    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 05-16-2013, 01:59 AM   #6826
Originally Posted by joecool View Post
Just spent all night changing my car from rear motor to mid motor. Gonna race it on carpet this summer. Anyone have tips for setting a car up on carpet? I usually add camber to the front and rear, last year I had about 3 degrees. 5wt thicker oil in shocks. Used 30 degree kick up. And basically left everything else the same.
Good place to start: http://www.petitrc.com/setup/kyosho/...stone20130209/
Its astroturf, but grip levels are more similar to carpet.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Old 05-16-2013, 02:02 AM   #6827
silvalis's Avatar
Trader Rating: 29 (100%+)
whats that thing on your spur? slipper eliminator?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-16-2013, 08:56 AM   #6828
Den303's Avatar
Default Exotec Aluminium Hangers
Hi,
I'm racing my RB6 since end 2012. Great car !
Just one short question: is anyone running the exotec aluminium hangers ? aspecially in mid motor ?
Which inserts do you use with it ? Simply stock (KYOLAW39) ?
Regards.
Dennis
Den303 is offline   Reply With Quote
Old 05-16-2013, 11:31 AM   #6829
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yes. speedtech hobby turbo hub with a TC 64p spur.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-16-2013, 11:34 AM   #6830
aloksatoor's Avatar
Originally Posted by Den303 View Post
Hi,
Regards.
Dennis
No use the delrin ones. The stocks are only good for plastic.
Old 05-16-2013, 12:27 PM   #6831
Send a message via ICQ to JiuHaWong
Do you have any closeups of the turbo hub?
JiuHaWong is offline   Reply With Quote
Old 05-16-2013, 12:30 PM   #6832
aloksatoor's Avatar
You do need the avid top shaft for the speedtech part to work but the speedtechs the best machined part out there. I have the customworks one and thats sloppy $hit. Also can use the perfect size spur gears for moving motor closest to the axles while maintaining FDR required for stock.
Old 05-16-2013, 02:32 PM   #6833
Looks like a RW Racing spur
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 05-16-2013, 02:56 PM   #6834
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I made a couple of big changes to my car this last weekend and loved the result. Instead of moving to mid-motor, I decided to try and get my motor as close to the gearbox as possible im RM config, and went with the longest rear wheelbase setting. The car was a blast to drive! Less pendulume affect, more stable, faster in the sweeper, and I could push the car harder everywhere on the track. All I changed was:
- Switched to IONs all around, from gold barcodes
- Geared at 66:30 (puts motor all the way forward for 17.5)
- Ran rear hubs all the way rearward.
Can't wait to run it again like that this weekend.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-16-2013, 03:15 PM   #6835
Any idea how the speedy's racing part fits? Also, what is the screw thread for the speedtech turbo hub? Metric or SAE?
Old 05-16-2013, 04:10 PM   #6836
aloksatoor's Avatar
Speedys I did not buy. I had placed an order but cancelled it since did not have the avid top shaft. I think its the same as the custom works part. For the speedtech hub its m3 screws. But the spur floats lengthwise on the top shaft so needs securing with that 4 mm spacer I put in the pic (had a spring before that works too).
Yes its a machined rw spur from my xray tc.
Old 05-16-2013, 04:11 PM   #6837
aloksatoor's Avatar
Nice was the battery all the way ahead as well?
Old 05-16-2013, 04:29 PM   #6838
Super Moderator
Nope, kept the shorty dead smack middle like I have always run it. There certainly isn't a shortage of weight up front, so i didn't feel a need to move more weight forward. Seems like a really really good balance right now...
- RCSpecialties -
Old 05-16-2013, 08:08 PM   #6839
What did you use for inserts? Have you tried pressure points?
Turbo
Turbo911 is offline   Reply With Quote
Old 05-16-2013, 09:08 PM   #6840
Super Moderator
Turbo
Broken in (second set of tires) red AKA closed cells.
- RCSpecialties -
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
