    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-27-2013, 03:37 PM   #7411
gelshocker's Avatar
Hey guys this was raised before, has anyone found a solution to tighten up the slack developed in the steering? Like some delrin inserts, bearings or something? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 06-27-2013, 04:17 PM   #7412
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I don't have much slop yet but it's starting to develope. Maybe try using the kyosho shims, I'm sorry I don't have a part number but they are very thin metal shim/washers that work just about everywhere. I think most people buy them to use on their b4 cars. Lol
ryanpatrickgore is offline   Reply With Quote
Old 06-27-2013, 04:20 PM   #7413
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I am running the all aluminum kyosho arms and rack slop free for quite a bit now. It seems its better than the exotek stuff.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-27-2013, 04:20 PM   #7414
Send a message via ICQ to JiuHaWong
http://p-dubracing.co.uk/index.php?m...g80iie3dijgdv0
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 06-27-2013, 11:38 PM   #7415
Why doesn't anyone run limiters inside front shocks on rb-6? Seems they just adjust overall shock length instead?
Jam-Air is offline   Reply With Quote
Old 06-28-2013, 12:02 AM   #7416
silveraider14's Avatar
i would just guess because changing the little bottom eyelid is easier than changind a limiter inside the shock.
doesnt the bottom of the shock adjust droop if you have the short medium or long eyelid?
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 06-28-2013, 06:30 AM   #7417
asc6000's Avatar
Trader Rating: 15 (100%+)
yes, same for unscrewing X turns
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-28-2013, 10:21 AM   #7418
Ok who here has good midmotor setup for mod? I know there are plenty of Tebo etc setups but I'm no Tebo.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 06-28-2013, 10:48 AM   #7419
Trader Rating: 31 (100%+)
what are you running on carpet, dirt(what kind, indoor, outdoor)?
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-28-2013, 11:17 AM   #7420
Smallish indoor clay tires of choice are hb beams in pink and full shot in pink or Jc greens. Jumps aren't very big and layout is usually pretty flowing. Search The Dirt Invert on YouTube there should be video. I would post it myself but I'm a tard lol.
www.OHRCR.com
Old 06-28-2013, 11:35 AM   #7421
I have been playing with Hara's WC setup from the Reedy race. I changed it a little, here are my changes:
.5 hubs
added this to the motor
http://www.amainhobbies.com/product_...tor-Weight-30g
taped this to the very rear of the car against the bulkhead
http://www.amainhobbies.com/product_...-Stopper-Block
The weight is key or the setup won't feel good. It shifts the weight over the rear tire so that it is similar to a rear motor, but without the pendulum effect of all the weight being behind the wheels.
shorty turned sideways all the way back, low pro servo up front, 2x1.6 taper AE pistons, 35f 30r
If your track has some grip, this should feel pretty good. If it is loose, not so much .
MBX6-ECO, B5m
Old 06-28-2013, 01:32 PM   #7422
Orion_2kTC's Avatar
I'm starting to think that my first 2WD Buggy will be an RB6. I plan on starting with the 17.5 class and moving up to mod when I'm confident. I'm curious on a couple things.
Is the build and manual simple enough that I can build this? I've never assembled any RC cars before but I have worked on a Losi 8Ight-E
I've heard that the various aluminum steering parts from Exotek are recommended for strength and stability. I would also probably buy the CF towers and battery holders. What other suggestions would you folks make? Link to Exotek for convenience! I'll take other brand recommendations too.
http://www.exotekracing.com/kyosho/
The shocks that come with the stock kit, are they the "velvet" shocks that everyone seems to swoon over? They're not advertised as such. If not, are they still good?
I've been reading info from this thread for a while now and while the RB6 is an expensive car, I believe in quality. This car has the look I want, the features I want, and seems to be built with quality in mind. Local parts support is there to a point but in this internet age, it doesn't bother me if I have to order from amain or other sites.
Orion_2kTC is offline   Reply With Quote
Old 06-28-2013, 02:20 PM   #7423
I've liked all the Kyosho aluminum steering rack parts (cranks and rack itself) which are basically slop-free after a few thousand laps, although you can't go wrong with Exotek. They make a front hinge pin brace that I'd like to try. I've never broken a shock tower, mainly just some front suspension mounts and bent/broken front braces. Shredded an idler gear once. Use the reinforced black ones!
There are probably parts of the build manual that could be more clear but if you've put together a kit before you'll have no problem. It really doesn't need that much in terms of upgrades. You won't be disappointed!
BryanJ is offline   Reply With Quote
Old 06-28-2013, 02:23 PM   #7424
t8rtot's Avatar
you can build it, just take your time. i would get the steering rack, don't worry about the carbon fiber, car doesn't need it, invest in alum hangers.
the shocks are velvet and they are the best.
build it, drool over it, wipe it off, start with the kit setup and race it
Sfida
t8rtot is offline   Reply With Quote
Old 06-28-2013, 03:10 PM   #7425
RacinJacin's Avatar
I replaced the stock rear hub carrier with a .5 deg tow in aluminum hub from Kyosho. The new hubs have an oversized outer bearing that is way way better that stock. They just got another revised hub carrier that has both oversize bearings. It should be even better. I am going to get those too but in 0 deg. For some reason I like 0 deg better. Who would have thought I would be able to tell the difference. The In sprung weight might not be the best thing but it is stronger, Its just a preventative measure. The RB6 is an amazing Car. It seems to do everything well. I have not found a flaw yet. I have picked up all the Kyosho Hop ups available although I didn't need any of them. I have not really had anything break.
RacinJacin is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sho yoshida
