    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree15Likes
Old 05-06-2013, 02:37 PM   #6661
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by ryanpatrickgore View Post
Ae quality going down hill steadily lately. Switching to the rb6 was like a dream come true. My b4 was so clapped out I was replacing parts that were just sloppy and worn after only like 3 months! The b4 is like a toy compared to the Kcar.
Why anybody would sell this car and go back to ae is beyond me...
I sense a jab at me, lol. Stop making sense and let your "feeling" dictate your actions, lol.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-06-2013, 02:46 PM   #6662
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
ryanpatrickgore is offline   Reply With Quote
Old 05-06-2013, 03:45 PM   #6663
silvalis's Avatar
Trader Rating: 29 (100%+)
So. Still trying to lighten my buggy.
Lunsford buckles: 3g lighter.
Lunsford balls: ~6g lighter.
buggy without wing, shell and wheels = 1301 (500f 801r)
I estimate wheels/tyres to be approx 210g. Body/wing probably about 50g.
Might find a different battery strap in a + shape (as opposed to Y) so I can remove half of the battery tiedown posts.
Maybe I can get a lighter battery...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-06-2013, 04:01 PM   #6664
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Anyone run it with the side pods cut down? I normally use only 1 screw in the front and sometimes no stiffening screws at all. Also have no use for the receiver tray. When I get my stock buggy I am going to try to run the diggity cf holders and run a lengthwise velcro to secure the battery. Also maybe run without the spur cover and eliminate slipper thats around 10 grams I think.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-06-2013, 06:14 PM   #6665
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by esoteradactyl View Post
You guys are misunderstanding me. The bottom of the motor guard has a tab that rests on the chassis. If you look close there is a .05 shim with a slit in the middle. You can remove it. Just like the rb5, the manual says to add a .05 shim between the motor guard and the hangar. So in all, thats two shims in the rear. I showed this shim to two other people at my track and they were both unaware it was even there.
I think thats yours, I looked at my brand new motor guard and there is no shim attached to it. Its possible you put one on there, or one was there without you knowing it.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-06-2013, 06:41 PM   #6666
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by aloksatoor View Post
Yep I run the tlr jconcepts silent spurs. Got a 70T on my rb5 stock and soon to be my second rb6. I have a slipper eliminator coming and then I can put the really tiny 50T 60T 48p spur gears for mod TC.
Is that the AE part? And does the kyo slipper bolt up?
Old 05-06-2013, 07:11 PM   #6667
silvalis's Avatar
Huh. Forgot about the slipper. I've been running the avid and from memory it's fairly heavy...
I've been considering chopping the sideguards too. I run without stiffening screws.
Old 05-06-2013, 07:12 PM   #6668
gelshocker's Avatar
Expensive but only 11 grams, that ghea front aluminum hanger is pretty strong.
Yeah but the Losi is like 3 bucks. If I can get it to hold in place there's no need for the $13 Kyosho I guess I'll ram some 3M tape between it and the bumper. Cheers,
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 05-06-2013, 07:34 PM   #6669
MikeXray's Avatar
Trader Rating: 73 (100%+)
The manual definitely tells you to put a .5 shim in between the motor guard and the hinge pin brace.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-06-2013, 07:41 PM   #6670
shoo goo it on, lol.
Old 05-06-2013, 07:55 PM   #6671
aloksatoor's Avatar
No to use the TLR spur the parts are
http://www.rcshox.com/tlr22-garodisc/ or 2 of http://www.amainhobbies.com/product_...r-Friction-Pad
and
http://www.amainhobbies.com/product_...-Spur-Gear-70T
or for a quieter tranny I run
http://www.amainhobbies.com/product_...-Spur-Gear-76T
Kyosho plates, spring retainers bolt right on. Just a drop of CA to hold the pad onto the spur till you tighten it. Get a very consistent feel with the garodiscs.
Old 05-06-2013, 07:57 PM   #6672
aloksatoor's Avatar
haha yeah I don't mind the 3 $ part or the permanent 43$ one. Only concern is the weight of the ghea part. For 17.5 no go for sure.
Also with the new updated kyosho brace, I just hammer it flat and its good to go for a few more weeks.
Got a lot more life out of it until I upgraded to the ghea hangers .
I had no idea how light a machined TC spur could be until I got my first car a month ago .
Old 05-06-2013, 10:21 PM   #6673
Yeah it's pretty strange that nobody else seems to have this. It's actually pretty nice because the shim is held on by the tab so there's no fumbling around with the spacer while screwing down the rear hangar. I only noticed it because it fell off one day while i was trying out the 521 arms.
esoteradactyl is offline   Reply With Quote
Old 05-07-2013, 04:47 AM   #6674
Frank L's Avatar
and
Thanks.
Old 05-07-2013, 08:03 AM   #6675
Contact Tony at RudeBits
He's using a carbon chassis as is a mate.
Www.rudebits.co.uk
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22968 Today 04:05 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
hairymuffin
