    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 07-14-2013, 06:23 PM   #7576
Or you can just flip the spacers already on the car from when you built the kit. Lol
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 07-14-2013, 07:32 PM   #7577
jkirkwood's Avatar
Linked is the scan of the UMW705, UMW706 and UMW707 instructions. It contains both an eccentrics chart and a reference to the other holders.
https://docs.google.com/file/d/0B03C...bzA/edit?pli=1
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 07-14-2013, 07:44 PM   #7578
caguilar4's Avatar
Gotta question, what do the shims that go between the caster block and chasis do? I see that the kit comes with different choices, but don't knowmwhat the effects on handling might be...
Thanks!
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 07-14-2013, 07:56 PM   #7579
gelshocker's Avatar
Thanks for sharing. Do I need to run the hinge pin bushings, if so which ones, plastic, metal or delrin? Thx,
Also, when should one run toe-in at the hub versus at the arm?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-14-2013, 08:22 PM   #7580
jkirkwood's Avatar
Yes you will still need bushings. I stayed with the delrin.
As for the other question regarding toe-in, when you change it at the arm's inner position you are changing wheelbase and dog bone angle. I tend to agree with Dan Griffin's statement on the matter. Difference between inboard and outboard toe-in
Old 07-14-2013, 08:23 PM   #7581
mingoglia's Avatar
Yeah, like what do you know about these toy cars?
Oh, and thanks for setting up my RB6. I spent the whole day with it yesterday and it was completely dialed. I didn't even have to switch to my Beams as my ghosted (almost bald) pressure points even provided plenty of traction. I even let Lacey drive it and even he was almost able to keep the thing on the track.
mingoglia is offline   Reply With Quote
Old 07-14-2013, 08:47 PM   #7582
gelshocker's Avatar
Thx. If the out-B pairing is stock kit (wide 3 degrees) would you know which combo equates narrow 3 degrees?
Kyosho RT5 | RB6
Old 07-14-2013, 09:11 PM   #7583
Anytime! If you ever have any questions shoot me a text ill pm you my number.
www.OHRCR.com
Old 07-14-2013, 10:02 PM   #7584
skengines's Avatar
Trader Rating: 226 (100%+)
I use the AE 12mm pistons.
GHEA makes some too, but they are about 7.00 more. The AE ones fit perfect.
Originally Posted by KalEl63 View Post
I am interested in this, what do the tapered ones do and what brand?
skengines is offline   Reply With Quote
Old 07-15-2013, 01:12 AM   #7585
eper's Avatar
Trader Rating: 14 (100%+)
the other issue with changing toe inboard is corner entry isnt consistent do to binding in the output cups.. i used to run the wide rear and narrow front hangers on my rt5 to get more forward bite and the truck would sometimes get sketchy on entry. BUT that is a dramatic amount of toe. As i always say the only way to see how it works for you is to try it out
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-15-2013, 03:12 AM   #7586
Negative...the AE pistons (at least the tapered ones) DO NOT fit perfect. They are not a thick as the Kyosho pistons and need shimming to be right or your going to get an inconsistent feel. Not to mention a clicking sound from them slapping against the e clips inside.
www.OHRCR.com
Old 07-15-2013, 04:56 AM   #7587
celt's Avatar
The GHEA's as mentioned, are a perfect fit - no shimming needed.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-15-2013, 06:26 AM   #7588
kyle3333's Avatar
Thanks for posting the instructions. So which configuration creates the narrow setup at 3.0? It looks like In-B/In-B, In-C/In-C, or In-D/In-D could all equal the narrow rear setup at 3.0.
JConcepts UpGrade RC
kyle3333 is offline   Reply With Quote
Old 07-15-2013, 09:02 AM   #7589
jkirkwood's Avatar
The "In-C" would equate to the narrow setup if you are currently using the UMW511/UMW512 narrow suspension hangers according to the reference provided in the document.
Old 07-15-2013, 09:18 AM   #7590
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
+1more for the ghea pistons.
I have never had a car/ piston combo with a more perfect fit and finish.
ryanpatrickgore is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Sam8344
