    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-16-2013, 02:07 PM   #7606
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Brutelizer View Post
Just wondering if I need to use a short servo if I'm running rear mount with a straight battery? or will a standard servo have plenty of room?
Straight batt, as in a full size batt?
If so, it'll fit with the standard size servo up front, finding room for everything else may be a challenge. Depending on your elec. equip. that you are running.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 07-16-2013, 02:23 PM   #7607
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by Teufel Racing View Post
Unless that "Pro" just so happens to be also sponsored by MIP as well
They don't want us to use anything but kyosho products unless they ok it first. Pretty cut and dry.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 07-16-2013, 02:28 PM   #7608
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
No. Factory team drivers for Kyosho, MUST have a kyosho car front to back. It's part of their contract. (they might even have to run a kyosho body as well) Maybe Matesa is reading and can confirm? You out there Ryan?
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-16-2013, 02:29 PM   #7609
What up?'s Avatar
Heading out to HRH shootout tomorrow and I made the switch to MM, we will see..
Kyosho Ultima RB6 & RB6.6 Car Thread-img_20130713_181056_735.jpg   Kyosho Ultima RB6 & RB6.6 Car Thread-img_20130713_181024_452.jpg
Josh Mitchell
Old 07-16-2013, 02:30 PM   #7610
Super Moderator
Nice wiring job! A man after my own heart
- RCSpecialties -
Old 07-16-2013, 02:37 PM   #7611
What up?'s Avatar
Thanks Brandon.
Josh Mitchell
Old 07-16-2013, 05:20 PM   #7612
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
im sure this questions been asked 100 times..
but who makes a smaller spur gear that fits this car? kyosho seriously only makes a 82/78/76 tooth gears? i need a 69, what are my options?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 07-16-2013, 05:23 PM   #7613
Using team orion r10 esc.
Brutelizer is offline   Reply With Quote
Old 07-16-2013, 05:24 PM   #7614
What up?'s Avatar
I would go with an avid system if you can afford it if you want the right gearing.
http://www.avidrc.com/product/21/triad-slipper-clutch/
Josh Mitchell
Old 07-16-2013, 05:24 PM   #7615
Life_livin's Avatar
Trader Rating: 16 (100%+)
If you swap over to AE slipper pads you can run AE or kimbrough spur gears, you could also swap over to a avid slipper to use the lower avid spur gears. If you are running 17.5 you also have the option of running a slipper eliminator and kimbrough spurs.
Life_livin is offline   Reply With Quote
Old 07-16-2013, 07:01 PM   #7616
MikeXray's Avatar
Trader Rating: 73 (100%+)
I run the avid topshaft with Kimbrough AE spur, I like the vts, but you can b4 standard pads and plates too.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-17-2013, 07:42 AM   #7617
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Expecting some high grip I see.
Are they sugaring the track this year? I am really not liking the trend of big races this year sugaring the track after Cactus did it.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 07-17-2013, 08:03 AM   #7618
Guest
Send a message via Yahoo to kyoshoracer77
I never been on a sugared track. Y don't u like it??
kyoshoracer77 is offline   Reply With Quote
Old 07-17-2013, 08:14 AM   #7619
mingoglia's Avatar
Makes incredible traction. I for one don't like it because I'm not sponsored and have to buy my own tires. When SRS out here used grape soda on the track a set of tires supposedly were completely bald after each round.
I have to admit, I enjoy running when there's tons of traction, but to me it just takes a bit away from racing. I believe if it's offroad racing there should be some inconsistency, and you should have to deal with varying traction between races and adjust your driving style accordingly.
mingoglia is offline   Reply With Quote
Old 07-17-2013, 08:14 AM   #7620
lewis4x4's Avatar
I realize this question was not addressed to me but I agree that I don't like the direction, assuming this is going to become a standard, for big outdoor races to go to Sugar tracks. What I love about outdoor "Off-Road" racing is that it is just that: OFF-ROAD... I understand that at Pre-Worlds, the drivers had zero traction and it was bad but I blame that on A-Main for not watering the track properly leading up. Loose dirt is Off-Road and I hope we don't quickly turn this sport into On-Road with jumps.
Brian "B-Daddy" Lewis
XRay, Proline, Absolute Hobbyz, RC America, Airtronics, Murnan Modified Motors, Team Trinity, Kustom RC Graphics, Schelle Racing, MIP, LFR, StickIt1 Racing, Team Lewis Racing
lewis4x4 is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
