    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 07-11-2013, 11:12 AM   #7546
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
69/33 with the reedy motor at 40* timing
ryanpatrickgore is offline   Reply With Quote
Old 07-11-2013, 11:34 AM   #7547
Super Moderator
Trader Rating: 17 (100%+)
let me rephrase that....
What gears are you using
I haven't seen anything that small from Kyosho. I may be missing it...
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-11-2013, 11:44 AM   #7548
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You can run Losi spurs and pads, or Avids.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-11-2013, 11:51 AM   #7549
Super Moderator
That's what I was looking for. Thanks.
Old 07-11-2013, 11:52 AM   #7550
I'm just running the kimbrough spurs with ae pads. But I have recently picked up a set of gariodisks and I have 2 days on them so far. No glazing and consistent throughout the pack. More testing required tho.
Old 07-11-2013, 11:54 AM   #7551
Cpt....did you ever get a gen2? If so looking for a basic setup for 17.5 blinky with gearing.
Gitsum is offline   Reply With Quote
Old 07-11-2013, 02:57 PM   #7552
B44USTA's Avatar
Trader Rating: 45 (100%+)
Send a message via Skype™ to B44USTA
some help plz, pinion x spur / 2.6 = FDR?
for a RB5 SP2
-------------------------------!ALLL FOR FFFUN!------------------------------------------
B44USTA is offline   Reply With Quote
Old 07-11-2013, 03:20 PM   #7553
Super Moderator
for a RB5 SP2
close
spur / pinion * internal = FDR
78 / 23 * 2.6 = 8.817
Old 07-11-2013, 03:57 PM   #7554
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
if i throw a Durango rear hex on the RB6, and use stock durango wheels, any idea if they will be the correct offset?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 07-11-2013, 04:08 PM   #7555
Mxer59's Avatar
Trader Rating: 114 (100%+)
what do you guys do for stock gearing? Assuming you aren't running the Avid setup....
I run AE spurs and AE pads 72/31-32 I currently run Orion R10 with schuurspeed at 30 can timing favorite system so far.
I used to run gen2 setup same gearing and timing also was good
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 07-11-2013, 06:11 PM   #7556
gelshocker's Avatar
Originally Posted by LT FAB View Post
I like the stock slipper with the with the KYOUM572 SP2 WC set up.
This is a replacement Kyosho Slipper Spring Set, and is intended for use with the Kyosho Ultima RB5 SP2 WC and SC-R SP 1/10 scale vehicles. This slipper spring set allows finer slipper adjustments for more traction and consistent slipper operation. This set up is the shit . I tried the avid with the avid top shaft and it only lasted one pack it was loud that's might be just my experience.
Guys any reason not to go the full WC hog? Red pads, WC discs and all?
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-11-2013, 06:37 PM   #7557
B44USTA's Avatar
Thumbs up
thanks mate
close
Old 07-11-2013, 06:40 PM   #7558
Super Moderator
Apex2? What rotor and stator combo did you order? With a torque stator and 12.5HT rotor, you will gear WAY up from an apex1. I haven't run it in my buggy yet, but I have in my touring car, and how far I had to gear up was ASTONISHING... I still can't believe it.
With the apex1, you would gear your TC for a medium sized average track at 3.75 to 3.85, give or take. With the apex2 (torque/torque), same endbell timing, we are gearing between 3.5 and 3.4!!! Taller than 21.5 guys.
For the buggy, I will probably run 60 timing, 66spur, and 32-33 pinion to start. (in not exactly sure yet)
All of this changes of course if you are running the RPM stator, and/or a different rotor.
- RCSpecialties -
Old 07-11-2013, 06:49 PM   #7559
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
That's what I run. Dialed
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 07-11-2013, 06:51 PM   #7560
Teufel Racing's Avatar
Trader Rating: 26 (100%+)
Originally Posted by jkirkwood View Post
Those suspension holders allow you to adjust width and/or toe-in. Anti-squat is still adjusted via shims under the hangers. I put them on my car a few weeks ago and cannot fault their fit & finish at all. Here's a bit more information here. If I get time in the next few days I'll scan in the eccentrics chart they provide with the hangers.
Good luck with the new RB6.
Would also like to know what each inset equates out to. If it's like the zx5 ones, I think I'll pick them up for sure. Was wondering if they'd make them for the rb6
Just looked up the zx5 ones on petitrc and I think I got a handle on it, but still not 100% sure
J.Mikoliczyk
ZX6 - RB6 - MP9e
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
