    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-30-2013, 08:44 AM   #6481
Super Moderator
Trader Rating: 17 (100%+)
My initial electronics layout on the new ride
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-30-2013, 09:00 AM   #6482
gelshocker's Avatar
Originally Posted by Wildcat1971 View Post
The JC b4 or JC TLR rears? I assume you meant B4. 3mm? are you sure, Those manufactures, like AKA, JC and others market those rears as for the b4, RB5/6 and tlr22. The main reason for the wheels nuts fitting seems to be the wheel thickness around the axle. I have some various wheels at home, but none of them have the same tire for an accurate comparison. If anyone has unmounted wheels, I would definitely like to see how the avid, aka, JC, Kyosho and other wheels measure. 3mm would greatly make the car feel different.
+1
I'm not doubting Cpt's claim but there's a case here. JC hex rims 3348 are more accessible.
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 04-30-2013, 09:07 AM   #6483
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
looks good Bob. I am wishing I have the separate cap. Mounting the vtx10 with the caps on top is crappy. I cant really get it far enough back because the caps hit the bulkhead.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-30-2013, 09:15 AM   #6484
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Originally Posted by mike_d View Post
I dont think so that looks like the carbon one. The one I had was silver aluminum looking.
ryanpatrickgore is offline   Reply With Quote
Old 04-30-2013, 09:19 AM   #6485
Super Moderator
so just install the updated cap
Old 04-30-2013, 09:19 AM   #6486
I thbink this one.
http://www.amainhobbies.com/product_...nner-Pin-Brace
Has anyone tried the avid top shaft? How well does it hold up? I always thought the alum top shafts tended to wear out really fast. I would like to use the AE Spurs if I can because the spurs are easy to get local.
Old 04-30-2013, 09:25 AM   #6487
Originally Posted by gelshocker View Post
Hey guys, for those running MM, are you adding weights in and around the motor? On the RF and behind the battery? I'm gonna try ramming a shorty right up to the motor guard, and 'park' the back end of battery in place with some weights to prevent it slipping towards the motor. I'm thinking with MM I'm gonna need more weight towards the rear anyway. Thanks,
No, no weight. My shorty is in the same place. I posted a pic a few pages back. You should not have to run any extra weight for mm. If you do ... You need to work on setup instead. Or. rear motor is better for your track and you don't have enought traction in your dirt/clay
Old 04-30-2013, 11:14 AM   #6488
Jack Smash's Avatar
Trader Rating: 29 (100%+)
One more thing, to get the rear turnbuckles level with the rb6 rear arms, how many shims do I need at the tower and hubs respectively? Thanks!
What are you trying to accomplish by doing this?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-30-2013, 11:19 AM   #6489
He wants a different roll center?
Old 04-30-2013, 11:39 AM   #6490
gelshocker's Avatar
I'm looking for some sort of MM starting rear roll center to play with. Thanks,
Kyosho RT5 | RB6
Old 04-30-2013, 11:49 AM   #6491
Jack Smash's Avatar
Drawing a straight line from inner to outer hinge pin, the upper camber link looks to be very close to parallel with an even amount of shims on the inner and outer ball studs on the car I ran this weekend.
Old 04-30-2013, 11:56 AM   #6492
Trader Rating: 38 (100%+)
[QUOTE=Wildcat1971;12101778]I thbink this one.
Has anyone tried the avid top shaft? How well does it hold up? I always thought the alum top shafts tended to wear out really fast. I would like to use the AE Spurs if I can because the spurs are easy to get local.[/Q
AVID TRIAD is the bomb. Spur gears are great and the slipper system is great
Previous username: MBUCK
noworries is offline   Reply With Quote
Old 04-30-2013, 12:09 PM   #6493
I thbink this one.
Tlr spurs go right on to the stock top shaft. You can use the AE spur and pads for a bit but the stock slipper plates will ride on the spur eventually. I ran the tlr 70 in 17.5/13.5 and a tlr 78 in mod with tlr pads and kyosho vented plates. We have it all at 1H. Even have the avid top shaft if you are set on getting one I never used it.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-30-2013, 12:10 PM   #6494
Heck I even have the avid slipper setup ill sell cheap to you. I think it's a pile personally.
www.OHRCR.com
Old 04-30-2013, 12:12 PM   #6495
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Bob Barry View Post
good stuff.
I do currently have the '3 line' axles on the car so that should compensate some until I can stock up on Kyosho rims.
Yes, that would probably be just about right!
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22984 Today 10:14 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
