    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 05-01-2013, 08:45 AM   #6526
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Cpt.America View Post
If you're OCD, (like me) especially about wiring and electronics layout, NOTHING will satisfy your OCD like the RB6 can. You just can't do this with a B4. So to use that as an excuse is flat backwards.
ok, I am missing something. how did you run the wires? because that wire layout just gave me wood. Do you take the side pods off and run the wires in a gap?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-01-2013, 08:57 AM   #6527
pekow91's Avatar
Trader Rating: 45 (100%+)
[QUOTE=Cpt.America;12105529]If you're OCD, (like me) especially about wiring and electronics layout, NOTHING will satisfy your OCD like the RB6 can. You just can't do this with a B4. So to use that as an excuse is flat backwards.
Nice! How are you routing your ESC wire?
Kyosho RB6 | Kyosho MP9 TKI3E | Xray XB4
pekow91 is offline   Reply With Quote
Old 05-01-2013, 09:14 AM   #6528
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
There are channels in the plastic pieces to run the wires towards your receiver.
As for those with axle problems, open up the hole on the wheel were the axle goes through. You don't have to do it much so be careful. This should reduce any axle issue you might encounter.
Ugly bodies, there are options besides the kit one. Proline and JConcepts offer bodies too.
Any other question? Look at the first post to see if it was answered otherwise ask away!
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-01-2013, 09:18 AM   #6529
nice on the channels. I will look when i get home. I might just need to get used otthe body. I hated cab forward at first, now I like it. Its just narrow and squared off a lot. I am sure it would grow on me. The finnishers normally look nice. might look into those. I just looked up some pics of the rb6 finnisher body, they actually look pretty good. The cab is not as huge and it looks like it is further back from the front towers.
Old 05-01-2013, 09:39 AM   #6530
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I like the stock body. I think it's sweet. The prime looks goofey to me like an el camino
ryanpatrickgore is offline   Reply With Quote
Old 05-01-2013, 10:18 AM   #6531
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Awesome wiring again cpt and thanks kraig for the channels tip. Have had mine for so long and never realised it was there for routing wires DUH!!! I am thinking of getting another chassis up and running for stock buggy, our spring series has crazy amount of talent in sportsman mod, exp mod and now 17.5 mod! glad the sc 2wd classes are dying out and people getting into buggy!
What RTR weight are you 17.5 guys at for the 6 chassis? I am around 1521 on my old rb5 right now thinking of running it this weekend and maybe decide if I want to upgrade it to the 6.
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 05-01-2013, 10:48 AM   #6532
1582g on mine with the shorty, but I just put in a lrp and took out the tekin Esc so that's a bit heavier. I will have to weigh again later and see the difference.
Old 05-01-2013, 10:54 AM   #6533
aloksatoor's Avatar
Not bad then weightwise. And of course way better handling wise than the 5 . So no aluminum bits anywhere? I will put the rear exo bulkhead for sure for peace of mind.
Old 05-01-2013, 10:56 AM   #6534
pekow91's Avatar
I'm at 1550 with a fantom shorty, speed passion motor and an orion ESC.
Old 05-01-2013, 11:03 AM   #6535
I have the alum exo rack and some extra red alum washers throughout for bling and the exotek red shock bushings and the exotek carbon battery mounts/straps .
All of that stuff adds weight. All for bling too really.
The car needs nothing so I started going OCD making it pretty
Old 05-01-2013, 11:16 AM   #6536
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I'm at 1560 with a Fantom 4600 shorty, 551 lowpro servo, alu steering rack, and SXX speedo. Seems to be a good spot in-between being too light for traction, or too heavy for speed in a 17.5. Weight is an important tuning factor. Running a lighter car will increase how nimble the car feels, and it will change direction faster, but overall traction will be lower. Tune your weight for your traction levels to minimize lap times.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 05-01-2013, 01:33 PM   #6537
Super Moderator
Trader Rating: 17 (100%+)
hey leave Wildcat alone..........I want his car next month when he decides to sell it. Mine's just too pretty to touch the dirt :P
I do think I may invest in a BLS551. I currently have the BLS451 and my receiver is really shoehorned in there LOL.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-01-2013, 01:40 PM   #6538
I currently have my receiver on the receiver tray thingy. I dont like it there and might move it forward. But I think in order for it to fit with a full size servo you need to put the shorty in the back/back position. The battery tray has 2 positions for fine tuning. The car came with it setup in the back/back but i moves the front holder forward because I thought i might want to play with battery foam for quick changes. Plus in the back/back my shorty was a very tight fit. I actually had to pry my pack out. I was worried about hard landing cracking my pack because it was soo tight.
Old 05-01-2013, 01:54 PM   #6539
MikeXray's Avatar
Trader Rating: 73 (100%+)
I dremeled one of the side pods and put my receiver there, I wanted the option to move the battery all the way forward if needed.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-01-2013, 01:59 PM   #6540
Super Moderator
hrmm... I actually might steal that idea from you. I have my power cap from my ESC that is mounted on the side pod. If it doesn't stay in place, I'll have to make a flat spot there.
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22936 08-14-2017 04:25 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
