    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree14Likes
Old 04-24-2013, 07:52 AM   #6346
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by Bob Barry View Post
Yeah I still haven't been up to the new building. I need to make it up there one of these days. It just costs me a ton to race there. Bridges / tolls / gas and I'm up to 60-70 bucks before even walking in the door That and it's 3 plus hours away LOL
Believe me I know, I've spent the last 2 years traveling to Jackson 2x a month or more. Helps to load the car up with 3 people.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 04-24-2013, 08:10 AM   #6347
B00t13g's Avatar
Originally Posted by Turbo911 View Post
I picked in up at LHS. But I found at mcmaster.com and http://www.cabletiesandmore.com/heat...FQVV4AodjiEAGg
1/16" dia
Thanks man. I ordered up a foot of each. If anyone needs any ill send it for the cost of shipping.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-24-2013, 08:26 AM   #6348
asc6000's Avatar
Trader Rating: 15 (100%+)
You might want to get more than a foot unless your selling it by the inch.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 04-24-2013, 08:44 AM   #6349
B00t13g's Avatar
Lol I'm using a half inch per spring so 1 inch per pair 2 inches per full set.
Mackenzie Meyercord
Old 04-24-2013, 08:57 AM   #6350
jkirkwood's Avatar
I haven't seen many RB6's with a Speed Passion Reventon Pro mounted. I thought the switch maybe impossible to get to but once I wired up it's fairly easy. Programming is done through the RX Wire. I could had easily cut the tabs off the mount and moved it forward but I wanted to build the car without modification, plus I can easily move the battery back if I move the ESC's Cap.
I really like car's wiring management in the side pods. Makes for a clean install without much effort.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 04-24-2013, 09:00 AM   #6351
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
how do you mount the receiver strap to the battery box. Mine is mounted to the rear bulkhead and I would rather use your config.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-24-2013, 09:10 AM   #6352
jkirkwood's Avatar
I used some other posts they included in the kit that allow for a screw to be used, then added a 2 mm spacer on top of them to space up the receiver mount and and screwed the receiver mount to the posts. I then cut the battery strap to the length I wanted.
Old 04-24-2013, 09:14 AM   #6353
ah, ok. I dont think i have those posts. might need to pick some up. I prefer to not bury the esc
Old 04-24-2013, 09:27 AM   #6354
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
@Jkirkwood
How do you like the revention? How does it compare to other esc's you have used?
ryanpatrickgore is offline   Reply With Quote
Old 04-24-2013, 09:42 AM   #6355
Did you guys see that Yaiba is releasing wide RM suspension holders? I wonder what the price will be. kinda hoping it is closer to strc than Kyosho, lol prices
According to the Yaiba site
Both hangers = 2400 jyp ~ $25 - $30 USD for both. Just a guess, but a nice option to the Kyosho holders at $50+
For reference B4 hubs = 2900 jyp = $32 USD at tresray
Old 04-24-2013, 09:55 AM   #6356
I am looking for more forward bite. Loads of side bite but need some more forward traction. Do you guys have any suggestions for changes that may help increase this. I'm running close to the tebo mm setup.
Old 04-24-2013, 10:00 AM   #6357
put it back to RM I am sure they will increase forward bite.
Old 04-24-2013, 10:07 AM   #6358
It is good after the layout traction comes up. yesterday was the first day on the fresh new track. Everybody was battling traction, even rm guys . Our new layout has great corners that are fast with mm. And the winner of the a-main was mm last ight too.
Old 04-24-2013, 10:24 AM   #6359
jkirkwood's Avatar
Originally Posted by ryanpatrickgore View Post
@Jkirkwood
I have used Tekin RS & RS Pro, Viper VTX10, Orion R10 Pro and now the Reventon Pro in recent years. The Orion R10 Pro and Reventon Pro are very close in performance and both can be made very smooth on the throttle, but I think the MOD2 software on the Reventon has a bit better brake feel, IMO. The other two listed I won't consider again for Off-road 2wd buggy.
Old 04-24-2013, 10:39 AM   #6360
what was your issue with the viper?
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22957 Yesterday 12:16 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15015 08-29-2017 12:36 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
