    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 06-10-2013, 07:51 PM   #7201
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Is there anyway to run thicker front hexes?
RCBuddha is offline   Reply With Quote
Old 06-10-2013, 07:54 PM   #7202
Why the 6 can move the front axle +/-3mm in or out?!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 06-10-2013, 08:33 PM   #7203
silvalis's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Jam-Air View Post
Why do some run the rb-5 front axle on the 6?
usually due to 3rd party wheel hex depth. K fronts have a shallow hex.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 06-10-2013, 09:00 PM   #7204
RCBuddha's Avatar
see below
I have a few B4.2 wheels left over which I would like to use up.
Old 06-10-2013, 09:39 PM   #7205
silvalis's Avatar
see below
Alternatively you can use the rb5 axles which you can put your own hex on.
Old 06-10-2013, 09:40 PM   #7206
RCBuddha's Avatar
That's what I thought, thanks!
On another note: Did someone compile a list of screws for the RB6? I could swear Bob Barry had a list going...
Old 06-10-2013, 09:45 PM   #7207
Reason I mentioned you can move the axle in or out is I usually run pl front wheels which have a deep hex. I just move the axle out and all is good by just flipping the spacers. Just saying you can get the proper width to run almost any front wheel just need to figure out what spacers need to go where to achieve it without spending the cheddar for different hexs.
www.OHRCR.com
Old 06-10-2013, 10:04 PM   #7208
Teambcw's Avatar
Trader Rating: 28 (100%+)
So.... You can run b4.2 front and rears on the RB6? Sorry I am just confused
OCRC / C$ race setups ...... And my Wife
Teambcw is offline   Reply With Quote
Old 06-10-2013, 10:59 PM   #7209
Yes you can but the rears will be slightly narrower overall by just a hair. If its an issue you can go with the longer rear axles with three lines for full adjustability front and rear.
www.OHRCR.com
Old 06-10-2013, 11:54 PM   #7210
skengines's Avatar
Trader Rating: 226 (100%+)
How is the rear track adjusted? I see the three lines but unsure on how to adjust the width.
skengines is offline   Reply With Quote
Old 06-11-2013, 09:39 PM   #7211
Just ordered a car today that I will pick up and start building tomorrow. Anyone have a good set up for stock mid motor? I'm replacing a b4.2 with my new rb6
Can't get good consistent traction with my b4.2 at my home track which is hard pack with a bit of fine fluff. Took it to a clay tack though and it was good. Thought about an xfactory car just got tired of waiting
Jam-Air is offline   Reply With Quote
Old 06-11-2013, 10:50 PM   #7212
Trader Rating: 19 (100%+)
What are the differences between the different arms, hubs and other little bits?
Like "type B" hubs, "middle arms", "type B" pivot block etc...
Also the difference between normal flat rear arms and the gulwing ones?
Shimmy is offline   Reply With Quote
Old 06-11-2013, 11:46 PM   #7213
john watkins's Avatar
Trader Rating: 17 (100%+)
Does anyone have a pic of their flat rear arms installed on their car?
XB2, XB4 '15, XB8 T5, B5m, Keilor off road RC car club.
Proudly Sponsored by:
Xray racing, Nosram, Proline AUS, B-Fast RC ,Much More , Hudy, JAD racing shells , Xray Racing Australia, Misfit RC Design Group, BFast RC .
john watkins is offline   Reply With Quote
Old 06-12-2013, 12:17 AM   #7214
silvalis's Avatar
bit hard to see... http://www.petitrc.com/setup/kyosho/...ace2013012427/
hara has flat arms here (mm) http://www.petitrc.com/setup/kyosho/...ace2013012427/
Old 06-12-2013, 01:48 AM   #7215
I'm about to convert my RB6 to a Vega Mid. Suits UK tracks better
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
