    Hide Wikipost
R/C Tech Forums Thread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Like Tree6Likes
Old 04-17-2013, 12:12 AM   #6241
silvalis's Avatar
Trader Rating: 29 (100%+)
Says 41mm
You *may* have width issues. I'll have a look later
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-17-2013, 12:13 AM   #6242
silvalis's Avatar
Old 04-17-2013, 05:56 AM   #6243
Trader Rating: 48 (100%+)
Which rear wheels fit the best. So far noticed that the AKA and Avid rims dont work since there is not enough thread left over for the nut.
Thanks to my sponsors:
My Credit Card
Speedychris22 is offline   Reply With Quote
Old 04-17-2013, 07:05 AM   #6244
caguilar4's Avatar
Same thing with the JC rear wheels
RB6 | XB4 | SC10.2 | MBX6 | RC8.2e
caguilar4 is offline   Reply With Quote
Old 04-17-2013, 07:27 AM   #6245
DeanV's Avatar
As mentioned in earlier posts, almost all of the non-Kyosho rear wheels will need a serrated nut and then they fit fine (though I cannot speak for AVID, haven't tried)
I personally run nothing but AKA and love the way they fit, especially in the front. The hex/hole is perfect and not wobbly.
Dean
ARC R11
XRAY T4 VTA
XRAY X12 2016
DeanV is offline   Reply With Quote
Old 04-17-2013, 07:27 AM   #6246
playerdd's Avatar
AKA Hexlite wheels work fine on the RB6.
All you have to take care is changing to a nut like the 1-N4045F that secure themselves on the wheel and not the shaft.
The whole team ran them at the European Offroad Series race last weekend without any single issue of a wheel coming loose.
KYOSHO Germany, Team Orion, KO PROPO, AKA, UpgradeRC, ABI, RCM-Racing
playerdd is offline   Reply With Quote
Old 04-17-2013, 07:42 AM   #6247
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Dean
Which LPF serrated nut are you using?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-17-2013, 08:06 AM   #6248
silvalis's Avatar
I'm using some xray and durango (cheap) ones I had lying around.
The CoreRC ones are fine too.
I had some 3racing alu ones strip themselves somehow once, so maybe avoid them...
I'm running avid wheels. Rears will need serrateds. Avid fronts will need the Rb5 axle that does not have the integrated hex. Note that using this will space out your regular k wheels by a couple of mm.
Old 04-17-2013, 10:04 AM   #6249
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Iv never had a single issue with the factory kyosho wheels myself, and I think they look the best to boot
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-17-2013, 10:13 AM   #6250
well, I have avids, JC's and AKA wheels from my b4, so I am hoping they will all fit. Looks like i might need LPF nut for sure.
Old 04-17-2013, 10:23 AM   #6251
Rfury's Avatar
Send a message via AIM to Rfury Send a message via Yahoo to Rfury
KYO1-N4045F is the Kyosho part number for serrated nuts. They are pretty cheap too.
http://www.amainhobbies.com/product_...Flanged-Nut-10
If you look around you can find them in red as well.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Rfury is offline   Reply With Quote
Old 04-17-2013, 10:25 AM   #6252
are those low profile enough for the avid/jc/aka rear wheels?
Old 04-17-2013, 10:29 AM   #6253
lbckevin's Avatar
Trader Rating: 89 (99%+)
The best fitting wheel is the stock Kyosho wheels. No wobble, stays straight and looks good.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 04-17-2013, 10:32 AM   #6254
The price on the wheels is nice and they appear to have a lot of webbing. But i still need to use up my other wheels and tires first, lol.
Old 04-17-2013, 10:32 AM   #6255
Rfury's Avatar
I run them on JC wheels without issue.
I will agree that the Kyosho wheels are the best for the car. The availability of JC wheels locally out weigh that for me. I don't have to order a bunch of wheels and carry them with me. The LHS has the JC wheels on the wall at all times.
Kyosho RB6
Kyosho ZX6
Kyosho MP9e TKI
Ryde it like you stole it: the Ryde Drivers thread. old_skoolie Australian Racing 22939 Today 01:36 AM
Island Raceway & Hobby (IRH), Lindenhurst, NY - Indoor Off-Road Track in Long Island Asharus Northeast Racing Forum 15013 06-22-2017 04:17 PM
Kyosho Ultima RB5 Thread Drift_Buggy Electric Off-Road 14641 11-10-2015 08:28 AM
Kyosho Ultima SC aeRayls Electric Off-Road 2599 04-27-2014 04:30 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
