    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree17Likes
Old 05-22-2013, 06:34 PM   #6886
silvalis's Avatar
Trader Rating: 29 (100%+)
+1 on the LRP/nosram x20 motors. Huge torque.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-22-2013, 07:41 PM   #6887
mingoglia's Avatar
Well as long as we're listing electronics.... LRP Flow Works and Reedy Sonic Mach 2 8.5 (wow, that's a long name). Currently 78/22 but plan on trying out 78/21 this weekend since it's a smaller tighter track.
mingoglia is offline   Reply With Quote
Old 05-22-2013, 09:12 PM   #6888
lbckevin's Avatar
Trader Rating: 91 (99%+)
Running the new Tekin gen2 speedo ....real nice.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 05-23-2013, 02:02 AM   #6889
eper's Avatar
Trader Rating: 14 (100%+)
im going to be trying the viper vtx10r-be and a viper 7.5. hopefully get to run it this weekend
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 05-23-2013, 06:05 AM   #6890
Super Moderator
Trader Rating: 17 (100%+)
Let me know if you need an ESC setup.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-23-2013, 09:07 AM   #6891
skengines's Avatar
Trader Rating: 226 (100%+)
Just picked up an RB6. Definitely looking forward to trying this kit out.
I wasn't too happy with the Durango DEX210. Poor build quality and it didn't got well together like my DEX408.
skengines is offline   Reply With Quote
Old 05-23-2013, 10:27 AM   #6892
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I was one of the early guys running the 210... nothing felt better than going back to Kyosho. The RB6 delivers on all accounts.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-23-2013, 12:28 PM   #6893
wild gopher's Avatar
Trader Rating: 39 (100%+)
I'm testing this new bad boy tomorrow night! Cant wait
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 05-23-2013, 09:08 PM   #6894
Not exactly an Rb6 question but ill post it here. Has anyone run a boosted 17.5 setup with the Orion Esc in an Rb6? I need gearing as well as motor timing and Esc settings if possible or at least something to get me started and close without blowing anything up. Thanks in advance!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-23-2013, 09:12 PM   #6895
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I normally drop 2-3 teeth and put in about 20% timing anf 1/2 that in turbo. no motor timing.then increase the esc timing based on temps. I started out a 28/76
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-23-2013, 09:55 PM   #6896
skengines's Avatar
So I'm picking up some spares for my Rb6 before it gets here.
It looks like I may be getting the exotek rear bulkhead and steering rack/crank.
Is the front bulkhead a necessary upgrade or are you guys running the plastic one? I know for the B4.2 the AE drivers used the plastic one for more flex but not sure if this applies with the rb6.
Anything else I should pick up?
Old 05-23-2013, 11:10 PM   #6897
umm winning's Avatar
Really all you need is the aluminum steering rack. Most of the other alum. Upgrades really just give you a piece of mind that the part will not break. For spares you should only really need the typical spares, I.e. arms, towers... Etc. The rb6 is truly a tank when it comes to durability. IMO As for the alum. Front Bulkhead I don't see a need in it, to be honest drive it and decide from there.
umm winning is offline   Reply With Quote
Old 05-24-2013, 12:02 AM   #6898
pekow91's Avatar
Trader Rating: 45 (100%+)
Check out the Kyosho High Strength SP Front Suspension Plate (Type-B)
[KYOUM720B].
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 05-24-2013, 01:53 AM   #6899
eper's Avatar
rear suspension arm hangers are a definite
new milford ct,
Old 05-24-2013, 10:37 AM   #6900
Trader Rating: 101 (99%+)
I bought and raced with both the Exotek & Kyosho aluminum steering racks... The Kyosho setup has no "slop" and the Exotek rack needs a bit more attention with shimming. The K rack tolerances are just better, so if you have the budget to buy it, I would recommend it. Also, the newer RB6 kits should have the revised aluminum front hinge pin brace in the kit already.
~ Richard Watchorn ~
* Team Associated/Reedy Electronics * OCRC Raceway *
* Schelle Racing * CBuilt Designs * Complex Ink *
desertracerdad is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22971 Yesterday 08:14 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
