Kyosho Ultima RB6 & RB6.6 Car Thread
#7936
Just installed the new aluminium rear hangers, made a massive difference to removing the slop in the rear end, the only slop I have now is from the aluminium hub carriers (or to be more precise the bearings, can wiggle the wheel and see the axle move about a bit).
They are also 3g heavier than stock if anyone was curious.
#7938
#7940
I have the old hangers. I have wide and narrow in alum so I figured really had no reason to get the new ones. Did I miss something that was different with the new ones? Are there more options than the std wide / narrow?
I better go look at the first post!
#7941
LOL I had no idea it was that much I would tend to agree that's a bit excessive.
#7943
Linked below are the instructions that are included in the hangers. Note the reference section in the middle of the page, to get the settings to mimic the narrow and wide hangers you typically use.
http://www.petitrc.com/setup/kyosho/...5UMW706UMW707/
#7944
You will be able to do that. Actually there is 3 width possibilities between the narrow and wide aluminum hangers. Plus you can go even narrower and wider than those hangers.
#7946
Yeah, the new ones are great, and much cheaper since you only need 2 hangers instead of 4 for narrow and wide and as already mentioned, get much more adjustment.
I'm assuming, combined with the V2 hubs aswell that the idea may be to not have toe adjustment in the hubs but in the hangers?
#7947
hey any of you guys have any idea if this body is both mid motor AND rear motor capable?
http://prolineracing.com/bodies/bull...lear-body-rb6/
#7948
#7949
