    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 09-26-2012, 12:59 PM   #736
Trader Rating: 140 (100%+)
ok guys, RC Racing Designs just got ahold of the kit.
since the rb6 wheelbase is the same as a 22, and the rcrd short chassis really rock on the car , rcrd in going to make a shorter rb6 chassis..
The question is how short do you kyosho guys want it.
respond , looks based upon first messurment ,
it is posible to do a 4mm and a 10mm shrink to the car,
thats just a rough measurement, its almost layed out in the laser and will know for sure..
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 09-26-2012, 01:11 PM   #737
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
There is no way to tell at this time. Not until there is a determination that a shorter chassis would even benefit this car. Sure the wheelbase is the same, but it's an entirely different car than the 22.... it may be perfect with it's factory wheel base. The key will be to figure out if the car has issues turning and changing direction. If the car is as stable as other longer cars, but is still nimble and changes direction well, there wont be a need for a short chassis.
Only time will tell.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 09-26-2012, 01:54 PM   #738
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by Cpt.America View Post
There is no way to tell at this time. Not until there is a determination that a shorter chassis would even benefit this car. Sure the wheelbase is the same, but it's an entirely different car than the 22.... it may perfect with it's factory wheel base. The key will be to figure out if the car has issues turning and changing direction. If the car is as stable as other longer cars, but is still nimble and changes direction well, there wont be a need for a short chassis.
THIS
just like the old xxx-cr, its wheelbase was actually shorter than the b4, but pushed like a sled..
we'll see how Kyosho took care of this with the RB6, the new front end looks to have been changed for that reason.
Sfida
t8rtot is offline   Reply With Quote
Old 09-26-2012, 02:34 PM   #739
BranVita's Avatar
Trader Rating: 39 (100%+)
Branden V.
Kyosho Rb6 | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1257
Kyosho SC-R SP | Orion R10 Pro | SchuurSpeed 17.5 | Savox 1258
BranVita is offline   Reply With Quote
Old 09-26-2012, 02:36 PM   #740
Any tried the new big bore caps on FS2 SP etc?
I've been using standard bore shocks over big bores this year and will be keeping a set to try on the RB6.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 09-26-2012, 05:51 PM   #741
BranVita's Avatar
Also, anybody got pics of rear motor layout/ w R10 pro and a Shorty Lipo?
Branden V.
Old 09-26-2012, 06:14 PM   #742
skrichter's Avatar
Send a message via AIM to skrichter
4mm might be right on target, to match the AE car.
I own the 22 -5mm chassis, and its great. Makes the car actually appear normal sized.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 09-26-2012, 07:21 PM   #743
Why doesnt the suspension bushing fit in the new one piece shock cap? Has anyone else had this problem? It just slides straight through. I am using the one the manual says
Bluehills315 is offline   Reply With Quote
Old 09-26-2012, 07:34 PM   #744
gelshocker's Avatar
I notice the same thing. The hole in the new shock cap is way bigger than previous plastic.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 09-26-2012, 10:42 PM   #745
AZRC4Me's Avatar
Mine's the same way. I even tried using the older bushing and it's loose as well. Not sure why it would be this way...? I haven't finished it yet but I'll try it and see how it turns out assembled.
Sean Gaffney
...where some sponsors used to be...
AZRC4Me is offline   Reply With Quote
Old 09-27-2012, 01:54 AM   #746
jelly's Avatar
it doesn't seem so bad when its screwed on with the washers. must be intentional slop.
on the other hand my kit didn't have the slipper spacers
jelly is offline   Reply With Quote
Old 09-27-2012, 06:22 AM   #747
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Over the years I have found that when you tighten something against plastic the original shape gets deformed. As you imagine it gets worse. However in this case it sounds like this might be planned but I could be wrong.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-27-2012, 07:00 AM   #748
lewis4x4's Avatar
Most people tighten the screw on too tight which caused the shock to have enough play in it to rock back and forth. Now, when you tighten the screw on there tight, it allows the shock to have proper play.
Also, why is everyone already trying to figure out how to customize a new chassis? The new RB6 is awesome. I have two friends that have driven theirs already and they both say it is the best buggy ever. Just my 2 cents...
Brian "B-Daddy" Lewis
XRay, Proline, Absolute Hobbyz, RC America, Airtronics, Murnan Modified Motors, Team Trinity, Kustom RC Graphics, Schelle Racing, MIP, LFR, StickIt1 Racing, Team Lewis Racing
lewis4x4 is offline   Reply With Quote
Old 09-27-2012, 08:17 AM   #749
Super Moderator
As you tighten the nut, it will compress and expand the bushing inside the shock cap. Make sure they aren't so tight they bind the shock, and make sure they are equal left and right.
- RCSpecialties -
Old 09-27-2012, 08:29 AM   #750
AZRC4Me's Avatar
Cool, thanks guys, that's kinda what I figured but I knocked off last night at 11:30 before I could finish the shocks. Really nice build so far, what I expected. I did notice the front caster blocks fit fairly tight in the front arms with the new insert/bushing, so I sanded the inside of the arms a little bit to free them up. Other than that, I haven't had to do anything out of the ordinary. My kit didn't seem to have the slipper spacers for the spring in it either...? But I noticed from the manual the one that sits on the outside slipper disc looked very small compared to the older one. I never had an issue with the RB5 slipper, so I just used that with vented discs in this build. The larger diameter spring plate makes more sense to me as it would distribute the load more evenly across the slipper disc. Looking forward to running it this weekend!
Sean Gaffney
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
