    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 06-24-2013, 07:55 PM   #7381
Mip top shaft is different than the avid one
In regards to caster, more caster means more turn in less exit steering, less caster mew s more exit steering less turn in
Jam-Air is offline   Reply With Quote
Old 06-24-2013, 11:04 PM   #7382
aeRayls's Avatar
Originally Posted by Team G Racing View Post
I checked on Amain and compared the Avid RB6 and the MIP and it looks a little different. I will wait til MIP answers
The MIP top shaft for the B4 fits into standard 3/16x3/8 bearings... So unless kyosho has went away from metric... I'd say its a no go
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 06-24-2013, 11:10 PM   #7383
What up?'s Avatar
Trader Rating: 14 (100%+)
Originally Posted by silveraider14 View Post
My rb6 has a stupid amount of initial turn in. Is there anything I can do to lessen it? I am running a mid motor on carpet.
Also for some resason my car just wants to throw a whip off of the biggest jump on the track. Not saying I don't like it cause it makes it look awesome! Just want to know why lol
Is you buggy loose in the rear? I know you said carpet but.... If your loosing traction off of the face of the jump it will do that.
If your tranny is diffing out on the face of the jump it will do it as well.
Some things to check.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 06-24-2013, 11:42 PM   #7384
silveraider14's Avatar
no its not loose in the rear. its not loose but not locked down.
B5m - speedpassion.net
Timewarp R/c Raceway
silveraider14 is offline   Reply With Quote
Old 06-25-2013, 12:25 AM   #7385
Originally Posted by Jam-Air View Post
In regards to buggy weight, I saw a 1680 gram buggy run a second a lap faster than everyone else in money stock
I assume your talking about Andrew Smolnik. More weight helps with the traction when it gets dusty, also he was only .4 faster then me by the time I got things figured out in round 2. We had a good battle in the Main, but I just couldn't make up the time I lost. I think I settled at around 1580 grams, I ran at 1620 with saddle pack and didn't like it.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 06-25-2013, 05:01 AM   #7386
eper's Avatar
silveraider it sounds like maybe the way things are mounted in your buggy is offsetting weight to one side of the car causing the whip effect. i would start by putting the car on a tweak station and getting all my preloads good and even, then i would counter balance the side of the car that isnt dropping, little by little to get a idea of the amount of weight and what component i need to move to get the car more balanced.. if you have access to 4 scales that would make things easier..
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-25-2013, 05:35 AM   #7387
Trader Rating: 31 (100%+)
Originally Posted by Cspurlock View Post
Does anyone know if you can run mid motor with the narrow hangers? If so do you use the same hanger as rear motor or a different one?
Thanks in advance!
Anybody?
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-25-2013, 06:15 AM   #7388
MikeXray's Avatar
Trader Rating: 73 (100%+)
Anybody?
Not currently, I'm speculating that the new adjustable hangers might be able to achieve this, but I haven't seen the specs of what inserts are available.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-25-2013, 10:30 AM   #7389
SpeedTech's Avatar
Hi Guys,
We have a few of the Kyosho V2 Aluminum Rear uprights (0 deg and 0.5 deg) left in stock.
Thanks,
Jeff
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 06-25-2013, 10:39 AM   #7390
Suspended
Trader Rating: 23 (100%+)
Straight from MIP
Unfortunately No, but Avid RC products manufactures an aluminum top shaft for the Kyosho that is made by MIP. Check out their site. Same quality went into that topshaft as it does into ours.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 06-25-2013, 11:26 AM   #7391
i figured out my saddle packs were sliding side to side so i am gonna put a even amount of foam on each side to keept them put
Old 06-25-2013, 05:07 PM   #7392
eper's Avatar
that would do it
new milford ct,
Old 06-25-2013, 05:11 PM   #7393
Send a message via ICQ to JiuHaWong
Straight from MIP
Let me just ask: What's your point?
Just go buy the two try mounting them up and compare. Or, even better, ride your bike to your LHS and have them show you both.
You post more than Wildcat1971...
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 06-25-2013, 07:57 PM   #7394
joecool's Avatar
Trader Rating: 19 (100%+)
Silverraider14, take droop out of the front end. You can use the short eyelets or put limiters inside the shock body. This will take away crazy steering while on power. However, under breaking you'll be faced with crazy initial steering again.
I'll be at the track all evening tomorrow if its dry out. I got a few more things to adjust on mine.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 06-26-2013, 09:04 AM   #7395
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
+1 lol
You were asking the same questions in the b4 thread. Why?
ryanpatrickgore is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
