    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 05-13-2013, 05:00 PM   #6781
IRM616's Avatar
Trader Rating: 29 (100%+)
Send a message via Yahoo to IRM616
Can u advice on what kind of shims bc my steering has lots of play.
Thanks or anyone
Originally Posted by mojo tom View Post
I have to chime in.
I own a lot of 2wd and even if I was not interested at all by Kyosho cars when I get back to the hobby I went naturally to them because the plastic are just great, harldly broke, and because just about every aspect of the car seems very well thought out.
Ballcups never came off (unless a very big crash where another brand of car would have broke wishbones and caster blocks), diffs are the best by far (I run a diff 6 months with a Bfast kit) and shocks are just great.
I race 13.5 boosted so transmission got hit pretty hard on high grip.
So RB6. Just awesome. Since July I broke a front shock tower, a mid rear bulkhead (at the ball end location) and one front wishbone. Got a thread gone on a caster block but I used a too short ball end.
I'm not gentle at all, got a lot of crashes and our club track got a triple jump that is a car breaker.
10 months of very hard use, beside a very hard crash that cost me the rear bulkhead (used on the shortest position, that explain it a bit) and a friend running the car and hit the pipe metal hook at full speed costing me a wishbone I'm looking at a shock tower I broke two days ago. Extremely sturdy.
That means a huge price on parts I didn't have to buy so I'm seriously thinking this car price is rather competitive in the long therm.
Options parts.
I put Lunsford turnbuckles and screws from a previous car RB5 based as well as a set of Boca orange but other than that I race it stock (mid motor).
For my style of driving, alloy steering rack was a must (I broke twice the plastic one at the same race, never had issues after using the Exotek one).
I put old blue alloy hubs from my older K car, might have broke once a ball end thread.
That would be about it if budget is a concern.
I noticed quite some slop from the plastic rear hangers using metal bushing and put some delrin one and it was way better, still is.
Any car needs some slop, at least offroad cars. I noticed right from the build that Kyosho really improve their part fitment over the 5 series, just the right amount of slop.
I have to say the rear/rear hanger in rear motor format isn't as strong as expected so I might advise for that part if you run rear motor.
I did tweak the front hinge pins holder and bent the front brace. Went for an alloy block from Ghea and a custom machined brace.
Considering how happy I am with the car, I'm planning to add more options parts from Kyosho as I have to say they offered the least they could do in the kit. Plastic hangers, plastic steering, plastic hubs, rather thin non ventilated motor plate,... But I will be happy to buy those upgrades parts as I just love the car.
Handling wise, the mid motor car is just amazing, up to the best conversion offered for rear motors cars and that was very hard to nail.
Rear motor is more conventional but yet I felt very comfortable running the car the few times I did. Will do more as we have some races on dirt but I do believe the car is up to the best here too.
Three points to check after 10 months :
- Some wear on diff outdrives and CVD
- Rear plastic blocks slope (might have been too much use of metal bushing)
- Steering parts got some serious slop, mainly due to not shim the Exotek plate and wear from alloy to alloy friction (bushings/plate)
Now I'm eager to see what they could do on the ZX6 !
SikLidz Custom Rc Painting-Coyote RC Raceway-BSR-Kyosho
IRM616 is offline   Reply With Quote
Old 05-13-2013, 07:43 PM   #6782
E73
E73's Avatar
Originally Posted by ryanpatrickgore View Post
Ok how about this...
I need more stabity in the sweeper, it gets a little bit squirley mid corner, an wants to go into the wall. What do you guys suggest.?
When I was in midmotor configuration I could hold throttle all the way through and rail it.
Ryan, I am still learning about setup but have found that increasing the kickup/caster makes the car feel more stable and less twitchy especially in the hi-speed sections. I'm running 30* kickup & 0* caster blocks at TRCR and find it works well for me. That said, Kyosho fast-guy Ryan Matesa runs 25* kickup & 0* caster blocks and he's very fast. He's also an ace driver. My .02.
E73 is offline   Reply With Quote
Old 05-13-2013, 11:27 PM   #6783
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I am running 30* block and 0* inserts . Also the tires are 1/2 worn barcodes with a whole rear stock open cell foam in em. I know alot of guys cut em to 3/4 before putting them in the tire.
I can get through the sweeper fine but it was seriously railing through full throttle when it was mid motor. I recently switched back to rear and that is really the only area I am missing. Maybe I was a bit spoiled with the mm for that section.
ryanpatrickgore is offline   Reply With Quote
Old 05-14-2013, 12:02 AM   #6784
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
I prefer 25/0 as the more caster makes the car hook on exit due to the camber gain.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-14-2013, 01:54 AM   #6785
Try moving the rear shocks in one hole on the tower.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 05-14-2013, 08:01 AM   #6786
Send a message via ICQ to JiuHaWong
http://www.exotekracing.com/rb6-hinge-pin-brace-7075/
JiuHaWong is offline   Reply With Quote
Old 05-14-2013, 11:14 AM   #6787
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Built my second rb6 in mid motor. That thing is light with the mid motor parts for some reason. I just put titanium turnbuckles and aluminum cranks and rack in front. Rest is all plastic and it weighs around 1520 grams RTR (promatch IP shorty, tekin 17.5, hw 3, futaba low pro servo, sanwa receiver,16ga wire). Hope it drives as well as it weighs!!!!
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-14-2013, 07:51 PM   #6788
carver gt's Avatar
Trader Rating: 41 (98%+)
Send a message via AIM to carver gt
Sounds fun! Let us know how MM is compared to rear motor. I am debating converting to MM but would like more input
We support and run-
Team Associated-JConcepts-sticky Kicks RC
carver gt is offline   Reply With Quote
Old 05-15-2013, 12:11 AM   #6789
IRM616's Avatar
again any advice on shim for steering would be helpful, like what size and approx. how many to use or start at. thanks
Old 05-15-2013, 12:55 AM   #6790
silvalis's Avatar
buy some 0.1mm shims and start at 1?
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-15-2013, 05:15 AM   #6791
gelshocker's Avatar
Hey guys, looking to upgrade my ESC on the 6:
HW3.1 or VTX10R-BE? Price not a consideration.
The HW has built-in on/off switch, but the Viper has better specs, lighter, smaller footprint and the BEC would support HV servos.
I'm going for the Viper, unless there are glaring issues I do not know of? Thanks,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-15-2013, 05:41 AM   #6792
Super Moderator
Trader Rating: 17 (100%+)
Cool, if you have any questions or need help setting up your VTX10, let me know.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-15-2013, 08:32 AM   #6793
gelshocker's Avatar
LOL Cheers. My lhs signed up with Viper RC so at least local h/w support is covered. The footprint alone allows me to fit it with a normal sized rx (i.e that is not KO411!) behind the servo on the MM RB6.
BTW, any reliability issues you'll care to share?
Kyosho RT5 | RB6
Old 05-15-2013, 09:07 AM   #6794
I would run the vtx10 as supposed to the "r" version for buggy unless your trying to run an outrageous mod motor. Because it is a bit lighter. My r was pretty heavy
Old 05-15-2013, 09:15 AM   #6795
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yeah, dont get the R, its too tall to fit under the rear bulkhead. And I would get the BE because then the caps wont be in the way. The R is also like 20 grams heavier.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
