    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-24-2013, 11:16 AM   #6901
aloksatoor's Avatar
Trader Rating: 42 (100%+)
X2 on that. I have the kyosho part on my mod buggy for the past month its got no slop still. The exotek is a backup part now. Also get some rear hubs if your LHS does not carry them that and the rear bulkhead for RM config, some people have had issues with the studs stripping the plastic.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-24-2013, 12:11 PM   #6902
Send a message via ICQ to JiuHaWong
http://www.liverc.com/news/new_produ...is_protectors/
JiuHaWong is offline   Reply With Quote
Old 05-24-2013, 12:28 PM   #6903
stanky626's Avatar
Nice memorial day sale on the Kyosho RB6 from Speedtech Hobbies.
http://www.speedtechhobbies.com/inde...roduct_id=1387
Kyosho RB6 - Tamiya 417X - Losi 5ive-T
SpeedtechRC.com
stanky626 is offline   Reply With Quote
Old 05-24-2013, 12:38 PM   #6904
skengines's Avatar
Trader Rating: 226 (100%+)
Originally Posted by desertracerdad View Post
I bought and raced with both the Exotek & Kyosho aluminum steering racks... The Kyosho setup has no "slop" and the Exotek rack needs a bit more attention with shimming. The K rack tolerances are just better, so if you have the budget to buy it, I would recommend it. Also, the newer RB6 kits should have the revised aluminum front hinge pin brace in the kit already.
Do you have the rack and arm, or just the rack?
skengines is offline   Reply With Quote
Old 05-24-2013, 12:45 PM   #6905
mkorn's Avatar
I built an RB6 for myself a few weeks ago and finally got around to testing it. I ran at a small indoor clay track and I was blown away at how well the car worked. Stock setup and not a single option part. I did bend the front hinge pin brace but it was a hard landing.
If the car works as well outdoors as it does indoors I'm pretty sure it will be what I run at the worlds. Still going to stay with the B44 for 4wd.
Marty Korn
USA Team Manager
A Main Hobbies
ProTek R/C
SWORKz USA
mkorn is offline   Reply With Quote
Old 05-24-2013, 12:52 PM   #6906
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
The rb6 is a sweet ride and very planted out of the box. I am sure it will work well at the worlds. I kinda think the Tebo has a shot this year.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-24-2013, 01:51 PM   #6907
Trader Rating: 101 (99%+)
I run both the Kyosho crank arms and rack (UMW701 & UMW702). When i upgraded, I started with fresh steering king pins (LA256), so the entire assembly was tight and will all wear together.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Old 05-24-2013, 01:58 PM   #6908
skengines's Avatar
Do you run the exotek rear bulkhead for RM?
Just want to make sure I'm ready. My track doesnt carry K parts.
Old 05-24-2013, 02:00 PM   #6909
That is a good price!
Old 05-24-2013, 02:08 PM   #6910
aloksatoor's Avatar
That store is my fav for buying kyosho stuff. Now if only they start carrying xray and 1/8 scale stuff . Best price and run by awesome ppl as well!
Old 05-24-2013, 02:30 PM   #6911
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Out of stock...
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 05-24-2013, 03:09 PM   #6912
Yes...
Old 05-24-2013, 03:16 PM   #6913
fullsyzz's Avatar
Trader Rating: 102 (100%+)
Apparently Kyosho has decided to rename the UMW701 aluminum steering plate.
fullsyzz is offline   Reply With Quote
Old 05-25-2013, 03:50 AM   #6914
Den303's Avatar
Hi,
has anyone tried the AVID TRIAD slipper in mid motor mod on astro/carpet ? What are your experiences ? If not what do the dirt racers say ? Worth the money ?
Thanks.
Den303 is offline   Reply With Quote
Old 05-25-2013, 05:10 AM   #6915
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Bob Barry View Post
Let me know if you need an ESC setup.
hey bob i am sending you a pm
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
