    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-17-2013, 10:56 AM   #7291
Trader Rating: 48 (100%+)
Originally Posted by mlinder View Post
Oh, thanks Chris for that link. So I use these axles with them?
http://www.amainhobbies.com/product_...heel-Shaft-RB5
Mark
Yes that's the one
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 06-17-2013, 11:21 AM   #7292
Originally Posted by silvalis View Post
on the bench or on the track?
It's usually due to the servo imo. I'm running an RSX one10 LP and it usually is about half a deg out trying to centre on the setup station, but centres properly in practice.
Check your slop anyway. From memory the Exotek rack needed a couple of shims between the rack and the cranks.
On the bench and track, it doesn't want to go to same spot every time.
Seems like something is hitting. I grinned the nose piece per the instructions, however they weren't very clear.
What shims are you referring to so I can confirm
Jam-Air is offline   Reply With Quote
Old 06-17-2013, 11:47 AM   #7293
John.C's Avatar
Trader Rating: 36 (100%+)
I'm trying to identify an alum servo horn to replace the stock plastic piece. I've discovered that not all aftermarket servo horns will work as the movement may be hindered due to the design. Has anyone upgraded to an alum servo horn that fits/works without too much modification and maintains the full range of motion? Does Kyosho make an hop up alum servo horn for the RB6? Thanks in advance!!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 06-17-2013, 11:57 AM   #7294
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
Kyosho makes one for the zx5 that works. I hear the TLR 22 aluminum horn fits but I can't put TLR on my car.
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 06-17-2013, 12:07 PM   #7295
I'm using the TLR22 aluminum horn w/ a Spektrum 6040 servo. I had to dremel the front upper just a bit back when fitting the kit plastic horn, but the TLR horn dropped right in and seemed to be really close to the kit horn as far as geometry goes.
BryanJ is offline   Reply With Quote
Old 06-17-2013, 01:13 PM   #7296
Personally I would advise against the al servo horn. I have had my car since it came out and have broken only 2 steering racks total and 2 plastic horns. Had I had an al servo horn on I'm sure my rack breakage would be much higher. Just food for thought something has to give on hard hits.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 06-17-2013, 01:16 PM   #7297
John.C's Avatar
Thx guys!! Found both on Amain. LMK if i'm looking at the wrong items.
Kyosho
TLR22
Old 06-17-2013, 01:35 PM   #7298
John.C's Avatar
Great point. The only reason I wanted to swap it out was due to the play that developed in the plastic unit. I had a centering problem and I discovered that it was due to a worn out servo horn. I do have the alum steering rack, so it's possible that my next weakest link may be the servo itself!
Old 06-17-2013, 02:58 PM   #7299
If you're running the aluminum rack and cranks I'd want the aluminum horn. Not sure what would break next after that. Maybe breaking ballstuds, steering links, or spindles? I doubt a decent servo would give out in 1/10 2wd buggy unless it was a fluke thing.
Old 06-17-2013, 06:40 PM   #7300
carver gt's Avatar
Trader Rating: 41 (98%+)
Send a message via AIM to carver gt
Originally Posted by Cpt.America View Post
Well do you want more side bite? or do you want more forward traction? Reducing your anti-squat isn't the direction to go, if you are lacking traction in the corners.
Yes i would like more traction in the corners. I have the tire hooked up it just still wants to break free under power in turns. What do I do for hangers and toe?
We support and run-
Team Associated-JConcepts-sticky Kicks RC
carver gt is offline   Reply With Quote
Old 06-17-2013, 08:00 PM   #7301
Jochim_18's Avatar
If the track is loose their is not much you can do!! What type of surface? Is it clay hard pack, Dusty, Wet you need to give us more details to help you out...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-17-2013, 08:40 PM   #7302
carver gt's Avatar
The track is on the large side, clay with med to high grip. I have plenty of steering and forward bite. I want the car to have more cornering speed with out the rear end breaking loose and spinning out. The tires are definitely hooking up I feel it is a rear end suspension adjustment. I let a fellow racer run the car for a few laps and was told it had too much steering. I drive his car which is the same car. And it felt like it rolled forward smoother and held corners way better than mine. Does that make sense?
We support and run-
Old 06-17-2013, 08:53 PM   #7303
silvalis's Avatar
Trader Rating: 29 (100%+)
copy his setup?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-17-2013, 09:03 PM   #7304
Trader Rating: 19 (100%+)
Probably take away some steering.
If you have a lot of grip on one end it can make the other feel like it has much less.
Shimmy is offline   Reply With Quote
Old 06-17-2013, 10:19 PM   #7305
Glen H's Avatar
Has anyone used parts from this company on their rb6 or 5? What are your opinions on them?
http://www.google.com/url?sa=t&rct=j...47883778,d.eWU
Glen H is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
whiskyshooter
