    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 05-15-2013, 09:30 AM   #6796
gelshocker's Avatar
Originally Posted by Wildcat1971 View Post
yeah, dont get the R, its too tall to fit under the rear bulkhead. And I would get the BE because then the caps wont be in the way. The R is also like 20 grams heavier.
Cheers. I have the Exotek alum rear bulkhead if I ever run RM, which should provide more clearance.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-15-2013, 10:55 AM   #6797
aloksatoor's Avatar
Trader Rating: 42 (100%+)
I'd recommend the HW v3* in the 6. It fits perfect in mid and rear motor configs and the wirings very tidy because of the switch. Plus the BEC wire is the exact length to run through the side channels no trimming required. Also switching to blinky mode is just a profile change. It has enough horsepower to keep all firmwares on board and data logging as well. Power turns off when u hold brake for 6 seconds, helps a lot when running back to back heats!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-15-2013, 03:54 PM   #6798
Originally Posted by IRM616 View Post
again any advice on shim for steering would be helpful, like what size and approx. how many to use or start at. thanks
If stock follow the Kyosho manual.
If you have an Exotek rack, they gave some drawing and suggestions about shimming. It works for me since November.
Got quite a lot of play now, without noticing a big impact on lap time/handling.
Wear is created between metal bushings and alloy rack, nothing to do about it after a while. I would have tried Teflon shims between bushings tops and rack but I ordered a Kyosho alloy rack and arms instead.
mojo tom is offline   Reply With Quote
Old 05-15-2013, 04:00 PM   #6799
aloksatoor's Avatar
I have both brands on my two cars with brand new bushings (had massive play with the exo part as well ran for a winter season every week almost ~ 3 months). I will update which ones last longer. The exotek aluminum rack with al arms and the kyosho ones on the mod buggy. I have a feeling the kyosho will outlast since its made of weaker aluminum.
Old 05-15-2013, 05:18 PM   #6800
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by ryanpatrickgore View Post
I would run the vtx10 as supposed to the "r" version for buggy unless your trying to run an outrageous mod motor. Because it is a bit lighter. My r was pretty heavy
the R is 19 grams heavier. You don't need an R though unless you run 4wd or below 6.5T. I am referring to the Black Edition of course.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-15-2013, 05:22 PM   #6801
Super Moderator
According to our site, Black Edition esc's are the same dimensions. I haven't needed an 'R' yet so I have to go by that.
VTX10 BE
Dimensions: 30x32.5x16mm
WEIGHT (without wires):56g
VTX10R BE
WEIGHT (without wires):75g
http://www.viper-rc.com/vtx10_r_be.php
Old 05-15-2013, 05:38 PM   #6802
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I run the orange ones and theh are lime 5mm taller
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-15-2013, 05:40 PM   #6803
gelshocker's Avatar
Lol you may wish to update the download PDF, the R is taller at 20mm
Agreed for 2wd buggy won't need the R and added weight/less turns than 6.5.
Cheers,
Kyosho RT5 | RB6
Old 05-15-2013, 05:40 PM   #6804
Grrr phone
Old 05-15-2013, 05:41 PM   #6805
Super Moderator
Agreed for 2wd buggy won't need the R and added weight. Cheers,
the R for the Black Edition or the Orange? I looked and you're right about the Orange, but I specified the Black Edition.
Old 05-15-2013, 05:44 PM   #6806
gelshocker's Avatar
I download the BE PDF and the stated dimensions are different thx
Kyosho RT5 | RB6
Old 05-15-2013, 05:46 PM   #6807
I kinda wanna try the v3.1 but out of my price range. Will the old lcd boxes work with the 3.1
Old 05-15-2013, 05:51 PM   #6808
gelshocker's Avatar
http://www.viper-rc.com/pclink/updat...manual_A55.pdf
The Rs for both orange and black @ 21mm tall? Thx
Kyosho RT5 | RB6
Old 05-15-2013, 05:51 PM   #6809
Super Moderator
ahh I found it. Good eye. I'll tell Nick so they can correct which ever one is wrong. I'm betting the site is wrong based off what you are saying though.
Thanks!
Old 05-15-2013, 05:55 PM   #6810
silvalis's Avatar
Trader Rating: 29 (100%+)
yes. just update the box software.
I run a vtx10 (44g or somehting). chopped the caps (black caps) off and put a hobbywing 4x capset alongside because the blacks dont let it get fully under. fits fine. the older ones with silver short caps will fit under fine. Have a couple of BE's (56g) sitting there but never tried to fit it.
VTX10R is a bit heavy (75 for be. orange was 80-something?), but lighter than the hobbywing (93, stock is 40 or something). Go figure.
IIRC the VTX1 is the lightest...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
