    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 07-15-2013, 09:31 AM   #7591
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by ryanpatrickgore View Post
+1more for the ghea pistons.
I have never had a car/ piston combo with a more perfect fit and finish.
yessir. takes the best shock in the industry to the next level
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 07-15-2013, 11:50 AM   #7592
SAMCRO's Avatar
I am in need of some new outdrives for my diff. Has anyone tried the MIP outdrives? If so, are they any better or the exact same thing as the RB6?
SAMCRO is offline   Reply With Quote
Old 07-15-2013, 11:55 AM   #7593
Super Moderator
Trader Rating: 17 (100%+)
Ghea 4 hole... only way to fly
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-15-2013, 12:09 PM   #7594
aloksatoor's Avatar
They are more durable for sure. I still cannot see any wear on mine. I have the whole MIP rear end, hexes, axles, cvd and diff. Just a slight discoloration on the inside of the outdrives after around 3 months I thinks
Old 07-15-2013, 03:02 PM   #7595
ColbyRichards's Avatar
Default mid motor help
I've been running my car mid motor the last week and I've got it to be somewhat to my liking but I have a problem with a switch back after a small double. It seems like the car is just lazy and I lose a lot of speed and time in that specific section. I'm running saddles, with speedo in front, no screws on the chassis and avid 4 hole 1.3 with 30f 27.5r associated oils. looking for some ideas to get the car to react faster
Retired
ColbyRichards is offline   Reply With Quote
Old 07-15-2013, 03:06 PM   #7596
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You can't run just the outdrives, you will need to run the entire diff, unfortunately. Then once you start to wear the pins down on your CVds, you can switch to the MIP CVD kit as well. Apparently they are much more durable.
But look closely, and you will see that the MIP outdrives by themselves, are 2x the cost of the kyosho outdrives. So will you actually save money buy buying ane entire new diff, and outdrives at double the price? Even if the outdrives last twice as long, you wont save a penny.... you will only be down the cost of the entire new mip diff.
Now, if they last 3 times longer or more, then maybe over a year or two timeline, you can start to save some cash. I don't know how much more durable they are (if at all), first hand.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-15-2013, 08:08 PM   #7597
joeymdz's Avatar
Send a message via MSN to joeymdz
What kind of surface do you run on?
joeymdz is offline   Reply With Quote
Old 07-15-2013, 09:20 PM   #7598
Just put the flex screws back up. Lazy is exactly what we feel the lack of it does.
Or maybe try to remove only the center ones.
We ran with all off them either rear or mid and try to make up for traction elsewhere if needed.
About MIP you could use the cvd only and keep the K diff, far better IMHO even if outdrives look more sturdy. Just have a spare K outdrives and change them if needed.
mojo tom is offline   Reply With Quote
Old 07-16-2013, 03:22 AM   #7599
1bigshane's Avatar
Trader Rating: 18 (100%+)
just my two cents ! mip is by far, very good! I have 120 hours on my k car,with mip products, with very little wear on drives and axles, it got to a point when I call out when I would snap a kyosho axle! now with MIP no worries! and the pin will never fall out and destroy my hubs!
www.rcracechat.net radio show Host
** Pro-Line Racing ** MIP ** TEKIN **
R/C CAR Track Builder
SIK LIDZ Rc Painting
P.I.P Parachute Industry Products.
1bigshane is offline   Reply With Quote
Old 07-16-2013, 04:55 AM   #7600
SAMCRO's Avatar
Good point. I always try to look at things like are the pros using these? I have been running my car hard for 9 months. Do the bones needs to replaced ever?
Old 07-16-2013, 06:05 AM   #7601
mingoglia's Avatar
I actually somewhat disagree. Just because the pros use something, doesn't necessarily mean they're the best or most durable. Depending on their level of sponsorship, they may be forced to use certain parts. They also either get free parts or drastically reduced in price parts. If ones always has access to, and runs fresh CVD's, then longevity isn't as much of a concern as it is to the rest of us which may run the same buggy every week and only swap parts when they break.
mingoglia is offline   Reply With Quote
Old 07-16-2013, 09:07 AM   #7602
I'll try some scews in.
You know where mandozer at nw. Traction is good and I'm not slipping and sliding every where
Retired
Old 07-16-2013, 09:22 AM   #7603
Super Moderator
Pro Kyosho drivers would be prohibited from using the MIP diff, outdrives, and CVD kits. They have to use Kyosho.
- RCSpecialties -
Old 07-16-2013, 12:56 PM   #7604
Just wondering if I need to use a short servo if I'm running rear mount with a straight battery? or will a standard servo have plenty of room?
Brutelizer is offline   Reply With Quote
Old 07-16-2013, 01:04 PM   #7605
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Unless that "Pro" just so happens to be also sponsored by MIP as well
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
