    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 05-07-2013, 08:24 AM   #6676
CanyonCarverR1's Avatar
Originally Posted by aloksatoor View Post
Anyone run it with the side pods cut down? I normally use only 1 screw in the front and sometimes no stiffening screws at all. Also have no use for the receiver tray. When I get my stock buggy I am going to try to run the diggity cf holders and run a lengthwise velcro to secure the battery. Also maybe run without the spur cover and eliminate slipper thats around 10 grams I think.
What parts are you using to eliminate the slipper?
CanyonCarverR1 is offline   Reply With Quote
Old 05-07-2013, 09:24 AM   #6677
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Howabout running with no side pods?
What effect do you get when running without the shim under the motor guard?
ryanpatrickgore is offline   Reply With Quote
Old 05-07-2013, 09:41 AM   #6678
aloksatoor's Avatar
Trader Rating: 42 (100%+)
http://www.speedtechhobbies.com/inde...roduct_id=2716 with avid top shaft
http://www.avidrc.com/product/5/acce...cessories.html
http://www.speedtechhobbies.com/inde...ry&path=64_190
Jason Dias 17.5 WCRC setup.
If you want to go the cheaper route with the Kyosho top shaft use
http://www3.towerhobbies.com/cgi-bin...?&I=LXZUC5&P=7 this should fit it but no guarantees until I get it in my hands. I ordered it as a spare.
or
http://www.speedysracingparts.com/Lo...eliminator.htm but this guy needs the avid top shaft as well.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-07-2013, 09:45 AM   #6679
aloksatoor's Avatar
For running without side guards, you do need to replace the part where the front tower plate mount sits on the guards. It has some conical thing to grab onto it. Might have to fashion something up or get it in aluminum. Its a reverse conical washer (the closest description). To replace the guards we can use thin carbon fiber or cut up lexan in that shape for sealing (like the tekno air guards). For the rears can mount the body posts with some washers I think.
Old 05-07-2013, 09:57 AM   #6680
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
You would lose your front to back rigidity of the chassis. I think you would risk bending and/or severely tweaking the chassis by casing a jump, or hitting something too hard square in the nose.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-07-2013, 10:00 AM   #6681
jkirkwood's Avatar
I would mill the side pods down before removing them entirely. Also the side pods help dampen the flex of the chassis. Without them, the car may feel inconsistent.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 05-07-2013, 10:19 AM   #6682
I'm not really going to. just seeing if anybody has. I'm running no screws in the side pods and I am very happy.
How many shims are you guys using under the motor guard? I always ran just the .5 shown in the manual. But now I am running no shim at all. And I haven't noticed a difference. What are the effects? What am I missing?
Old 05-07-2013, 10:22 AM   #6683
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
its an anti squat adjustment. You can shim the front of rear. By removing it from the rear, you increased the anti squat. Are you back to rear motor?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-07-2013, 10:28 AM   #6684
I am back to rear and going to race it tonight. This will be a really good test for me to see how I like the 2 configurations. The time to beat is 17.9 for me, but I am really lookin to see which config suites my driving style best.
I think I am just as fast with both really
Old 05-07-2013, 10:32 AM   #6685
Assume anti squat same between rear and mid.
If I'm right .5 shim = 1 degree, so if wanted 3 degrees, that's be .5 upfront and none on rear for mid.
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 05-07-2013, 06:47 PM   #6686
Default Kyosho New Parts
No.UMW704-0
V2 Aluminum Rear Hub Carrier Set
(0゚/RB6/ZX/RT/SC)
Aluminum material delivers increased rigidity and durability. Aluminum rear hub carrier includes a choice of 3 different bearing bushes that improve drive efficiency and durability. 0゚ toe angle.
Available in May 2013
I copied this on the english version of kyosho.com.
Anybody know anything about this part.
Turbo911 is offline   Reply With Quote
Old 05-07-2013, 07:23 PM   #6687
gelshocker's Avatar
I too was told the alum hub was going through new spec changes. You can't order the current one through Japan anymore.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-07-2013, 07:35 PM   #6688
Send a message via ICQ to JiuHaWong
Anyone else see this before?
http://www3.towerhobbies.com/cgi-bin...?&I=LXDKHB&P=7
JiuHaWong is offline   Reply With Quote
Old 05-07-2013, 09:05 PM   #6689
wild gopher's Avatar
Trader Rating: 39 (100%+)
Originally Posted by jkirkwood View Post
I have used Tekin RS & RS Pro, Viper VTX10, Orion R10 Pro and now the Reventon Pro in recent years. The Orion R10 Pro and Reventon Pro are very close in performance and both can be made very smooth on the throttle, but I think the MOD2 software on the Reventon has a bit better brake feel, IMO. The other two listed I won't consider again for Off-road 2wd buggy.
Sorry to dig up old old postings but I am looking at the Reventon Pro for my RB6 and I had a question about reliability and ease of programming. Is it the same as the other manufacturers in ease of use, or does it take some tweaking? What motor do you run with it? Any comparisons would be greatly appreciated.
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 05-07-2013, 09:18 PM   #6690
vr6cj's Avatar
Trader Rating: 124 (100%+)
ive had a few Rev pros and got tired of them bricking or going poof. They are very smooth when they worked though. I switched to the Gen2 rs and its every bit as good and smooth as any new esc.
vr6cj is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
