    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-16-2013, 08:32 PM   #7276
carver gt's Avatar
Trader Rating: 41 (98%+)
Send a message via AIM to carver gt
I have a tuning question. I am trying to achieve 0 anti squat. If no spacers under the RF hangers means 2 deg how do i get 0 ? Also which rear hubs would work for this set up? want MORE side bite. Thanks RCT
We support and run-
Team Associated-JConcepts-sticky Kicks RC
carver gt is offline   Reply With Quote
Old 06-16-2013, 08:40 PM   #7277
Frank L's Avatar
Trader Rating: 148 (100%+)
I need to replace a diff outdrive cup, it has a pretty good nick in it. Should I rebuild the ball diff with new or jut take it apart and put it back together?
If I replace it is there a kit and what all do you replace.
Old 06-16-2013, 09:40 PM   #7278
silvalis's Avatar
Trader Rating: 29 (100%+)
i use the bfast kit. - plates, balls, thrust balls, thrust plates
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-16-2013, 10:22 PM   #7279
Jochim_18's Avatar
Shim the RR suspension hanger to reduce anti-squat.. RB6 has a lot of weight transfer to the front reducing anti-squat forces the weight to be transferred more towards the back and it give you more forward bite..
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-16-2013, 10:28 PM   #7280
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Well do you want more side bite? or do you want more forward traction? Reducing your anti-squat isn't the direction to go, if you are lacking traction in the corners.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-16-2013, 10:55 PM   #7281
wild gopher's Avatar
Trader Rating: 39 (100%+)
Originally Posted by umm winning View Post
Currently in the market for a new esc, out of curiosity whats everybody else running in their rb6? - Would be running stock 17.5
I have a Tekin Gen2 in my RB6 and a Speed Passion Reventon Pro in my SC10. While both are very good, the Speed Passion is much smoother and is very affordable at <$120. Many people state they are equivalent to the Orion Pros.
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 06-16-2013, 11:45 PM   #7282
What's the difference in the front axles that come in the kit vs all the set up sheets that reference the rb-5 front axle
Jam-Air is offline   Reply With Quote
Old 06-17-2013, 01:11 AM   #7283
silvalis's Avatar
built in hex vs clamp on hex
Old 06-17-2013, 01:58 AM   #7284
gelshocker's Avatar
Clamp on hex is taller and would sit more securely in filling a deeper non-Kyosho wheel. The built in hex is one-piece steel. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 06-17-2013, 02:01 AM   #7285
gelshocker's Avatar
Slightly off topic, is it worth the effort to update the box stock Orion r10 ESC's firmware, as I only have iMac and office pc are secured. Cheers,
Kyosho RT5 | RB6
Old 06-17-2013, 02:45 AM   #7286
really it is a huge smash really nice.
what is price? at where can people order this online?
colin222 is offline   Reply With Quote
Old 06-17-2013, 05:27 AM   #7287
Hello,
Where can I find the front clamp on hexes? Do they accommodate the use of AE style wheels (I have a lot, having just moved from B4.2)?
I looked up RB5 front axles on Amain, but couldn't find front clamp ons, so I must be looking for the wrong thing. Any link to what I need?
Thanks!
Mark
mlinder is offline   Reply With Quote
Old 06-17-2013, 06:00 AM   #7288
Trader Rating: 48 (100%+)
Originally Posted by mlinder View Post
Hello,
Thanks!
Mark
http://www.amainhobbies.com/product_...Set-Gunmetal-2
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 06-17-2013, 07:10 AM   #7289
Originally Posted by Speedychris22 View Post
Oh, thanks Chris for that link. So I use these axles with them?
http://www.amainhobbies.com/product_...heel-Shaft-RB5
Mark
Old 06-17-2013, 08:10 AM   #7290
hi,
if i want to run the rb5 wc rear arm um566 on my rb6 mid mount, do i have to flip the arms? as the two holes to mount the bottom shocks are at the front?
hugo
hugobox2003 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
