    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 07-09-2013, 07:24 AM   #7516
celt's Avatar
Default should arrive today...
Someone tell me this thing steers better than a 22.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 07-09-2013, 07:34 AM   #7517
Way better! On a side note was looking at all the rear hangers available and it seems the front hanger is the same for narrow and wide or am I missing something?
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 07-09-2013, 07:41 AM   #7518
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
No, the front is different for wide and narrow just like the rear.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 07-09-2013, 07:46 AM   #7519
MikeXray's Avatar
Trader Rating: 73 (100%+)
They are all listed on the first page of this thread.
Exotek now also makes them, and even some options Kyo doesn't offer.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-09-2013, 09:07 AM   #7520
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Everything steers better then a 22.... except maybe the dex210. This car can steer just as aggressively as the infamous b4. It can have as much or as little as you want, tuned in or out based on your setup.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 07-09-2013, 09:09 AM   #7521
Super Moderator
The front suspension hanger is designed specifically for the RB6. There are THREE front hangers, two for the RB5, and one for the RB6. If you want to change the front track width of the RB6, by design, you do it using the inserts in the caster blocks.
- RCSpecialties -
Old 07-09-2013, 09:12 AM   #7522
Are the kit springs any good for outdoor clay?
zzztech is offline   Reply With Quote
Old 07-09-2013, 10:25 AM   #7523
turtlebmx's Avatar
Trader Rating: 31 (100%+)
yes
turtlebmx is offline   Reply With Quote
Old 07-09-2013, 10:49 AM   #7524
Super Moderator
Depends on the traction level of the track. If traction is low, you may want to run gold rears, or even white rears, depending on how much traction is lacking.
- RCSpecialties -
Old 07-09-2013, 12:32 PM   #7525
t8rtot's Avatar
Trader Rating: 14 (94%+)
if you do run the gold rears, you will lose corner speed so make sure you stand the rear shocks up.
it will get you just about back to the same speed but provide more grip..
Sfida
t8rtot is offline   Reply With Quote
Old 07-09-2013, 12:57 PM   #7526
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Nope, not at all.
Originally Posted by ridgeracer View Post
Thanks for your help Kyoshoguys
I am going to say 54mm center to center.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-09-2013, 01:31 PM   #7527
Originally Posted by Kraig View Post
Nope, not at all.
Thanks Kraig, 56mm on the dex210 so I will order one then.
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 07-09-2013, 05:51 PM   #7528
paintchip31's Avatar
Trader Rating: 434 (100%+)
Send a message via ICQ to paintchip31
Thanks guy' it was the wheels . Now on to the AVID slipper when I opened it up I installed it just as the pic showed! (I NEED THE PICS LOL) Anyway there are 3 small washers and a larger aluminum one that are still in a bag un opened I don't see where they would go I will take a pic of the bag and post in a bit . Thanks again guy's.
Heart of a hustler racing
TRICK GRAPHICS
The Loft RC Raceway ~ Columbus, OH ~ www.TheLoftRC.net
sponsored by
http://teameamotorsports.com/
paintchip31 is offline   Reply With Quote
Old 07-09-2013, 09:47 PM   #7529
gelshocker's Avatar
Originally Posted by gelshocker View Post
Hey guys how's your RB6 bulldog holding up? Mine's received a 2 inch rip at the back along those one of the acute angled body lines. First run with it! The Blade body is holding up. Thanks,
Anyone?
Another quick question: those running MM with the ESC behind servo: would 10" wire from ESC to motor be enough? Thx!
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-09-2013, 10:03 PM   #7530
Super Moderator
Trader Rating: 17 (100%+)
My bulldog is doing ok. I have a hole in the side from getting t-boned by a Losi 4x4 SCT... but that's kind of an extreme case.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Yesterday 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
