    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-01-2013, 02:06 PM   #6541
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Mike/bob, you don't need to modify the side pods to mount a reciever there at all. that is where I originally mounted mine, and it mounts just fine as-is. Just put a small strip where it contacts on the bottom, and a small strip where it contacts on the side of the receiver, and it locks in nice and tight. No need to modify anything.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-01-2013, 02:07 PM   #6542
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by MikeXray View Post
I dremeled one of the side pods and put my receiver there, I wanted the option to move the battery all the way forward if needed.
ummm, no. I wont take a dremel to a Ferrari. That is just sinful.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-01-2013, 02:51 PM   #6543
Super Moderator
eehh.. its just a side pod. If you ever changed your mind about the receiver location, replacement pods aren't expensive.
- RCSpecialties -
Old 05-01-2013, 03:16 PM   #6544
Trader Rating: 24 (100%+)
Originally Posted by jordy-15 View Post
jarrod
the best place i have found is rc champ in japan fast postage cheaper and you should be able to get all you need from them
upgrades
the new front hinge pin brace
alu hubs 0 and .5
rear springs gold & white (x-gear)
front white (x-gear)
alu rear susp hangers wide and narrow
the thing is bullet proof so just arms and towers
and you should be set
cheers
so no alloy rear hubs standard?
whats standard spring colors?
why only those colors?
is narrow or wide standard and why do i need both
whats the part # for updated front brace
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 05-01-2013, 03:18 PM   #6545
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Cpt.America View Post
I'm at 1560 with a Fantom 4600 shorty, 551 lowpro servo, alu steering rack, and SXX speedo. Seems to be a good spot in-between being too light for traction, or too heavy for speed in a 17.5. Weight is an important tuning factor. Running a lighter car will increase how nimble the car feels, and it will change direction faster, but overall traction will be lower. Tune your weight for your traction levels to minimize lap times.
Cool thanks guys I will make up my mind sunday on the second chassis . Need to get another shorty servo also...
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-01-2013, 03:24 PM   #6546
aloksatoor's Avatar
On my mod buggy (the rb6), my receiver is under the rear shock tower its a lot cleaner for wiring and I can move my battery all the way up if needed (with BLS 551). Ill try to post a pic tonight.
Old 05-01-2013, 03:44 PM   #6547
jordy-15's Avatar
Trader Rating: 17 (100%+)
kit is plastic 0deg
kit springs are pink front (super soft) red rear (medium)
white spring = soft
gold spring =medium/soft
kit hanger are plastic wide and prone to breaking. narrow for a tuning option
kyo um720b
hope this helps
cheers
:: Proline :: XRAY :: Muchmore::HEI ::
www.nbhc.com.au
www.rchobbyland.com
www.sydneyrc.com
jordy-15 is online now   Reply With Quote
Old 05-01-2013, 03:48 PM   #6548
thanks bud
Old 05-01-2013, 03:55 PM   #6549
is steering rack alloy standard?
Old 05-01-2013, 03:55 PM   #6550
red spring says MED/HARD lol
Old 05-01-2013, 04:02 PM   #6551
silvalis's Avatar
Trader Rating: 29 (100%+)
Hrm. I'm having issues getting mine as light as you guys. I'm at 1600 (RM) with the lid and wheels on.
- Exotek steering bits (rack and the other bit)
- Exotek rear bulkhead
- Viper VTX10
- Reedy 17.5
- Intellect 4600/80C shorty
- KO One10
- KO KR411FH
- RC4 Hybrid
- bulldog body/wing
- Front K wheels w/ rips
- Rear Avid wheels /w losi bigshots
I've got lunsford turnbuckles and ballstuds I could put on, but I doubt that will shed 50g. Maybe it's not that much of an issue, given im outdoors dirt...
I'd still get 0 deg hubs, but I've broken rear hubs on previous K cars before. I think the general consensus was that the RB6 rear hubs had been strengthened (but the P/N remained the same?)
I'd hesitate going white rear (medium soft) white front on aus tracks. This is 2 steps softer rear and 1 step harder front.
Gold rear is worth picking up (medium).
Standard is Red rear (medium hard) and pink front (soft).
wide suspension hangers are standard. Gives you more steering/less rear grip. I use these as tuning. Good for getting a medium size effect in rear grip. Wide aluminium hangers in these may be a bit difficult to get (actually nbhc just got the Yaiba brand ones). You will need alu hangers if you hook the rear on something at speed. May break the plastic hanger.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 05-01-2013, 04:03 PM   #6552
silvalis's Avatar
nah. plastic.
NBHC also have the yaiba racks now...
Old 05-01-2013, 04:27 PM   #6553
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
silvalis- the viper is pretty heavy and the alum exotek rear bulkhead is too, wires can also be heavy. shorty servos are much lighter than standard too.
ryanpatrickgore is offline   Reply With Quote
Old 05-01-2013, 04:33 PM   #6554
pekow91's Avatar
Trader Rating: 45 (100%+)
I was able to shed the weight with the shorty servo and trimming the wires.
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 05-01-2013, 04:57 PM   #6555
silvalis's Avatar
The VTX10 (not the R and not the BE) is only 47g. Mine's jammed under the bulkhead, caps removed (a 4X capset soldered on and placed next to the shorty) with short wires to the battery. I guess i could go down to 14AWG or 16AWG wire...
Also the RSX One10 is a short servo. Bit heavier than the BLS551 though.
I'll try going back to the plastic bulkhead
Oh. I've got the front exotek bulkhead too. Maybe go back to plastic there.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22944 Today 12:18 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
