    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 08-21-2013, 08:28 PM   #7951
spdrac430's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to spdrac430 Send a message via Yahoo to spdrac430
he ran the carbon front tower because its cool.. or because sugar tracks are such high bite the plastic flexes to much and takes away some responsevness
Tekno, Kyosho, SMC-racing.com, AKA, Avidrc.com, Futaba
Trick Graphics
Heart of a Hustler Racing Team
spdrac430 is offline   Reply With Quote
Old 08-21-2013, 08:31 PM   #7952
spdrac430's Avatar
are people getting both UMW705 and UMW706 or are they just getting the rear one need to make an order
Trick Graphics
Old 08-22-2013, 12:31 AM   #7953
You should get both, and if you're planning on running mid motor at some point, you would need UMW707 as well.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 08-22-2013, 06:55 AM   #7954
carbons2k's Avatar
Trader Rating: 21 (92%+)
Dialed RB6 right here! Chassis has a slight wobble in it and rear hinge pins were tweaked so I decided to rebuild from the ground up and getting a ton of upgrades! Kyosho steering rack, hubs, vented slipper plates, vented motor plate, Lunsford titanium turnbuckles, titanium screw kit, new hinge pins, all new bearings and will be rebuilding it in mid motor. Also debating on a new servo... perhaps the KO 30102. its gonna be a loooooooong week!
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-22-2013, 07:25 AM   #7955
tef
Originally Posted by jkirkwood View Post
You will be able to do that. Actually there is 3 width possibilities between the narrow and wide aluminum hangers. Plus you can go even narrower and wider than those hangers.
Linked below are the instructions that are included in the hangers. Note the reference section in the middle of the page, to get the settings to mimic the narrow and wide hangers you typically use.
http://www.petitrc.com/setup/kyosho/...5UMW706UMW707/
Actually there is 7 track width positions. The RR dictates the width in most cases and the RF dictates the toe angle. the "A" is the middle setting and then you have 3 narrow or 3 wider.
Thanks to my sponsors Kyosho America*O.S. Engines*TrakPower*Pro-Line Racing*Futaba*O'Donnell fuel*Team Scream Racing
tef is offline   Reply With Quote
Old 08-22-2013, 08:19 AM   #7956
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
he ran the carbon front tower because sugar tracks are such high bite the plastic flexes to much and takes away some responsevness
The shocks don't really bend the shock towers, they push up towards the top mounting holes, and when the springs pushes down, they pull pressure away from the top mounting holes.
Are you saying that the factory plastic piece stretches and contracts as the shock puts vertical pressure on the mounts? I would think that the shock tower's tensil strength is actually pretty high. (relatively speaking, of course)
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-22-2013, 08:23 AM   #7957
jkirkwood's Avatar
Yes 7 total but Bob asked, "so there are more than just the std wide and narrow? Interesting. I would like to run a setting that's in between." Thus there are 3 positions (In-B, A, & Out-B) between the the positions traditionally provided the UMW511+UMW512 or UMW514+WMW515 aluminum hangers.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 08-22-2013, 05:13 PM   #7958
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
looking to buy the Kyosho Front Suspension Mount Block. can anyone help with A,B and C? I don't know what I have on my car but the one it came with thanks!!!
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 08-22-2013, 08:55 PM   #7959
tef
I tried the Avid 4 hole pistons tonight and other then the fact they fit the shock shafts like a donut on a pencil they work great. FYI to anyone considering them that they need a shim to take up the slack....
Old 08-22-2013, 09:03 PM   #7960
Life_livin's Avatar
Trader Rating: 16 (100%+)
Its best to just go with the Ghea pistons, they are a perfect fit and worth the few extra bucks.
Life_livin is offline   Reply With Quote
Old 08-22-2013, 09:06 PM   #7961
Super Moderator
x2
The Gheas are precision cut, tight fit, zero slop. Can't go wrong. (they are a little pricy though)
- RCSpecialties -
Old 08-23-2013, 05:37 AM   #7962
jkirkwood's Avatar
Kyosho SP Front Suspension Plate Type-B (UM721)
Type B is what you want if you want to keep it stock according to the exploded view. It's the only part I seem to have to maintain. I've never broke it, but overtime it seems to warp/bend, giving a bit of toe-out to the inner hinge pins.
Old 08-23-2013, 05:46 AM   #7963
hairymuffin's Avatar
Trader Rating: 93 (100%+)
is the avid top shaft a direct replacement? I am running the stock slipper
hairymuffin is offline   Reply With Quote
Old 08-23-2013, 05:53 AM   #7964
Default Gear Diff
has anyone the part numbers to convert to a gear diff?
florianlaux is offline   Reply With Quote
Old 08-23-2013, 06:07 AM   #7965
jkirkwood's Avatar
DETERMINED TO BE AN INCOMPLETE LIST
To make a gear diff for the RB5/RB6,you need the:
  • Kyosho UM605 Diff Gear Set
  • Kyosho UM610 Diff Bevel Gear Set
  • Kyosho UM611 Diff Case Packing
  • Kyosho UM612 Diff Shaft
  • Kyosho ORG045S Silicone O-Ring
If you want you can use steel bevel gear set:
  • Kyosho V-OneR4 Steel Diff Bevel Gear Set, VZW424
Source petitrc.com
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
