    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 07-06-2013, 10:25 AM   #7486
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by jackcarter3 View Post
You should've asked one of us at the track. You never drove mine when I had it but it was dialed. 4x1.3 ghea pistons is what everyone is using.
Yeah I know Jay,
Seems that most are of the guys locally are opting for the 1.3-4 hole pistons. Say the car is way better with them. I think Mike said he has the Ghea ones. Not sure how many run the tapered ones though. I'll get it dialed in.
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 07-06-2013, 10:38 AM   #7487
jackcarter3's Avatar
Originally Posted by Teufel Racing View Post
Yeah I know Jay,
Drive ramirezs car. Everyone is running tapered.
TEAM SCHUMACHER-USA
TRACTION RACEWAY-Reno, NV.
jackcarter3 is offline   Reply With Quote
Old 07-06-2013, 10:39 AM   #7488
It's hard to get the right amount of pack with more than 4 holes in my opinion. Especially when we have circus jumps on some tracks.
TEAM SCHUMACHER-USA
Old 07-07-2013, 07:35 AM   #7489
MikeXray's Avatar
Trader Rating: 73 (100%+)
The ghea 12mm rb5 are the same as the rb6 pistons right?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-07-2013, 10:53 AM   #7490
I tried the 1.4/3 hole tapered and didnt like them. I keep going back to the 4/55 pitons I drilled from blanks. Been running 35/30 oil and AE brown front black rear springs. Car feels really planted especially on this off camber turn we have. Everyone else seems to slide down the side of it while turning and my RB6 is glued.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 07-07-2013, 01:37 PM   #7491
Hello guys...I want to try the RB5 front axles UM506 and I was wondering if they fit right in the new car or I have to buy some other bits...spacers? How many and do I put them inside or outside the axle??
nitroargi is offline   Reply With Quote
Old 07-07-2013, 02:11 PM   #7492
paintchip31's Avatar
Trader Rating: 434 (100%+)
Send a message via ICQ to paintchip31
I found that the AVID 1.3 is the same as the 4 55
As for what I am needing is anyone using the V2 rear hubs yet ? I just put a set on my car and seems like there is not much room for the wheel nut now did I do something wrong?I have tried taking out the brass washer in center still not enough bite take a look and let me know what you think.
Heart of a hustler racing
TRICK GRAPHICS
The Loft RC Raceway ~ Columbus, OH ~ www.TheLoftRC.net
sponsored by
http://teameamotorsports.com/
paintchip31 is offline   Reply With Quote
Old 07-07-2013, 02:20 PM   #7493
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
+1 on the ghea pistons
ryanpatrickgore is offline   Reply With Quote
Old 07-07-2013, 02:38 PM   #7494
Super Moderator
Trader Rating: 17 (100%+)
1.3 = 55 hole.. more or less. 1.3x4 was the way I went. Ghea tapers. I believe I went with the same oil / pistons / springs that's listed on Tebo's 2013 Midwest Winterchamps setup from CRCRC. It was pretty good. I would start with that setup and adjust off it.
The inner hub bearing doesn't look seated to me... maybe it's just the picture??
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-07-2013, 02:59 PM   #7495
That is close to the set up I am running but I am running Luke Richards really close.
And yes it is all the way in for sure! I changed rims they bite more but not as much as I would like there to be!
TRICK GRAPHICS
sponsored by
Old 07-07-2013, 04:51 PM   #7496
EJF
EJF's Avatar
Trader Rating: 37 (100%+)
Will associated big bore pistons fit the RB 6 shocks?
EJF is offline   Reply With Quote
Old 07-07-2013, 05:03 PM   #7497
Super Moderator
Yeah. I tried 2x1.6 tapered ae pistons. They were good too.
Old 07-07-2013, 09:22 PM   #7498
Well it seems that the 1mm spacer that I am missing is the UM505B..the question is should I put it inside the hub or outside?
Old 07-07-2013, 10:25 PM   #7499
It looks like your bearing are not in correctly. Make sure you have the correct black plastic piece installed for your bearing size, brass piece goes inside hub between bearings
Jam-Air is offline   Reply With Quote
Old 07-07-2013, 11:35 PM   #7500
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Paintchip, your exposed axles look normal, which means your bearing seating is just fine. You should have 1mm of un-threaded axle showing, and about 11 threads... which you do. Which means you have an issue with your wheel. I doubt your hex is seating all the way into the wheel (that's a kyosho wheel right?.. if not, make the switch). It's the only thing it could be.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 09-22-2017 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
