, 12:00 PM   #7979
This thread has to few video clips. Here is a lap on my local track. Tried midmotor on the track for the first time and did 0.1 seconds better than the track record that I had set previously with rear motor. In the clip i ran 0.3 seconds slower than the track record for 2wd.
+ YouTube Video
daniz is offline   Reply With Quote
Old 08-27-2013, 12:47 PM   #7980
Interesting. As that was a fair amount of more weight than I was even considering, but thank you for the info. For sure more things to ponder as I get into the mid setups more.
J.Mikoliczyk
RB6 - MBX7R Eco
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Gayosaka
