    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-09-2013, 08:56 AM   #6736
Moderator
Posvar's Avatar
Trader Rating: 462 (100%+)
I will check tonight and send you a pm......
Having fun with my 9 year old and running Kyosho cars!
Posvar is offline   Reply With Quote
Old 05-09-2013, 09:49 AM   #6737
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Jason.Dias View Post
These? LAW32
Quick question. In your setup sheet which brand of the slipper eliminator hub are you using? I have both the speedtech and the customworks one with avid top shaft. Did you machine your kyosho one?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-09-2013, 10:20 AM   #6738
Hmm... Looks nice!!
New RB6 Alum goodies from RDRP
https://www.facebook.com/pages/REVOL...38618482913017
Stevenich is offline   Reply With Quote
Old 05-09-2013, 10:29 AM   #6739
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by umm winning View Post
@ Cpt. America - With the 12.5mm Hi torque rotor in a Revtech 17.5 does it really bring it to life, compared to a regular Revtech 17.5 w/ a stock rotor and full timing?
Thanks.
It does, but it certainly isn't necessary. We run a 12.3BP in Rachael's RB6, and her car seems just as fast overall as with the high-torque. The more "point and shoot" your layout is, the more the HT rotor will help you. Iv been on some tracks where you have to flip a 180 and get heavy on the gas to make it over a quick jump... the HT rotor really helps in those situations, and can really measure out a faster laptime. On a more sweeping track? Nah, it won't affect your lap times much I wouldn't think.
Originally Posted by silvalis View Post
Brandon, is the battery tiedown strap you are using the kyosho rb5 carbon one cut down? umw503? Any issues with it moving?
Yes exactly.. just a cut down rb5 strap. You need to run the posts in the wider holes in the chassis (looks like they are designed for the rb5 strap). They are slightly farther back, which works perfectly for ditching the rear shelf... I run RB5 battery posts, shimmed up 4mm, with locnuts.
I run the locknuts, and not the thumbscrews, because part of keeping the chassis flexing right, is making sure the battery isn't held down to the chassis. So with the locknuts, you can keep them semi-loose so that the battery strap floats a little bit, and its just tight enough to keep the battery from hopping out of the tray, but loose enough so it's not being pinched, hindering chassis flex.
Originally Posted by pekow91 View Post
I did the same. It holds well and I think it looks a lot cleaner than the stock or exotek setup.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-09-2013, 01:15 PM   #6740
Send a message via ICQ to JiuHaWong
I'm surprised MikeR of Exotek hasn't made a new hinge pin brace for the RB6
JiuHaWong is offline   Reply With Quote
Old 05-09-2013, 01:23 PM   #6741
Super Moderator
Im sure the hingepin brace is next on their list.
- RCSpecialties -
Old 05-09-2013, 01:53 PM   #6742
aloksatoor's Avatar
I hope it has threaded holes so it latches onto their front bulkhead. The bulkhead had matching holes already where the brace sits always wonder what they are for.
Old 05-09-2013, 02:57 PM   #6743
RodneyB's Avatar
Originally Posted by Cpt.America View Post
Well, I'v been running the same Alu-0s for the last 2 years (got them for my rb5, and moved them to my rb6), and they look and feel like they did the day I bought them. Bearing fit is still 100% snug... and I typcaly put in about 15-20+ packs a week, with some weeks reaching 40.
Ran the same 0s on my SC for almost a year (not nearly as much run time), but they were old used ones I got on a different car. They were old blue ones where somebody actually scraped off all the annodizing. they looked like hell from all the use, but the bearing fit/finish/feel was still 100% plush.
So yes... from my experience, they don't wear. (at least at the bearings... they might wear after a long while at the hingepin).
Hmmm maybe it's just me...but then again, why would they fix something that isn't broken? Like I said, wear in the buggy really isn't too bad. Mod SCT is rough on them.
Kyosho America; Peak Racing; Grandview Hobbies; CRCRC
CRCRC club administrator
Kyosho RB6, Kyosho ZX6, Kyosho SC6, Kyosho MP9e TKI
RodneyB is offline   Reply With Quote
Old 05-10-2013, 12:25 AM   #6744
I used a custom method with pencil erasers with no slipper pads locking the disks down.
However now I use the avid triad system with some custom 64p avid spur gears.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 05-10-2013, 09:57 AM   #6745
aloksatoor's Avatar
Oh nice! Any advantages to using the 64 from avid other than getting motor close to the axle?
Old 05-10-2013, 06:32 PM   #6746
B00t13g's Avatar
My rb6 is for sale with every aluminum piece you want/ need. Just FYI.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-10-2013, 10:21 PM   #6747
Smile
Efficiency, finer gear ratio tuning, smoother feel
Jason Dias
Old 05-11-2013, 02:34 AM   #6748
KalEl63's Avatar
Just after some people’s opinions as I am thinking of swapping over form my TLR 22 to an RB6 and wondering the pros and cons of do this in regards to how the RB6 handles to a 22?
Also is there anything people recommend doing to the car while building it?
Team Associated RC10 B6D
Team Associated RC10 B64D
Team Associated RC10 T5M
1.21 GIGAWATTS!!!
KalEl63 is offline   Reply With Quote
Old 05-11-2013, 05:26 AM   #6749
eper's Avatar
Trader Rating: 14 (100%+)
that question has been asked on this forum since page 2.. i think everyone who made that upgrade has been happy the got rid of the 22.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 05-11-2013, 05:57 AM   #6750
Moderator
Posvar's Avatar
You are sooooooo right on this.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Arctic RC
