    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree16Likes
Old 04-21-2013, 11:53 PM   #6286
Trader Rating: 28 (100%+)
Anyone try the Suburbs (front and rear) on blue grooved outdoor hard pack sugared track? They don't make the suburbs in mx for the front. I have them for indoor clay and like them a lot. Looks like the scrubs are the only mx avail for the front, anyone know how the M3 does in high wear high traction 17.5?
Thx
Kyosho STRR
RB6
MP9
SCR-SP
www.SolidTechPerformance.com
lbz34 is offline   Reply With Quote
Old 04-22-2013, 03:18 AM   #6287
Originally Posted by K_King View Post
So I ran my second car that I built as MM for the 1st time yesterday in a race. Wow. Our track is indoors, but it's not exactly high bite. Medium bite would be describe it, and it can be loose so it was going to be interesting to see if it would work.
I had never run a mid motor car before, and I have a bit of work on it to make it better, but essentially I took my rear motor car setup and tossed it on this with some adjustments, but the base is the same.
I was able to run my fastest laps with MM, ran more consistent, jumped better, and was overall smoother than I had been with my RM car. I TQ'd and won the 7 min main by a good margin.
My RM car was good, but there's something to be said about how a MM car drives without feeling like you have to drive hard to get a really good lap time.
Here's how I made the car config wise. I am going to try saddle packs eventually, but I need to figure out how they are mounting them.
I did have to modify the rear motor guard to move the battery back further back, and the braces look a little tweaked because of it (the holes are actually not made for the braces so it stretches it a bit, the battery doesn't move though. Just looks goofy.)
Here is my setup
https://dl.dropboxusercontent.com/u/...Motor_SDRC.pdf
Phone friendly JPG version
https://dl.dropboxusercontent.com/u/...Motor_SDRC.jpg
We're running the saddles in the same position you have your shorty, and you already made the modification to the motor guard, so all you need to do is remove the rear battery holder, and flip the front holder, and the saddles should fit.
Jason Dias
http://www.facebook.com/jasondiasrc
Team Kyosho - AKA - KO PROPO - Hobbywing - Schuur Speed - Schelle Racing - OCRC Raceway - Tuning Haus
Jason.Dias is offline   Reply With Quote
Old 04-22-2013, 06:44 AM   #6288
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
ok, my kit should arrive today. I picked it up off these forums used. Here was the AD
FS: Kyosho Rb6
I will do my usual checks for the screwed screws, diff smoothness and change the shock oil. I have tlr22 4x55 pistons I can use if they work well on the loose outdoor tracks. I mainly need to figure out if the narrow or wide hangers are on the car. Is there an easy way to tell them apart? The seller was not sure what was on the car. Also, it has the exotek upper shock bushings. Do those wear out the caps? Metal on metal seems like a bad idea. It also has the exotek rack, I read on here that the rack was wearing out the steel mounts? Any work around? How can I tell if the steel mounts are shot?
This is the track i will be running on. This video was from last saturday and we will be doing night racing until november. I plan to start with the box stock kit setup, but any pointers on changes that might help out on this track would be helpful. The are no kyosho buggies in town that I am aware of. In fact, I think every car in this main was a b4.
https://www.youtube.com/watch?v=PtzDIWHKKG4
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-22-2013, 06:54 AM   #6289
Looks to be in decent shape I did notice the rear shelf piece is missing. It holds the rear of the battery bar in place kinda a triangle looking piece.
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 04-22-2013, 06:55 AM   #6290
jkirkwood's Avatar
I haven't any experience with the Exotek shock bushings but I personally wouldn't run them due to it being metal on metal. I would replace them with the stock plastic mounting hardware.
For your other questions someone with more experience with the car will need to chime in.
BTW nice looking track.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 04-22-2013, 07:06 AM   #6291
yeah, I know. It is the receiver mount right? Is this required? I have seen some people run it and some not. After, I get the kit today, I plan to see whats there and what not and make an amain order. He sent spare arms. I was thinking about getting towers, but I never even break the towers on the b4. that track is very nice to cars. its like crashing on pillows, lol.
Old 04-22-2013, 07:16 AM   #6292
Super Moderator
Trader Rating: 17 (100%+)
I hope to be picking up my RB6 this weekend. Can't wait to get my hands on it
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-22-2013, 07:48 AM   #6293
eper's Avatar
Trader Rating: 14 (100%+)
you shouldnt need towers. in the pics it looks to me by the spacing of the arms it has the wide blocks on it. I have bought a few used vehicles and one thing ive learned is always take them completely apart and go through them. there are a lot of people out there who arent good at building these kits and build things wrong. the car will still work but not the way it was intended and you may end up being like this things a pos when in fact its something smalll and easy to fix.. thats the best advice i can give you. receive it and disassemble it. then enjoy
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 04-22-2013, 07:55 AM   #6294
yeah, i always tear them down. I always like to check for stripped screws, plus it helps me better understand how to put the car together and take it apart. I hate pulling out manual at the track on my phone, lol.
Old 04-22-2013, 08:09 AM   #6295
I like having the little platform to hold the strap in place it's more of a piece of mind thing for me. From the pic yes it does have the wide blocks on it now. As for the shock mounts I personally would go back to the stock ones.
www.OHRCR.com
Old 04-22-2013, 08:20 AM   #6296
it looks like the kyow5303-05 tree comes with a lot of not so useful items. Does anyone else make a plastic or delrin upper shock mount?
Old 04-22-2013, 08:24 AM   #6297
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Welcome to Kyosho....where you have to purchase parts in trees.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-22-2013, 08:29 AM   #6298
lol, yeah. I did notice that when i was poking around. Losi always liked to bundle stuff too. I am hoping the car will make it all worth while Is the chassis still denting in under the rear of the tranny? I read about it when the kit first came out. Have not seen it said in a while, so I figured it was fixed?
Old 04-22-2013, 08:34 AM   #6299
caguilar4's Avatar
I just changed to the Triad slipper clutch, and man what a difference! With the stocker, I was having the slipper clutch come loss for the 3rd qual, and then my Diff would come loose as well.
Now with the triad, slipper has been consistent for 6 qualifier runs, and 2 main events! Slipper is a bit noisy though (gear noisy, not slipping noisy)... compared to the stocker
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 04-22-2013, 08:40 AM   #6300
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Default kcar
here is my layout for midmotor. i have the shorty bumped all they way back against the motor. i mad a little stop block out of carbon and wedged it up against the motor, then added a foam pad to space the battery about 1/4 form the motor.setup is pretty close to tebos mm but using ghea pistons and have 32* castor and a few other changes. car is working well at the track, as fast as my rear mototr car.
Kyosho Ultima RB6 & RB6.6 Car Thread-image.jpeg   Kyosho Ultima RB6 & RB6.6 Car Thread-image_1.jpeg   Kyosho Ultima RB6 & RB6.6 Car Thread-image_2.jpeg
ryanpatrickgore is offline   Reply With Quote
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22970 10-17-2017 05:10 PM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15020 10-08-2017 07:30 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
