    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree18Likes
Old 06-02-2013, 09:30 AM   #7051
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Bob Barry View Post
I switched from 4.2 to RB6 and I love it. But make no mistake, you aren't going to switch from one to the other and get miraculously faster. I personally am quicker with the RB6, but I don't know how much of that can be attributed to the car or the track just getting better. I'm sure a bit of both.
anyway the build and quality are not even comparable. You can't really understand it until you have experienced it. RB6 just wins hands down.
Performance on the track: anything that my 4.2 did, the RB6 did better. It's incredibly stable, while maintaining that aggressive feel. I've tried several setups and each worked well. I can't say for certain which setup is the fastest yet, but again, I have less than 30 packs through the car.
That brings me to my question for the others. I noticed on most setup sheets, the anti-squat is left blank. does this mean you guys are all running with no shims under both the front and rear hangers? I tried adding a 1mm shim under the front hanger but didn't get a real chance to see how I liked it as I broke after a few laps.
I did have a shim under the RF hanger. I believe a 0.5 = 1 degree antisquat. I used to run in the rb5 with that for more steering on power. In the 6 I never felt a need. I did run it with the 6 chassis once but did not like it for outdoors (indoors it was a bit better). I prefer the stock setup better, and use droop instead now to control the amount of weight transfer front and back.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 06-02-2013, 09:33 AM   #7052
aloksatoor's Avatar
Originally Posted by steam View Post
The XB4 knows how wings should mount.
Thats one of the worst designs actually for me. I have broken a total of 4 xray wing mounts (the part behind the screw threads), the tabs stick out too much at the rear, theres no flex at all and the lexan wings too stifff as well. So basically the wing wins over the mount always. I personally found the older schumacher mount with the orings a really good one. Never broke a wing as well as a mount but it was a bit tricky to replace wings. http://www.amainhobbies.com/product_...oad-Wing-Mount
Old 06-02-2013, 09:37 AM   #7053
Super Moderator
Trader Rating: 17 (100%+)
ok cool. So how much anti is built in if you use no shims and alum hangers?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-02-2013, 05:05 PM   #7054
Mxer59's Avatar
Trader Rating: 114 (100%+)
There's a team driver at my track and he told me to remove the shims and run them flat on chassis for better forward bite
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 06-02-2013, 05:07 PM   #7055
Mxer59's Avatar
Most of you guys running wide or short rear hinge pin holders
-wanting to pick up alum ones so wanting to make sure I grab the right ones and the zx5 plastic bushings so no metal on metal
Futaba 4pls
Team Chase 2015
Old 06-02-2013, 05:13 PM   #7056
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I'm liking the wide so far everywhere.
http://www.exotekracing.com/kyosho/
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 06-02-2013, 05:27 PM   #7057
RShockley's Avatar
It seems to be different for everyone. I really like the narrow holders. Try both of the plastic holders and see which one one like more.
Richard Shockley
Kyosho RB6 / Kyosho RT5
Mike's Hobby Shop......Carrollton, TX
Kalgard / Epic Cameras / SMX Optics / Heavenly Hobbies
RShockley is offline   Reply With Quote
Old 06-02-2013, 06:19 PM   #7058
Mxer59's Avatar
Do you guys have a part number for the bushings that go in hangers once you run alum?
Futaba 4pls
Team Chase 2015
Old 06-02-2013, 06:27 PM   #7059
RShockley's Avatar
KYOLAW32
Richard Shockley
Old 06-02-2013, 07:24 PM   #7060
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by moto44 View Post
Just sold my B4.1 and was going to pick up a B4.2 kit to build for the fall. I was thinking of maybe giving the RB6 a shot. Any body make the jump and how do the two cars compare? Thanks
Made the switch... Not going back. This platform is superior!
ryanpatrickgore is offline   Reply With Quote
Old 06-02-2013, 08:11 PM   #7061
Trader Rating: 50 (100%+)
Any aftermarket washers that I can purchase. Need a lot .5 mm
Thanks to my sponsors:
My Credit Card
Speedychris22 is online now   Reply With Quote
Old 06-02-2013, 08:21 PM   #7062
Suspended
Trader Rating: 23 (100%+)
Avid came out with some. Check them out.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 06-02-2013, 11:34 PM   #7063
steam's Avatar
anyone making Red washers anymore?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 06-02-2013, 11:38 PM   #7064
aloksatoor's Avatar
2 degrees.
Old 06-03-2013, 12:08 AM   #7065
lbckevin's Avatar
Trader Rating: 91 (99%+)
Top racing...an on road company has them
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22972 Today 04:13 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
