    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-23-2013, 09:24 PM   #7666
Jochim_18's Avatar
Originally Posted by Shimmy View Post
Anyone run the Losi Low Frequency springs?
Also, anyone have any issues with slop?
Mine has a bit in the arms and castor blocks.
Although I suspect the rear is in the hangers (going to buy the Exotek hangers soon).
Has anyone used the kingpin kit?
http://www.amainhobbies.com/product_...King-Pin-Set-4
I got the king pin but I think you have to use a different C-Hub...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-23-2013, 09:30 PM   #7667
justpoet's Avatar
Trader Rating: 16 (100%+)
Questions?? Cheat Sheet?
I've looked quickly, and browsed through the manual. I bought one of these used and want to convert it to mid motor from rear motor. Is there an instruction sheet anywhere for converting between the two?
Do I just have to try and take apart the car in reverse manual order and then put it back together the other way 'round? This seems like it'd be much more work than needed due to how soon the manual starts showing differences between mid/rear config in the build.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 07-23-2013, 09:35 PM   #7668
Jochim_18's Avatar
Page 18 is for rear motor assembly. I believe page 28 is for mid motor assembly if I'm not mistaken.
Old 07-23-2013, 10:18 PM   #7669
gelshocker's Avatar
I think the whole purpose of the king pin set for the rb6 is for the 4 bushings. C'mon Kyosho release some delrin steering bushings already
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-24-2013, 02:57 AM   #7670
Trader Rating: 44 (100%+)
Been seriously thinking about picking up one of these to try,hopefully soon I can get one..will run stock for now but mod is in the future as I love the power and the challenge of taming them
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 07-24-2013, 06:16 AM   #7671
celt's Avatar
Originally Posted by KalEl63 View Post
Sorry if I have missed something but can you buy spare screws other than the titanium screws?
I have been looking but cannot find anything
I sometimes go to the expense, and it's not a lot, and build my kits with ProTek 12.9 grade steel screws from Amain Hobbies - or anywhere that sells high grade hardware. Not a plug for Amain by any means, they always carry everything I need.
Great quality for spares and will almost never wallow out like softer material.
Here's an example, so you see what I'm referring to...
http://www.amainhobbies.com/product_...Head-Screws-10
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-24-2013, 07:18 AM   #7672
MikeXray's Avatar
Trader Rating: 73 (100%+)
My local ACE hardware carries SS screws similar to what I get from mcmaster, its usually easier to just go down there an grab a few of the sizes I need instead of ordering boxes of 50 and have tons left over. I use steel for stuff like hinge pin mounts, anything that will see a lot of strees, and SS for the rest.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-24-2013, 09:37 AM   #7673
Trader Rating: 19 (100%+)
Any idea what hubs are needed?
Main reason I would like to get them is to remove some slop and I find easier to adjust.
Shimmy is offline   Reply With Quote
Old 07-24-2013, 10:02 AM   #7674
Super Moderator
Trader Rating: 17 (100%+)
I'm looking to build a second transmission for mid motor just so I can swap entire rears if needed. If anyone has the mid motor parts and wants to unload them, shoot me a PM and let me know what you have. Figured with the influx of guys buying new cars, there may be some unused parts laying around.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-24-2013, 10:17 AM   #7675
skengines's Avatar
Trader Rating: 226 (100%+)
Do the new suspension hangers require the LAW32 bushings?
skengines is offline   Reply With Quote
Old 07-24-2013, 12:47 PM   #7676
Hey guys
Im going to buy the Rb6 in the next days while selling my B44.1..2wd is ( in my opinion) much more fun
I`m racing on a high grip track ( astroturf) in europe. I suppose buillding the rb6 in mid-engine setup would be the best solution ?
What tyres would you suggest? I thought about Schuhmacher stagger in the front and Schuhmacher Minipin/dboots in the rear.
Are there any tyres in the kit?
I would say no, but many shops don`t add them to the "things u need to complete the set"
Im using an LRP SXX competetion2 + LRPk4 8,5t vektor engine. What Gear ratio would you suggest?
wwwmacdannstadtde thats the homepage of the track Im racing on. We do only have 1 long straight. Im atm not allowed to link urls, so if you want to look at it feel free to do so
I am thankfull for any help
cya guys
Ice22 is offline   Reply With Quote
Old 07-24-2013, 09:17 PM   #7677
RacinJacin's Avatar
Default The RB6 Rules in every way.
I am in the US Cali. I tried to look at the track you linked. I didn't find it. The mid motor set up is great on tacky clay and carpet. In Clay I use J Concepts Bar Codes Gold compound soft. I run rear motor also. Not Mid. I have some testing to do with the mid motor set up. This car has no trouble turning at all. The Kit will not have any tires in it. It does come with wheels. For gearing It come stock with an 82 spur if I remember correctly. You might want to start with a 17 tooth check you temp them move up from there. The car will be fast no matter what gearing you try. But you need to gear for run time, temp and Top speed in the straights also.
For stock You want to find the smallest spur gear you can find and go big on the pinion. The motor plate won't let you go big unless you put a 70 spur on it. Or whatever you can find. I think I am using a 71 Associated spur gear. For stock. With the largest pinion I could fit. You can use associated spurs also. You have to buy the slipper pads and thats it.
Also there are some new parts out from Kyosho new rear hinge pin blocks and new rear hub carriers.. Both are way more adjustable. The hinge pin blocks let you widen the car change the toe in and let you narrow the rear if you want.
You might have to call your dealer and have them order them though. They might not be in stock.
The new hub carriers let you choose what bearings you want to use. I use the over sided outer with the stock inner. O degree. I have the .5 deg also.
While you are putting the car together you should put the aluminum steering bell cranks in. YOU wont want to take it back apart after you have it up and going. I have not broke anything but 2 ball cups since I have had this car.
And - NO I DONT WORK FOR KYOSHO.
I just really like the quality of the products.
I hope something I babbled here helped you.
Originally Posted by Ice22 View Post
Hey guys
cya guys
RacinJacin is offline   Reply With Quote
Old 07-24-2013, 09:24 PM   #7678
RacinJacin's Avatar
I might try using the gear dif as weird as that may seem. I have on on my Ultima SC and it is bomb proof.
Hey guys
cya guys
Old 07-25-2013, 02:05 PM   #7679
Hey guys
cya guys
Mid for sure on astro.
Stagger cut low profile on a slim wheel, no insert or foam (but drill two holes on the wheels).
Rear Minispikes Yellow with tubby foam inserts, outer row cut.
You could try later on minipins but it will be way more aggressive.
No rebound on shocks (especially rear) and almost no flap on wing.
The car is awesome on high grip astro (although I'm running small ores and flat RB5 wishbones)
mojo tom is offline   Reply With Quote
Old 07-25-2013, 03:58 PM   #7680
skengines's Avatar
What gearing do you guys recommend for a 10.5 motor?
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Today 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
M3CSLDreamin
