    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 05-15-2013, 06:58 PM   #6811
gelshocker's Avatar
Not nick picking is any way, but dimensions are a factor in the 6 as its tight (pardon the pun
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-15-2013, 06:58 PM   #6812
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by silvalis View Post
yes. just update the box software.
I run a vtx10 (44g or somehting). chopped the caps (black caps) off and put a hobbywing 4x capset alongside. fits fine. the older ones with silver short caps will fit under fine. Have a couple of BE's (56g) sitting there but never tried to fit it.
VTX10R is a bit heavy (75 for be. orange was 80-something?), but lighter than the hobbywing (93, stock is 40 or something). BE non-R are heavier than the oranges, but they have larger caps. Go figure.
IIRC the VTX1 is the lightest...
The hobbywing is only 44grams on my scale (just 120A esc no caps wires). Wires might be another 10 15 grams but its not the advertised 93 grams for sure. Anyone tried the new exotek hinge pin braces yet? How are they holding up compared to the part B from kyosho?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-15-2013, 07:02 PM   #6813
silvalis's Avatar
Trader Rating: 29 (100%+)
v3? stock spec or the mod one? Maybe I should switch... ha.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-15-2013, 07:15 PM   #6814
aloksatoor's Avatar
No I dont have the stock spec. Its the regular red v3 which sells for around 167 shipped from falcon. I did not go for the v3.1. The spec on the falcon site is wrong its not 93 grams at all .
Check this out on amain its similar casing, maybe more FETS on the orion but 40ish grams
http://www.amainhobbies.com/product_...-ESC-160A-2-3S
http://www.amainhobbies.com/product_...-ESC-120A-1-2S
Old 05-15-2013, 08:05 PM   #6815
gelshocker's Avatar
Originally Posted by Wildcat1971 View Post
I kinda wanna try the v3.1 but out of my price range. Will the old lcd boxes work with the 3.1
LOL the 3.1 is much cheaper than the Viper. I have a 2.1 and no quarms about it for its intended use, practising and bashing. If I were to get another HW I'll need another card so I wouldn't have to update the software each time between different ESCs.
I've only heard good things about HW, but you know how it is, it wouldn't be as fun if it was easy Plus I'll have more range of HV servos to choose from.
Kyosho RT5 | RB6
Old 05-15-2013, 08:08 PM   #6816
gelshocker's Avatar
The HW 3.1 is entirely metal casing, the R10 has plastic bottom.
Kyosho RT5 | RB6
Old 05-15-2013, 08:29 PM   #6817
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Speed Passion and call it a day. Has built in switch and can handle HV servos. You can buy yourself tires with the money you save. You can never have too many of those.
http://www.amainhobbies.com/product_...sored-ESC-Blue
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 05-15-2013, 08:43 PM   #6818
Default Outdoor Season
Getting ready to head outdoors. We have our first race of our series indoor this Saturday and then it is outdoors until the final race in October which is back indoors. Have been running shorty pack for indoors. Considering running saddle packs or full pack for outdoors for addition weight due to less traction. Anybody have some thoughts on this.
Turbo
Turbo911 is offline   Reply With Quote
Old 05-15-2013, 09:12 PM   #6819
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
This won't fit under the I don't think for rear motor
ryanpatrickgore is offline   Reply With Quote
Old 05-15-2013, 09:21 PM   #6820
wrightcs77's Avatar
Trader Rating: 523 (100%+)
I have a NIP Avid Triad Slipper and topshaft if anyone is interested. Also a NIP MIP Super Diff.
Sorry for the spam
PM me if interested.
wrightcs77 is offline   Reply With Quote
Old 05-15-2013, 09:26 PM   #6821
mingoglia's Avatar
I just installed a LRP Flow Works in mine, fit great. Taped it down, then bolted the shock tower over it.
mingoglia is offline   Reply With Quote
Old 05-15-2013, 09:57 PM   #6822
Well finally back into an Rb6 I went full circle. Revisited the 22 and B4 and both left me wanting more so snatched up an Rb6 again. Now I'm looking for an easy mod setup to start working on. If anyone has one that I could try post up. Mainly clay tracks one dust normal tires are hb beams, ions, etc in ss or m4.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 05-15-2013, 11:36 PM   #6823
jkirkwood's Avatar
The Reventon Pro does. Not sure about the others in the Reventon line. I have one mounted under the shock tower with all stock parts.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 05-15-2013, 11:56 PM   #6824
joecool's Avatar
Trader Rating: 19 (100%+)
Just spent all night changing my car from rear motor to mid motor. Gonna race it on carpet this summer. Anyone have tips for setting a car up on carpet? I usually add camber to the front and rear, last year I had about 3 degrees. 5wt thicker oil in shocks. Used 30 degree kick up. And basically left everything else the same.
Joe Cool
Kyosho America, Team Orion, Ko Propo
joecool is offline   Reply With Quote
Old 05-16-2013, 01:19 AM   #6825
aloksatoor's Avatar
Heres mine with the hobbywing v3.0 in mid motor 1520 rtr with transponder converted from old rb5 for stock duty.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22979 Yesterday 10:09 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
