    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 09-13-2012, 10:56 PM   #646
lbckevin's Avatar
Trader Rating: 91 (99%+)
the kits did not arrive yet.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 09-14-2012, 08:00 AM   #647
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by eper View Post
I had a b4.1 wasnt for me. Sorry to offend you im just trying to get other peoples opinions and also give mine. Pretty sure thats what forums are all about
Yes and no offense taken. You do have valid points though. As for me, I am going to build the front end the way I have my car setup with the shim and then build the kit as it comes out of the box except I will use the shock oil that I am currently running. Then I will see where I am at.
As for the rear arms here is something to think about and it might not come out clearly in text. Put the rb5 series arms up next to the rb6 rear arms. Is the outside hinge pin higher or lower? Then measure the rear bulkhead where the camber link attaches. Depending on these measurements you could be significantly changing the change in camber gain when the wheel is moving through its suspension range. Some like an aggressive change and some don't. Anyway...just something to chew on.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-14-2012, 08:38 AM   #648
Having already built up my car AND fitted UM713 RB6 rear arms to my Lazer as well I can answer the question on difference in rear arms.
If you run a long hinge pin through both ends of the arms you will be able to slide on a UM713, the hinge pin to hinge pin distance is the same.
If you do the same comparison to with an LAW43 rear arm and drop plate you find that the inboard shock mounting holes lines up spot on, there is a fraction (and I mean fraction) difference in the outside shock holes when compared.
That means the UM713 rear arm can be a substitute for the LAW43 rear end. If you were running that on the RB5 awesome, read setup straight across. If you were running UM521/521-1/566 arms on the back of the RB5 you will find that your shock setup and link positions will need a bit of optomising to get the same "feel".
Not sure on the rear motored build, as I have only so far built mine in mid motor format, but the lowest potential inner ball stud position is a lot lower than you would have ever achieved on the RB5 ... that is a significant difference in geometry. Not sure on the exact difference, I will try to measure both RB5 and rear motor builds when built, but it is at least 2mm lower on the mid motor RB6 bulkhead.
http://model-car-racer.co.uk/
Today AE .. tomorrow who knows?
RogerM is offline   Reply With Quote
Old 09-14-2012, 12:33 PM   #649
big chris's Avatar
Trader Rating: 50 (100%+)
Maybe he ran that arm because Kyosho did not have any extra rears at the time??? Maybe???
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 09-14-2012, 02:54 PM   #650
savageboy69's Avatar
Trader Rating: 88 (100%+)
I get the concept of a baseline set up. Im just not thrilled about sverytime they release something new everyone puts the old parts on it. It seems like they dont make the new stuff work for them tbey just divert back to the old. So if the old stuff is just as good y do i want to go dump $450 of my HARD earned money into it ill stick with my +10 rb5. although i do love new kits. Im just going to try and relax and see what happens when it gets to my lhs.
its not usually everyone at first, its tebo, who will change stuff around, then everyone follows, but what everyone has to remember is tebo is a TOP driver so the little things that he changes or tries out are because its what he likes, doesnt mean its goin to work for everyone else, the setups they give are only a starting point and thats it, everyone has a different driving style so they are all looking for different things from there car. I will admit, when tebo changes something, i also change it to at least try it, so i know what the difference is and what that change actually does. But i see so many guys who dont have their own base set up that just make change after change because someone else is doing it, then there car is so far from where it was it doesnt handle like it should, and they have no idea where to go back to to get it handling well again, thats when you see people start making negative comments and sell the buggy and yada yada. The best thing i can reccomend to anyone is put in the time and make the setup yours, get what YOU want out of the car and enjoy it. Its been said time and time again these setups that are released are just a starting point but too many people seem to think they can throw on the setup and go. And if you arent the type of person who can tell what they want, or need to change on a car this probably isnt the buggy for you. Just like with anything you have to put the time and work into it. Eper this wasnt directed at you or anyone else just a general statement.
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 09-14-2012, 04:26 PM   #651
So I have heard both 9/20 & 9/28 as release dates.....anyone else hear anything one way or the other?
Bluehills315 is offline   Reply With Quote
Old 09-14-2012, 05:51 PM   #652
fastestwon's Avatar
Trader Rating: 15 (94%+)
i heard they are in the shipping container on their way here but customs will be the slow part of delivery . it may take up too a week to get through .
fastestwon is offline   Reply With Quote
Old 09-14-2012, 06:03 PM   #653
+1
I have been working on an excel style spread sheet for my rb5 over the last couple of months. Trying all the setup options for the car, some better some worse, but the important thing is I now know the feeling of each change and now my local track setup is spot on, but when I go to other tracks I'm able to quickly adjust the car to my liking.
It's also a great feeling to learn and understand more about the car each race day. Very rewarding.
Tom87 is offline   Reply With Quote
Old 09-14-2012, 06:31 PM   #654
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
Lookie what Kyosho America just posed on their Facebook/website...
http://www.kyoshoamerica.com/assets/...tup_sheet1.pdf
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 09-14-2012, 11:19 PM   #655
eper's Avatar
Trader Rating: 14 (100%+)
See know thats a nice little piece of information. Thank you rfury and thank you kyosho. Little extra things like that are really helpful.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 09-17-2012, 04:10 PM   #656
Trader Rating: 77 (100%+)
Seriously are we going to get our IPhone 5's before the RB6? The wait is killing me.
goin2drt is offline   Reply With Quote
Old 09-17-2012, 04:58 PM   #657
Yeti AS3's Avatar
Does anybody know if the front pivot block is the same as the SP2 or WC? Just want to order an alum one if it is
Hot Bodies D413
AE B5m
Haigh Designz -Custom Airbrushing
Leisure Hours Hobby and Raceway!!
Yeti AS3 is offline   Reply With Quote
Old 09-17-2012, 05:05 PM   #658
Shows the part # as um721 and that is not the same.
Old 09-17-2012, 06:05 PM   #659
cnelson3's Avatar
Trader Rating: 66 (100%+)
so i'm SOL if i didn't pre order yet?
cnelson3 is offline   Reply With Quote
Old 09-17-2012, 07:24 PM   #660
celt's Avatar
I can't wait for YOU to get this buggy, so you can put the shortcourse away.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15027 11-22-2017 09:29 AM
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 11-21-2017 10:14 AM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
