    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 07-30-2013, 10:06 AM   #7726
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Johnn27 View Post
I can see from pics on petiterc.com that Hara is running at least 14g in front of the motor. ..
that was also with a shorty.. guys that are running saddles, its probably not necessary.
Sfida
t8rtot is offline   Reply With Quote
Old 07-30-2013, 10:19 AM   #7727
Johnn27's Avatar
Trader Rating: 69 (100%+)
I think I am going to try the shorty sideways. Right now the car is in rear motor configuration with shorty pack and I am not getting the performance out of the car that I want so I am going to try something different.
Johnn27 is offline   Reply With Quote
Old 07-30-2013, 12:14 PM   #7728
t8rtot's Avatar
Work on that setup before you switch, the car is the best or there. Switching mid or rear with a crappy setup won't change anything.
Sfida
Old 07-30-2013, 12:42 PM   #7729
Suspended
Trader Rating: 23 (100%+)
+1 this car is the best of the best.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 07-30-2013, 01:23 PM   #7730
Johnn27's Avatar
Questions??
Well the first thing I am trying is the new hangers and a rear spring change.
Running pink/f and gold/r springs
Right now the car pushes and does not take small jumps well, it nose dives hard. Over large jumps it is fine
Not sure what to do about that so I was going to change the balance of the car. I am running shorty pack as far to the rear as I can get it with the stock battery holder.
Old 07-30-2013, 01:26 PM   #7731
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You have something else going on. If the car is noticeably pushing, you most likely have a tire problem. The first thing you need to do, is restore the natural balance of the car. Running gold springs AND running the shorty all the way to the back, will shift all your traction to the rear of the car. Move that shorty to the middle, and put your red springs back on, and the buggy will transform.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-30-2013, 01:29 PM   #7732
Johnn27's Avatar
I thought maybe I was just getting to much rear traction...
Old 07-30-2013, 01:35 PM   #7733
Super Moderator
yep. that is coming from your setup (or you have a tire issue). But what you don't want to do, is set your car up for maximum rear traction, and then complain that your car is pushy, and move to a MM setup to try and correct. Make sense?
- RCSpecialties -
Old 07-30-2013, 01:38 PM   #7734
Johnn27's Avatar
I am going to try the new hangers and spring change first then.
Old 07-30-2013, 02:21 PM   #7735
Life_livin's Avatar
Trader Rating: 16 (100%+)
Are most of you running saddles with midmotor? Im running my rb6 MM in 17.5 blinky so I have been hesitant to give it a shot due to to the additional weight compared to a short.
Life_livin is offline   Reply With Quote
Old 07-30-2013, 02:39 PM   #7736
You will have to add some weight with a shorty in MM no matter what, 45 to 100g, especially MM.
I run 13.5 and a lighter car is more responsive but can be twitchy. The added weight really help to add a bit or rear lock and finished a setup perfectly.
One thing I noticed after working on RM and MM setups (mostly MM) is how different the front end setup is between the two (25/30 caster, shim/no shim, shock position on wishbone outside/inside), going back and forth require a complete setup change overall, something to keep in mind while going from one to the other.
mojo tom is offline   Reply With Quote
Old 07-30-2013, 03:09 PM   #7737
Super Moderator
And battery position.
- RCSpecialties -
Old 07-30-2013, 03:11 PM   #7738
t8rtot's Avatar
there will be a weight difference, roughly 60g on avg. however 17.5's now have so much power and MM carries so much more corner speed, i doubt you feel a drop in lap times
at 32/69 my car could lift the front wheels off the ground when the track was prepped at 80% throttle so your car has power to spare.. you wont be losing any races b/c your running saddles.. until recently it wasn't even an option.
Sfida
Old 07-30-2013, 03:44 PM   #7739
ryanpatrickgore's Avatar
[QUOTE=t8rtot;12397936]Work on that setup before you switch, the car is the best or there. Switching mid or rear with a crappy setup won't change anything.[/QUOTE
+1
Unless your running on carpet mm is not gonna make you any faster that is for sure...
I only went to midmotor because I was bored and wanted to tune something
ryanpatrickgore is offline   Reply With Quote
Old 07-30-2013, 03:48 PM   #7740
I have been struggling with my car. I run on a tight indoor clay track, that is medium to low traction. When I first built the car the track had good traction, and I was using Capt. Americas set up. The car was great! But now the car is loose at both ends. The B4's have more rear traction, and can turn inside me on every corner. Im running clay compound Suburbs, or Clay Barcodes. But nothing seems to hook up. Ive also used every traction compound I can find. Every one at the track used the subarbs, with buggy grip.
Anyone have a good set up I can try that has lots of grip at both ends I can try
Dale.0 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
