Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 08-19-2013, 06:38 AM
  #7906
A lighter car is an edgy car if you are looking to run stock focus on dropping weight on the drivetrain. You will have much better results overall. My car weighs in at 1578 and its plenty fast in the stock class.
Gitsum is offline
Old 08-19-2013, 06:45 AM
  #7907
Trader Rating: 22 (100%+)
Originally Posted by jkirkwood
Avid rear axles,
Hey I was looking at these and considering grabbing a set. I have all Kyosho rims though and I saw you have to open them up some. Do you know how much you have to open it? I don't want to sit there and hack up 10 pairs of rims.
Bob Barry is offline
Old 08-19-2013, 06:48 AM
  #7908
That's pretty much right where I will end up.
Old 08-19-2013, 07:08 AM
  #7909
jkirkwood's Avatar
Sorry, I only use AKA rims, those fit with zero modification.
jkirkwood is offline
Old 08-19-2013, 07:19 AM
  #7910
ok thanks,
Old 08-19-2013, 08:32 AM
  #7911
Trader Rating: 31 (100%+)
Can you list what you can do to lighten the drivetrain?
Cspurlock is offline
Old 08-19-2013, 08:59 AM
  #7912
Trader Rating: 101 (99%+)
Using a good reamer, it only needs (approximately) 0.5mm taken out of both sides to get the Kyosho wheels to fit snugly onto the axles.
desertracerdad is offline
Old 08-19-2013, 09:00 AM
  #7913
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Default Setup q.
Brandon,
I am running your setup except for 27.5wt in the rear and the 25* block position rather than the 30*. Same old tires and inserts as everyone. The track was good it was after the Sunday mains I even swept it a few times.
Yesterday the car felt good but seemed to push on power sometimes, other times low speed and off power it hooked and had crazy amounts of steering. Twitchy and punishing me. Half way through the sweeper it would sometimes just hook up and dart. Other times it pushed wide.
Could this behavior be from running with the 25* rather than the 30* ?
I am searching around but hard to find the answer. I know you have tested with this.
ryanpatrickgore is offline
Old 08-19-2013, 09:03 AM
  #7914
Trader Rating: 19 (100%+)
I ran a full size stick pack (85g heavier than the turnigy shorty), so my total weight would have been around 1605g and the handling I thought turned to crap (not that I'm much good anyways).
Going into corners just felt a bit slower and seemed to want to push/slide a lot more.
I didn't change anything besides the battery which could explain part of it but, I really didn't like it.
It seems the Turnigy's and Venoms are the lightest shorty lipos available aswell (about 189g).
Revolectrix's and a couple of other brands are around 205g but seems most are about the 215g area.
Shimmy is offline
Old 08-19-2013, 09:07 AM
  #7915
There isnt a ton you can do....
Avid top shaft
Avid slipper
Freer bearings in the tranny and make sure everything spins free. If you know someone who can machine for you or if you are skilled with a dremel you can lighten the outdrives etc...
Gitsum is offline
Old 08-19-2013, 09:10 AM
  #7916
Originally Posted by ryanpatrickgore
Brandon,
You can try moving your battery all the way forward.
Gitsum is offline
Old 08-19-2013, 09:56 AM
  #7917
silveraider14's Avatar
Originally Posted by silveraider14
where you mount the camber link upfront changes camber gain correct? which way is more camber the outside hole?
anyone?
silveraider14 is offline
Old 08-19-2013, 09:58 AM
  #7918
steam's Avatar
I am using his set up at the moment and it pushed a bit, I stood up the front shocks on the tower, and went to s more aggressive front tire and felt pretty good, and that's with the 30 degree block. Was running clay handlebars, changed to suburb front.
steam is offline
Old 08-19-2013, 10:29 AM
  #7919
Thanks. I think I'll grab a set of them for the indoor season. I was going to order AKA tires anyway, guess I'll just get premounts and save myself the headache of gluing them. I'll save my existing rims.
Anyone know if I'll have to ream out JC or Proline rims if I needed to use them?
Old 08-19-2013, 10:32 AM
  #7920
anyone?
I think it's the shorter the link, the more camber gain.
