    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 07-28-2013, 08:07 AM   #7696
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Bob Barry View Post
More anti squat will make less weight transfer. I would leave anti alone and adjust droop and springs. Less front droop stiffer rear spring
that does make sense, I already run an extra 1mm under the RF block. Anyone measure if the RB6 arms can extend the wheelbase more than the 521's? I feel like someone told me the 521s equal the middle setting of the 6 stockers. I need a 2nd chassis to keep working on a MM setup
Is ghea the only weighted rb5 front caster block made?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-28-2013, 07:46 PM   #7697
Sterlzy's Avatar
Trader Rating: 29 (100%+)
Hey Guys,
I know this has probably been answered already numerous times, but here goes.
I run the RB6 in MID motor config here in Australia.
Now I have had the problem in 3 of the RB6's that run mid motor,
No matter what we do there seems to be a weird noise coming from the car, anywhere where its under load, ie. Mid sweepers, landings off jumps, sometimes on the upramps of jumps. Now the noise sounds like a bird chirping or like a high pitch bark. We run our diffs really really tight as we thought this was the problem, tightened up the slipper all the way to try and make the diff slip but still no change.
I have tried MIP Diffs, Cermic balls, Carbide balls and even the std steel balls but to no avail. Does anyone know what this could be?
Almost sounds like a gear slipping or something rubbing metal on metal. My thought was even that the diff plates were slipping on the actual outdrive but no wear there also.
If anyone has a clue about this that would be great
Ben
KYOSHO, PROLINE, REDS, MKS SERVOS, KO PROPO, VP POWERMASTER, BITTYDESIGN, PLAIG BEARINGS.
WWW.BENSTERLING-RC.COM
Sterlzy is offline   Reply With Quote
Old 07-28-2013, 07:49 PM   #7698
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by Sterlzy View Post
Hey Guys,
Ben
Mine does too, its the wing against the tire under load. Had a buddy have that same issue and that was the noise.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-28-2013, 07:56 PM   #7699
Sterlzy's Avatar
Thanks K_King, Never thought of that but now that I think about it, it just could well be. When I changed to the Rebar rears it went away, obviously less expansion in the tire therefor less hit against the wing.
Old 07-28-2013, 08:34 PM   #7700
Life_livin's Avatar
Trader Rating: 16 (100%+)
Had the same noise and came to the conclusion of the tire rubbing the wing also.
Life_livin is online now   Reply With Quote
Old 07-28-2013, 08:48 PM   #7701
+1 on the noise, the wing must be in a slightly different position in mid motor.
Tom87 is offline   Reply With Quote
Old 07-28-2013, 09:05 PM   #7702
Trader Rating: 244 (99%+)
Use the jconcepts high clearance wing. No rubbing issues!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 07-28-2013, 09:15 PM   #7703
Life_livin's Avatar
I run the jconcepts high clearance wing and I still get rubbing noise in hard cornering mostly sweepers.
Old 07-29-2013, 04:46 AM   #7704
Super Moderator
Trader Rating: 17 (100%+)
Fred forgot to mention he was using the JConcepts high clearance wing for the TLR 22
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-29-2013, 08:46 AM   #7705
Johnn27's Avatar
Trader Rating: 71 (100%+)
Default Mid engine rear wide suspension mounts
Anyone try these yet? They were just recently released and I am wondering if it is worth converting my car from rear motor to mid- motor with the wide rear mounts? and giving a new set-up a shot ?
Johnn27 is offline   Reply With Quote
Old 07-29-2013, 08:48 AM   #7706
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Can anybody speak about the new exotek midmotor narrow rear hanger.? Looks like it might be a good option to have.
Can this same geometry be achieved with the new kyosho hangers with the inserts? Or are those for rear configuration. Thanks
ryanpatrickgore is offline   Reply With Quote
Old 07-29-2013, 08:50 AM   #7707
K_King's Avatar
Wide is what the mid motor comes with. Narrow would give you more rear bite which instantly makes the new hangers worth it.
Old 07-29-2013, 09:08 AM   #7708
Johnn27's Avatar
When you refer to rear bite are you talking about side bite or just overall rear traction?
Old 07-29-2013, 09:15 AM   #7709
function>form's Avatar
Trader Rating: 43 (100%+)
Are you guys running mid motor outdoors? At family? If so how do you think it will be at bumps?
Josh Medina
Bumps and Jumps rc
function>form is offline   Reply With Quote
Old 07-29-2013, 09:31 AM   #7710
K_King's Avatar
Overall rear traction. I know on the RB5 the wide hangers were a godsend to free up the car after the longer arms, but I think the narrow is going to work better in mid. At least on non high bite tracks.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
