    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-12-2013, 04:58 AM   #7216
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by john watkins View Post
Does anyone have a pic of their flat rear arms installed on their car?
here ya go
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-12-2013, 06:38 AM   #7217
Hello,
I am building an RB6 to try running mid motor. I currently race an AE B4.2FT.
I have a question concerning the slipper shaft. More specifically the side to side play it has. With the tranny closed up, the slipper shaft moves maybe 2+mm side to side. It is almost as if a shim or two, or a spacer is missing, but there isn't anything listed in the manual. Have I overlooked something or is this side to side play normal?
Thanks in advance for any replies.
Mark
mlinder is offline   Reply With Quote
Old 06-12-2013, 06:44 AM   #7218
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by mlinder View Post
Hello,
Mark
As long as you have the brass collar installed it's fine (see step 34 in the manual) These things are not super tight specs, also don't over tighten the case screws.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-12-2013, 07:12 AM   #7219
Mike,
Thanks for replying. Yep, the brass sleeve is there. I ask only because the similarly designed B4.2 slipper assembly doesn't have much side to side play at all. I will run as is.
Thanks again.
Mark
Old 06-12-2013, 07:17 AM   #7220
silvalis's Avatar
Trader Rating: 29 (100%+)
Mine doesn't move 2mm.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-12-2013, 07:49 AM   #7221
Hmmm. Well, I will take it apart and look again. Not much to mess up on this tranny. I know I can shim is with a couple 5mm shims, but they shouldn't be necessary.
Thanks.
Mark
Old 06-12-2013, 08:23 AM   #7222
joecool's Avatar
Trader Rating: 19 (100%+)
No shims are needed. There is something wrong with yours. There is very little play when it's built right. Are both bearings seated correctly on the top shaft? Is the plastic motor spacer mated to the transmission properly? The motor plate flush with the long screws just threaded to the edge of the motor plate?
Build the slipper assembly to the instructions making sure the slipper pads fit in the indents of the spur gear. Once it's all assembled again you should have no issues.
There would be play on the top shaft if there was no slipper assembly installed yet too.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 06-12-2013, 08:42 AM   #7223
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Originally Posted by mikeyscott View Post
I'm about to convert my RB6 to a Vega Mid. Suits UK tracks better
Is this the conversion your talking about?
http://www.teamxtreme.co.uk/store/ve...rsion?cPath=1&
Also, what didn't you like about the RB6's mid motor layout?
RCBuddha is offline   Reply With Quote
Old 06-12-2013, 09:21 AM   #7224
Frank L's Avatar
Trader Rating: 148 (100%+)
I ended up with 1 too many. Low use car...
Rb6 exotek - reedy sonic - rs pro - KO one10
Old 06-12-2013, 01:46 PM   #7225
justpoet's Avatar
Trader Rating: 16 (100%+)
Sorry for the list of questions, but...
I'm likely picking up one of these used without any upgrades to get back into 2WD Buggy. What have turned out to be the must have upgrades (both durability and performance)?
I saw the Avid heavy duty rear axle announcement, anybody have thoughts on those? Which line axle are they equiv to?
Wide vs narrow rear holders, do the narrow ones also help with on power rear traction AFTER the turn is completed? That's where I've typically wanted more traction when I ran my RB5 and tested a friend's car (I'm decent with my finger, but would like to be able to push harder once squared up).
I've skimmed enough to see a bunch of talk about changing arms, what is the net change this is causing vs stock arms, and what is the reason for it?
I generally will be running a medium bite indoor damp packed dirt track (where b4.2's have taken over, including for the original owner of the RB6)...but I just can't bring myself to join the AE herd.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 06-12-2013, 04:19 PM   #7226
silvalis's Avatar
Read post #1
The main purposes of these are to extend the threaded area and thicken the shaft. Should fit 3rd party wheels that are shared with the B4.2 better.
narrow hangers will raise your rollcentre, which should give you more lateral traction (and less forward traction)
better for high traction tracks
Old 06-12-2013, 09:00 PM   #7227
Joe,
You were correct. I didn't have the long screws tightened down enough. It is all good now.
Thanks for your suggestion.
Mark
Old 06-12-2013, 09:12 PM   #7228
Can the mid motor use saddle packs? I don't have any shorty, only saw shorty setups on petitrc
zzztech is offline   Reply With Quote
Old 06-12-2013, 09:38 PM   #7229
Yes.
Shimmy is offline   Reply With Quote
Old 06-13-2013, 12:19 AM   #7230
Yes
Inconsistent
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
