    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 05-28-2013, 07:04 PM   #6961
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yes. although some will tell you that there are small variances in the offsets of some rims.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-28-2013, 07:04 PM   #6962
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by skengines View Post
This is my first K buggy and I don't regret my purchase.
All the parts look top notch and I will be starting my build this weekend. I've been running the AE buggy and Durango for the past few months, so I needed something different.
Awesome. I can't say anything bad about the way the AE drove. I just had a man crush on the RB6 from the first time I saw one
I've only had a few weekends with it and I really like it. I am on average 25 sec faster (over 6 min) than I was with my 4.2 and I am just starting to play with setups. Can't say how that is going to translate over the long haul, but so far so good.
I don't have the quantity of competition that you guys out west have, but I am lucky to have a couple of guys who are blazing fast to set the pace and race against. Just wish I could get more practice in.... that's what is killing me now.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-28-2013, 07:07 PM   #6963
It is because he have a lot of traction heros out in the west, lol. I actually can do well when the traction is crap, lol. When the traction comes up, I get spanked, lol. oh well.
Old 05-28-2013, 07:08 PM   #6964
Super Moderator
Originally Posted by Team G Racing View Post
Are the wheels the same as the Associated buggy? Front and rears?
The front fit if you either chamfer the hex or space the hex out. Otherwise they hit the steering knuckle.
The rear fit ok, but couple of guys showed that they are about 2mm narrower. 4mm narrower overall is a big change. I personally switched over to KY rims.
What I suggest is use what rears you have but stock up on KY rims and start mounting all your new stuff on them. I would change fronts right away so you dont have to space out the hex.
Speaking of which, I have about 22 pairs of mounted tires that I need to sell now :P
Old 05-28-2013, 07:10 PM   #6965
I also gained about 26 seconds over 6 minutes when I ran the rb6. Its a really nice car to drive. I dunno about the cost over a year though. I dont replace parts when ever they get a little slop, lol. I only replace bent or broken parts. Which means mostly a-arms and motor plates.
Old 05-28-2013, 07:10 PM   #6966
Send a message via ICQ to JiuHaWong
(a while back) kdub of Avid said they are working on new hexes for the Rb6 to work better with the Avid rims.
JiuHaWong is offline   Reply With Quote
Old 05-28-2013, 07:10 PM   #6967
Suspended
Trader Rating: 23 (100%+)
I run borrego rims.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 05-28-2013, 07:11 PM   #6968
gelshocker's Avatar
Tried some JC mono rears and the rim is loose when mounted. Definately need serrated nuts. If you insert some Tamiya wheel spacers (comes in 0.5 and 1mm) to correct the offset there's not enough thread for the serrated nut. Stay with K rims.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-28-2013, 07:11 PM   #6969
Suspended
I just looked on DE's websight and there rims fit Rb6, Rb5, and Associated, so I think I am good?
Old 05-28-2013, 07:12 PM   #6970
I thought the jc were the main issues. The aka, avid rear and DE were fine. Also, I ran the aka up front without issue.
Old 05-28-2013, 07:15 PM   #6971
Peopel are basically saying that different companies dont have the exact same offset as the K wheels. Which means, they probably were not consistent on the b4 either. They are also talking about the B4 JC wheels. Not the JC tlr22 wheels which are slightly different. I doubt most will be able to feel the different though.
Old 05-28-2013, 07:56 PM   #6972
caguilar4's Avatar
Originally Posted by mingoglia View Post
Would be cool if they built a new ST as well.
I am actually waiting for a SC truck based on the RB6 platform. Does anybody know something about it?
Im not thrilled about SC, but is the most popular class at my local track. There are somedays that there is not one buggy running but mine.
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 05-28-2013, 07:59 PM   #6973
Originally Posted by iterator View Post
Some killer video of our local team driver running some smoking fast laps with his RB6 at Tacoma RC Raceway. I also put together his setup sheet along with close up photos, available here. I got a chance to drive it.. super dialed.
+ YouTube Video
Was curious to see this setup but apparently my iphone feels the need to just show me a blank setup sheet.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-28-2013, 08:02 PM   #6974
RodneyB's Avatar
The rumor is fourth quarter 2013.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 05-28-2013, 08:42 PM   #6975
Super Moderator
I have a craptastic amount of Proline and JC rims... they are both a bit 'off' I actually preferred the Proline rims over the JC because of the recessed wheel nut and the JC have that ugly matte finish
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 10-20-2017 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
