    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-13-2013, 08:40 PM   #7246
mdowney's Avatar
Trader Rating: 21 (100%+)
Originally Posted by zzztech View Post
Can the mid motor use saddle packs? I don't have any shorty, only saw shorty setups on petitrc
If you run saddle packs you will probably have to shave off the two plastic mounting posts on the front of the motor guard in order to fit them in, then you position the forward battery holder as far back as you can. This gives you room for the ESC and Rx in front of the battery. I copied this off of the team drivers' layouts.
Only catch is the battery strap is about 1mm too short to fit under the motor guard and hold the batteries down (the mounting posts you shaved off would have held the back portion of the battery hold down, allowing the strap to fit under it). My solution was to buy the JConcepts CF battery strap for the B4.2 and dremel off the front portion of it, then shorten the length a bit. It looks great.
I noticed on Ty Tessman's MM RB6, which he ran saddle packs with when he won the World's warm up last weekend, that he didn't seem to be using a battery strap. I'm guessing he taped them or something. Based on the pic, it didn't look like he had just removed it while in the pits.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 06-13-2013, 10:53 PM   #7247
I assume a ZX6 since there was some photos of Tebo with a 4wd buggy with an aluminum chassis.
You can see the motor has been turned around like all the other 4wds, ie slipper in the middle of the car
Tom87 is offline   Reply With Quote
Old 06-13-2013, 11:09 PM   #7248
skengines's Avatar
Trader Rating: 226 (100%+)
Originally Posted by mdowney View Post
To expand... you need to purchase the Avid top shaft for the RB6 in order to use the Triad slipper.
Turns out mine had a missing washer. AVID is sending me one.
skengines is offline   Reply With Quote
Old 06-14-2013, 05:00 AM   #7249
Originally Posted by mikeyscott View Post
Yes
Inconsistent
Couldn't agree less mate. RB6 is easily the best and most consistent 2wd car I've run since the Ultima Pro around 1988!
If your car felt inconsistent then it must have been setup based, hardly touch mine now venue to venue. Love this car, wish I could do it justice!
Kyosho UK RB6.6 & ZX6.6
RogerM is offline   Reply With Quote
Old 06-14-2013, 11:12 AM   #7250
For those who have run it mid motor, why does the track have to be super tight for it to work?
I think most people in the states are afraid of mid motor. If the car is loose, there are ways to mechanically fix that besides hanging a brick in back
Just got my rb-6 and building it today
Jam-Air is offline   Reply With Quote
Old 06-14-2013, 11:34 AM   #7251
Send a message via ICQ to JiuHaWong
Great question. I'd like to hear the responses to as well.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 06-14-2013, 11:42 AM   #7252
aloksatoor's Avatar
Trader Rating: 42 (100%+)
hhaha I still have nightmares about my mid motor cougar. The rb6 was better but still lazy for me and with regards to us style tracks, the many hairpins just dont allow you to take the lines which are fastest with a mid motor. The track has marbles there so looser there. Better to follow the RM racing line but then you cannot pin the throttle fast enough in MM.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-14-2013, 11:42 AM   #7253
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
It dosent have to be super tight. it just excels better there in those conditions compared to the rm cars because the cornering speed is that much faster. On tight tracks races are usually won on the infield.
ryanpatrickgore is offline   Reply With Quote
Old 06-14-2013, 12:34 PM   #7254
In my opinion, mid motor cars should be better in any hard pack track condition that isn't got tons of fluf. The car should also excel in stock where you need momentum that usually inertia of a mod motor generates. The car will just flat rotate better
Old 06-14-2013, 12:51 PM   #7255
aloksatoor's Avatar
The factory guys on our track use the pendulum effect of rm well to rotate on a dime on the tight hairpins (most are b4.2s). Our track has crazy grip, orange bar codes with no sauce can do wheelies on the straight with a mod motor. So gaining a few on fast sweepers negates the advantage of being faster on 3 tight hairpins.
Old 06-14-2013, 01:15 PM   #7256
I've preferred mid-motor everywhere indoors so far, five different tracks and eight different layouts in the SoCal area since I got the car a couple of months ago. Some were/are pretty loose surfaces and some were very high grip. Haven't raced it outdoors yet.
I'd also add that in MM config, I prefer the kit arms to the 521-1 arms when the grip is lower. I liked the 521-1's at OCRC and West Coast. But that's just me, YMMV.
BryanJ is offline   Reply With Quote
Old 06-14-2013, 04:06 PM   #7257
eper's Avatar
Trader Rating: 14 (100%+)
so your saying you think the 521-1 arms generate more grip? or is it a feel thing?
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-14-2013, 04:20 PM   #7258
I think he is saying the kit arms generate more traction
Can some one explain how much toe in it has in rear and what the differences are in the rf blocks?
Old 06-14-2013, 04:29 PM   #7259
Exactly, sorry if that seemed unclear. I'll mess around with them some more in a few weeks, but that's how it felt to me. I might have gotten the droop wrong when switching, though, so I'll try harder to do a real apples-apples comparison next time around.
Old 06-14-2013, 05:07 PM   #7260
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
3 degree's.
Check the first post on this thread and it should answer your question about the rear blocks.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
