    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 07-31-2013, 07:39 PM   #7771
gelshocker's Avatar
Maybe just me but I switched from gull wings to 521-1 arms on a low traction surface and was faster. Medium shock ends fully screwed in equates to around the same droop as gull wing Japan setup (eyeballed).
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-31-2013, 08:55 PM   #7772
Trader Rating: 19 (100%+)
Anyone else run the Jconcepts body?
I've had mine for a few weeks now (some practice and a race day) and it's already stuffed.
Cracked across the front and a bit in the back.
Another race day or 2 and it'll be in 2 pieces and torn up.
Shimmy is offline   Reply With Quote
Old 07-31-2013, 09:29 PM   #7773
Originally Posted by seth556 View Post
From my experience and it goes with what Tebo said, the flat arms will keep the car more flat while the gullwings had the car still leaning over when I was ready to power out of the corner. So for a loose track the gullwing is probably better since it'll give more traction. While on a higher bite track the flat arms will have the car square up faster out of corners.
Last night I took my RM RB6 to a really fast flowing astroturf near Athens and I tried many setup changes just to see how my base setup will react. Among other things I tries the 521 arms and I must say that the feeling is like you describe...they help the car square up better coming out of the corners without loosing speed in high speed corners. It fet like using sway bar at the back in a way...
Of course I tries to keep everything else equal to understand the change...put the medium ball ends, went to the same droop at the back as the stock arms and play around with the wheelbase to get the same overall feeling in that particular track. To me for this high grip surface at that particuar day this setup made the car easier to drive.
Also tried the RB5 front axles with 25 degrees caster and wide front end and the car was steering as aggresive as my previeus setup with 29 degrees caster and narrow front end. Now the steering was more linear throught the turn and I had time to make adjustments to my input...same steering "slower" reaction in input
nitroargi is offline   Reply With Quote
Old 07-31-2013, 09:41 PM   #7774
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I was told earlier, than the 521-1s added droop relative to the hub. I ran them just because, but lately have had a pro tell me the 521-1 lack the grip the stock arms provide. Ive started running the stock ones on my MM car with C-in to get the rear end to grip more. So far its been pretty good, and I think the stock arms should be the base for sets vs the 521-1s because I think can work better universally.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-31-2013, 09:43 PM   #7775
joecool's Avatar
I have tried both arms on my RB6. I really like the flat 1 hole arms best. However I'm running on carpet this summer and just bought the rear sway bar kit. Despite my best efforts I could not get the sway bar kit to mount up to the flat arms so I switched to the stock gulwing arms. The sway bar is a pretty neat option to use on really high bite with mid motor.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 07-31-2013, 11:25 PM   #7776
K_King's Avatar
Originally Posted by Sterlzy View Post
Hey K_King What weight diff oil do you run in your gear diff? Our track is medium traction, bumpy, with a slight layer of dust on top, Dry.
I dont run a gear diff
Old 07-31-2013, 11:55 PM   #7777
Guys don't get me wrong...
I am not saying the flat arms work better than the stock ones...I am just suggesting that if you run on high grip surface with traction taken out of the setup equation flat arms are like running sway bars in RM configuration
My next test will be to run MM in that astroturf track!
Old 08-01-2013, 06:56 AM   #7778
gelshocker's Avatar
I ran the bulldog but no more. Both sides at the back ripped along the edges. Less than 10 practice sessions. The Blade body under same abuse holding up fine.
Kyosho RT5 | RB6
Old 08-01-2013, 07:13 AM   #7779
jkirkwood's Avatar
I've been running the Finnisher since I had the car for the past 3-4 mo. No issues. However I only use the front clip and then Velcro on the sides near the rear.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 08-01-2013, 07:42 AM   #7780
http://www.rctech.net/forum/newreply...ply&p=12404015
Hmm, I spose it could have been how I cut it (right on the line), might need more material left or move the corner up along further.
I have mine on with velcro only.
Also, anyone else run the Avid slipper?
I'm finding after the first couple of laps it kinda loosens up a bit and needs tightening.
Might just need a new nut though.
Hmm, I really didnt like the look of the bulldog, but kinda interesting that it has a similar issue aswell.
Old 08-01-2013, 07:57 AM   #7781
jkirkwood's Avatar
I've ran the Avid slipper since it's release and that's the only fault I've found with the slipper. Each time I've fixed it by just replacing the 3m locknut with a new one and it stays put for few months.
Old 08-01-2013, 08:00 AM   #7782
Yea them nuts suck!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 08-01-2013, 08:11 AM   #7783
skengines's Avatar
Trader Rating: 226 (100%+)
I use Durango lock nuts. Holding up so far.
The PL Bulldog body is holding up so far for me. As long as the nose of the body isn't too tight of a fit between the front shock tower you shouldn't develop cracks.
skengines is offline   Reply With Quote
Old 08-01-2013, 08:58 AM   #7784
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
No, it's not. Changing to the RB5 arms is nothing like running an anti-roll bar.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 08-03-2013, 09:35 AM   #7785
iterator's Avatar
Some mid motor RB6 action from our local track, they look super fun!
+ YouTube Video
Anthony Honstain - rc-stats.com and tweakstation.com
B5M and B44.3 - Reedy Powered
TRCR -Tacoma RC
iterator is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
