    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 05-02-2013, 11:01 AM   #6586
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by pekow91 View Post
Have any of you guys ever bent a lundsford punisher turnbuckle? I just bent one on my rear link on my 17.5 RB6.
yes, I have bent them before. Send it back to lunsford, they will replace it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-02-2013, 11:10 AM   #6587
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Yep they bend quite easily in the right hands (me :P). I have since upgraded most of mine to the 3.5 mm versions have yet to bend one.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-02-2013, 11:14 AM   #6588
are the rb6 lunsfords normally 3x40mm?
Old 05-02-2013, 11:15 AM   #6589
hmm these are the super duty kits
  • (2) M3.5x55mm Super Duty Titanium Turnbuckles (Front Camber)
  • (4) M3.5x60mm Super Duty Titanium Turnbuckles (Steering & Rear Camber)
  • (12) 4.8mm Ball Cups with access hole for easy installation
they went from 40mm to 50 and 55, which is about the same length as the b4 and 22 rods. I wonder if my b4 lunsfords are 3mm or 3.5mm.
Old 05-02-2013, 11:28 AM   #6590
aloksatoor's Avatar
Don't buy the kit form. Kyosho has designed the buckles properly the longer plastic pieces flex and are the first point of breakage rather than expensive hubs, bulkheads. Get the 1.5 inch long super duty pack from amain or whereever. They sadly come in packs of 4 so two are backups.
http://www.amainhobbies.com/product_...-Turnbuckles-4
Use a body reamer for the first 2 mm in a new ball cup to get the thread going, its fatter than the 3mm on the skinny turnbuckles.
Old 05-02-2013, 11:30 AM   #6591
lololol.....
3.5mm x 1 1/2, wtf. its metric x standard?
Old 05-02-2013, 11:38 AM   #6592
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
If I didn't know better, I would say something changed in the production material of the lunsford Ti turnbuckles. I'v been running them for years. A few years ago, i would never see a bent turnbuckle. Today? I crash FAR less than I used to, and i bend them all the time. Honestly, i would probably stick with the stock turnbuckles, unless weight was a huge issue. you save about 6 grams going from the stockies to the lunsfords. (if memory servs). But the stock buckles are a lot stronger, and don't bend nearly as easily.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-02-2013, 11:52 AM   #6593
MikeXray's Avatar
Trader Rating: 73 (100%+)
I would not do that, the xray pin is way stronger than the K stuff. Someone on this thread put the xb4 rear hinge pin into the kyosho aluminum hangers and tore up the RF kyosho hanger. The xb4 has thick plastic inserts to flex and give a bit the kyosho will be ripped.
Shock tool Epers version is good very tight tolerances as well.
That makes no sense, i have plastic hingepin mount, there is no downside to a stronger pin.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-02-2013, 11:56 AM   #6594
aloksatoor's Avatar
Oh yeah duh. The pic someone posted was for the rear aluminum hangers. I got confused I have a front aluminum hanger on my rb6 as well .
Old 05-02-2013, 12:02 PM   #6595
Sorry, but what is kit anti squat again?
Schumacher - RW Racing - RudeBits - TORCH
mikeyscott is offline   Reply With Quote
Old 05-02-2013, 12:12 PM   #6596
aloksatoor's Avatar
2 degrees
Old 05-03-2013, 09:43 AM   #6597
pekow91's Avatar
Trader Rating: 45 (100%+)
Ah, glad I'm not the only one.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 05-03-2013, 11:06 AM   #6598
Trader Rating: 26 (88%+)
Default Small Double Problem
Having some problems with my RB6 when it comes off jumps...specifically small doubles. Seems as when I take off the lip of a small double at a lower speed as not to over shoot it my car seems really unpredictable. Unpredictable both on take off and on the landing. The front end can be heavy on either side at any time. I hit the jump square but Im not sure why this is happening. Im running 32.5 in front white springs 27.5 rear gold springs. The car is dialed everywhere else on the track I just tend to pucker up every time I hit a double. Any ideas what could be causing this?
jgonz is offline   Reply With Quote
Old 05-03-2013, 12:28 PM   #6599
MikeXray's Avatar
My first inclination would be your ride height it too low, second would be a bad shock, or binding in the suspension, third would be, just a uneven jump
Old 05-03-2013, 12:50 PM   #6600
eper's Avatar
Trader Rating: 14 (100%+)
hinge pins bend easily i would check them all. maybe one side doesnt move as freely as the other at times.. honestly this is the best jumping buggy i ever drove
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 Yesterday 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
