    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 06-09-2013, 09:31 PM   #7186
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by ryanpatrickgore View Post
You do Brandon? At brcr? I know traction can be great there.
When traction is super high (after a fresh layout on slicks or ghost pins), I do... after 3 or 4 weeks, I go back to 0s.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-10-2013, 12:56 AM   #7187
eper's Avatar
Trader Rating: 14 (100%+)
guys if you put the wing on the buggy and take a sharp cutter and remove the little body clip nipple you can drill a hole and tap it to use screws as wing mounts. then you can use and shim any thickness wing.. I ad a nut under the wing mount for piece of mind
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-10-2013, 09:34 AM   #7188
offroad dude's Avatar
Trader Rating: 25 (100%+)
You got any pics of this?
offroad dude is offline   Reply With Quote
Old 06-10-2013, 10:05 AM   #7189
Super Moderator
Trader Rating: 17 (100%+)
just picture 8th scale wing mount.....how you screw the wing in from the top.
cut the nipple off on the existing wing mount so that the top of it is flat. take a small drill bit and make a hole. Use 4-40 screws (they tap plastic better) and thread the screw all the way down through the mount. put a lock nut on the other side when done.
Tip.....use a 3/32 cap head screw to 'tap' the threads. then switch to a 1/16th counter sink along with a counter sink washer for a cleaner look after you have the hole cut right
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-10-2013, 10:16 AM   #7190
Super Moderator
This is what I did when I ran the RB5, but the RB6 wing mounts are much skinnier, and it doesn't look like there would be enough material around the threads of the screw to work. Maybe something smaller than an M3 might work.
Did you get an M3 screw to work?
- RCSpecialties -
Old 06-10-2013, 10:31 AM   #7191
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Did jconcepts or exotek say they are doing aluminum mounts? My only concern is that the mount sticks on the hard to get to gear box rather than just the tower. So aluminum there might be a bit risky if the gearbox breaks.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-10-2013, 10:37 AM   #7192
Suspended
Trader Rating: 23 (100%+)
Does the JC b4/t4 almunium wing mounts fit on the RB6?
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 06-10-2013, 11:20 AM   #7193
aloksatoor's Avatar
Not sure. Don't know anyone who has tried it yet.
Old 06-10-2013, 11:25 AM   #7194
MikeXray's Avatar
Trader Rating: 73 (100%+)
Visually look very different..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-10-2013, 03:56 PM   #7195
eper's Avatar
i use m3 screws. counter sunk with counter sunk washers just like bob barry said
new milford ct,
Old 06-10-2013, 06:10 PM   #7196
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
That's just wrong...
Rb6 dosent deserve such treatment
ryanpatrickgore is offline   Reply With Quote
Old 06-10-2013, 06:19 PM   #7197
Trader Rating: 41 (100%+)
Send a message via Skype™ to StockRacer
JC has mounts in the works I believe
Ben
StockRacer is offline   Reply With Quote
Old 06-10-2013, 06:50 PM   #7198
Trader Rating: 31 (100%+)
Default Rb6 wanted
Hi Guys,
Looking for an RB6 roller, anyone have one they want to offload? PM Me.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 06-10-2013, 07:12 PM   #7199
Super Moderator
Yeah I talked to Paul Wynn and he said the RB6 wing mounts are in the works.
Old 06-10-2013, 07:34 PM   #7200
Why do some run the rb-5 front axle on the 6?
Jam-Air is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Today 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
