    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree25Likes
Old 04-22-2013, 09:44 AM   #6301
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
nice looking buggy Ryan. Are those AE greens on the rear?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-22-2013, 09:57 AM   #6302
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
They are greens, needed to try a softer spring last time I was out and that's all I could get a hold of. It is 1 step softer then kyosho golds. Next time out I will put the golds back on. I was using reds too but golds neem to be the ticket for me
ryanpatrickgore is offline   Reply With Quote
Old 04-22-2013, 10:10 AM   #6303
Trader Rating: 54 (100%+)
noticed that they have an aluminum servo horn for the rb5. Should I still get the tlr servo horn or go with the RB5 aluminum
Here are the links
http://www.amainhobbies.com/product_...-Horn-Gunmetal
or
Speedychris22 is offline   Reply With Quote
Old 04-22-2013, 10:18 AM   #6304
the rb5 one is nice with the inserts for different servos, but pricy. The losi is cheaper, but you will need to drill it and put a nut on it because it is 4-40 tapped.
Old 04-22-2013, 10:27 AM   #6305
I'm afraid that the kyosho option might strip as well since its a plastic insert
Old 04-22-2013, 10:30 AM   #6306
its plastic that is supported by alum. I "could" strip, but I would think the chances are low if you installed it correctly.
Old 04-22-2013, 04:22 PM   #6307
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
My 17.5 mid motor setup!
Need to check my part stock. need to see what parts i need to get to make mod mid motor.
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 04-22-2013, 04:55 PM   #6308
got the buggy it is about hwta I expected. it did come with the radio plate mount. But it did not have the narrow hangers (booooo) and the slipper plug on the gear cover is missing. other it looks very good. that is one free tranny. I gave it a little twist and it just took off. seems really well built. time to go over it and place my amain order.
Old 04-22-2013, 06:16 PM   #6309
Sweet deal! You can use the rubber 22 slipper plug just trim it and its money and doesn't fall off. No need for the narrow blocks for our tracks I run wides everywhere even at cactus.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-22-2013, 07:31 PM   #6310
yeah, I pulled the one off my 22 to try. worked good. my 22 kinda need a new gear cover anyway. sadly the kyosho cover is cheaper, lol. ok, the shocks. WOW so freaking nice to build. just like the old losi xx shocks. I am gonna run losi 55x4 with 30/27.5 for now. I have read the 55x4 is sweet. I might get the ae 1.3x4's once they come into stock. My front pin brace is tweaked a little not a ton, but a little. I am not sure if it is the 1mm thicker version. how thick is the upgraded brace? is the xxx brace better, thought i read it works. Honestly the pin brace design is a little weak. The plastic bumper is suppose to keep it on and support it I guess. I notice the previous owner was trying to put the Team Stock setup on the buggy. he even removed the 3x screws from the side pods. the only screws in the pods are the end ones. should i put more screws in? And yeah, avid rear wheels dont really fit. I used the locked hut on it, but it looks like it only threaded 1/2 way. I am unsure if the serrated surface will be enough. sadly I just mounted all of my tires on avid wheels for my b4.....so I kinda wanna use them. ok, gonna get back to the buggy.
Old 04-22-2013, 07:45 PM   #6311
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Wildcat1971 View Post
it looks like the kyow5303-05 tree comes with a lot of not so useful items. Does anyone else make a plastic or delrin upper shock mount?
exotek makes black delrin ones and i like them on my buggy
the serrated nut is plenty i been running it on my proline wheels for months no issues
also i make a nice shock tool for your new shocks if your interested pm me and the front brace will not be anissue within the next 2 months i have re-engineered some of these parts and am testing only for durability now. i seem to have found a very simple way to fix the issue and it will work on the entire k car lineup
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-22-2013, 07:48 PM   #6312
silvalis's Avatar
Trader Rating: 29 (100%+)
1) the serrated surface is enough. Just make sure it bites into the wheel.
2) What kind of track are you running on. Outdoors, I reckon the Kyosho 5x1.3 works better.
3) put the screws back in if you want it stiffer and already have good traction.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-22-2013, 08:11 PM   #6313
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Originally Posted by Jason.Dias View Post
We're running the saddles in the same position you have your shorty, and you already made the modification to the motor guard, so all you need to do is remove the rear battery holder, and flip the front holder, and the saddles should fit.
Thanks Jason, figured it was something simple. Have you been having success with the saddles vs shorty? Cody was trying them at JBRL last week and he TQed and won pretty easily.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-22-2013, 10:01 PM   #6314
So I was at a local track yesterday and they said the RB-6 is better for stock than anything else, why is that?
Jam-Air is offline   Reply With Quote
Old 04-22-2013, 11:18 PM   #6315
You hang out at wcrc huh? Ahaha
Jetboat_Jake is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22982 Today 01:26 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15026 11-02-2017 04:19 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 09:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 05:30 PM
