    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 07-25-2013, 04:58 PM   #7681
Super Moderator
Trader Rating: 17 (100%+)
was just curious and weighed my car tonight. 1605 g with out the transponder. That's with a shorty and every aluminum option that kyosho makes. Not too bad with all that aluminum.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-25-2013, 05:13 PM   #7682
Trader Rating: 101 (99%+)
Originally Posted by skengines View Post
What gearing do you guys recommend for a 10.5 motor?
Start at 76/26, should be in the ballpark +\~ a tooth on the pinion.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 07-25-2013, 05:30 PM   #7683
skengines's Avatar
Trader Rating: 226 (100%+)
Thank you sir.
Were you at the Shootout this past weekend? Saw a couple RB6s in Stock, Super stock and mod.
skengines is offline   Reply With Quote
Old 07-27-2013, 11:54 AM   #7684
ColbyRichards's Avatar
Are people running weight under the steering rack or on top of their servo? i remembered today on my rb5 i had a couple lead pieces stashed on top of my front bulkhead and want to know if that is a common placement for weight on the 6? I also asked a few pages back about getting my mid motor to be more responsive in a switch back section and putting the screws back into my side pods was a suggestion, but it only slightly helped out. Any other suggestions?
EDIT: Maybe these could help me out?
http://www.amainhobbies.com/product_...-Set-Mid-Motor
Retired
Last edited by ColbyRichards; 07-27-2013 at 01:04 PM. Reason: added link to sway bars
ColbyRichards is offline   Reply With Quote
Old 07-27-2013, 01:12 PM   #7685
Suspended
Trader Rating: 23 (100%+)
Thank you sir.
I was at the shootout, I saw a lot of RB6's in the stock class not many in SS.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 07-28-2013, 12:18 AM   #7686
Yea not as many as 17.5, in 13.5 three RB6's made the A-Main (2 mid motor, and 1 rear motor) along with five B4.2's, and two 22's. If memory servers me right, there was three RB6's in the B-Main (All rear motor).
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 07-28-2013, 03:13 AM   #7687
skengines's Avatar
Anyone care to explain how to use these adjustable inserts?
Outb/Outb is 3.0 wide but outc/outc also is 3.0 wide.
Old 07-28-2013, 03:25 AM   #7688
Would the Proline velocity wheels be a direct fit with same offsets?
zzztech is offline   Reply With Quote
Old 07-28-2013, 03:54 AM   #7689
1bigshane's Avatar
Trader Rating: 18 (100%+)
Originally Posted by gelshocker View Post
I think the whole purpose of the king pin set for the rb6 is for the 4 bushings. C'mon Kyosho release some delrin steering bushings already
I think the bushings r a big problem! that needs to be delt with. delrin will fix it.
www.rcracechat.net radio show Host
** Pro-Line Racing ** MIP ** TEKIN **
R/C CAR Track Builder
SIK LIDZ Rc Painting
P.I.P Parachute Industry Products.
1bigshane is offline   Reply With Quote
Old 07-28-2013, 04:24 AM   #7690
idbdoug's Avatar
Trader Rating: 33 (100%+)
Hello
Trying to decide between RB6 and B4.2, I mainly run stock 17.5. My main concern with RB6 is the weight difference between RB6 and B4.2? Is the RB6 too heavy for stock?
Thanks for any info
idbdoug
idbdoug is offline   Reply With Quote
Old 07-28-2013, 05:35 AM   #7691
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by idbdoug View Post
Hello
Thanks for any info
idbdoug
Definitely not, car is very good in stock.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-28-2013, 05:48 AM   #7692
Hello
Thanks for any info
idbdoug
You can get down around 1550g easy enough with a shorty pack
Tom87 is offline   Reply With Quote
Old 07-28-2013, 05:50 AM   #7693
MikeXray's Avatar
I ran a 10.5 for the first time on this car, we run slicks and the car was pulling wheelies all over the place. I put 60g up front through out the night, but didn't help enough. Would less squat decrease rear weight transfer? I have the shorty almost all the way forward already.
Old 07-28-2013, 07:20 AM   #7694
Super Moderator
More anti squat will make less weight transfer. I would leave anti alone and adjust droop and springs. Less front droop stiffer rear spring
Old 07-28-2013, 07:22 AM   #7695
Suspended
In the B-Main there was 3, 2 in RM and 1 in MM.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
