    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 08-14-2013, 12:08 AM   #7861
Trader Rating: 44 (100%+)
Originally Posted by Teufel Racing View Post
That's what I put on mine Works good and fits like it was supposed to be there
yes this works, I have one on mine as well
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 08-15-2013, 12:05 AM   #7862
Life_livin's Avatar
Trader Rating: 16 (100%+)
Awesome! Thanks guys I would have hated to spend $7 on a useless parts tree just for those plastic washers.
Life_livin is offline   Reply With Quote
Old 08-15-2013, 02:01 PM   #7863
stiltskin's Avatar
Trader Rating: 102 (100%+)
Just bought my second RB6 and realized that I've never run either one of them with a full size pack. Any opinions on the differences between shorty and full packs in this car?
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 08-15-2013, 04:11 PM   #7864
carbons2k's Avatar
Trader Rating: 21 (92%+)
I've tried the full pack when I first built the car, I find that with the shorty pack the car will jump better and will corner better too. I think with the full pack... The car is too heavy.
Tom Licata
*JConcepts*Devil Spit*
carbons2k is offline   Reply With Quote
Old 08-15-2013, 04:22 PM   #7865
silveraider14's Avatar
i got the kyosho rebuild kit and the diff balls don't go into the gear at all. they just sit on top of one side. is that normal?
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 08-15-2013, 06:26 PM   #7866
steam's Avatar
No, they go in the gear
Who's rebuild kit?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 08-15-2013, 07:07 PM   #7867
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
hahahaha
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 08-15-2013, 09:57 PM   #7868
I figured it out right after I posted it lol and it was the kyosho rebuild kit.
what should gearing be on a 7.5? I will probally turn it down to around 85% since its a pretty small track.
Old 08-15-2013, 10:43 PM   #7869
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 08-15-2013, 10:50 PM   #7870
^alright thanks!
Old 08-15-2013, 11:11 PM   #7871
Guest
Send a message via Yahoo to kyoshoracer77
Default rb6
I am getting a new rb6 at the end of the month.
what spares do I need
what do I need to replace befor I race it
and what up with the rb5 front alxes and hex hud in the front instead of the stock rb6 front alxes/hex??
where do I find the 4 hole 55 shock pistons?
kyoshoracer77 is offline   Reply With Quote
Old 08-16-2013, 04:57 AM   #7872
Super Moderator
Trader Rating: 17 (100%+)
Has anyone run tapered 4x1.3 (55) vs reg 4x1.3 (55)? Which did you like better and why? What was the track like that you tested on?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-16-2013, 05:07 AM   #7873
Guest
part is the part number on them???? or are they custom drilled pistons??
Old 08-16-2013, 07:22 AM   #7874
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Kraig: Things that have carried over to this car from previous generations that people have replaced are, rear hubs and rear hinge pin carriers. While I have been fortunate in not needing to replace these items others will say they broke them. Your experience will vary with these parts.
The new rear hinge pin carriers allow you to adjust rear toe and overall rear width of the car. See post #1 for what changing the width does. If you do purchase some bling definitely go with these.
Kraig: the only thing in addition to the above items you may want to look at the steering rack. While I haven't broken a plastic piece I have purchased the aluminum piece from Exotek and Kyosho and have not had an issue since with them. They very well could have made changes to the mold for this piece but I haven't kept up on that.
Kraig: Nothing really. Jared runs them but I haven't had the opportunity to ask him why. I think one thing this does is that it allows you to run non-Kyosho wheels without the wheel actually rubbing on the steering knuckle. Then again I could be completely wrong and people will correct me.
Kraig: the 4 hole 55 piston is a Losi shock piston. You have to buy their bag of pistons to get what you need.
Now if you have your own set of drill bits you can pickup these, KYOW5303-08. These are blank pistons and which allow you to drill your own size. These have little dimple marks in them to help keep the drill in one spot as you drill your holes.
I answered your questions above.
One thing to keep an eye on his the front hinge pin brace. If you take some hard or have some weird landings it may bend. They did redesign this part and the new ones have a line in them right in the middle. I don't know if this new part made it into the kits or not but the part number is KYOUM720B.
Have fun!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-16-2013, 07:31 AM   #7875
Super Moderator
Kraig's Avatar
GHEA makes some tapered 4x1.3 size pistons, GHEA8114.
Associated has some tapered ones too, ASC91350.
As for flat/regular ones, obviously Losi has them which is part of the shock piston package for their 22 line of cars. The Losi ones are thin so they will move up and down on the shock shaft in between the e-clips.
Associated has some flat ones as well, ASC91353.
You could get some Kyosho blank pistons and drill your own too. Although they are not tapered like the others but are not exactly flat either, KYOW5303-08.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
